      01-19-2013, 08:25 PM   #2157
RASHID007
Drives: 2014 535d X-Drive
Originally Posted by shawnsheridan View Post
Not necessarily. As I wrote above, 48.2 may also have the increased Token Security. It was barely around long enough before 48.3 came out, so there just isn't many users nor feedback on it.
Ah, so 48.1 then depending on my integration level.
Actually, I'm happy to pay the $65 and support the cause. I'm not even going to bother checking iLevel. I'm just order E-Sys patch and token.
Thank you. You're the man.
      01-19-2013, 08:27 PM   #2158
skiscreamer1
skiscreamer1's Avatar
Drives: 2013 bmw 328i sedan rwd
interesting
interesting!
Originally Posted by svache View Post
Thanks for the support guys
I'll try to have some instructions and PDF with the confirmed coding I did online somewhere tomorrow
@Mith: Technically anything you mod could void warranty. However, if you mod the camera and your engine breaks down, then the mod to the camera would not void your engine's warranty. Also, they need to proof that your mod actually caused the engine to break down if they try to claim that your warranty is void due to a certain mod (of course, where I say mod, you could say code but technically a chance in code is a bit of a mod).
One thing that might be good advice is to keep backups of every chance you make so you can always revert to the last update (or original even) in case something seems to be wrong
      01-19-2013, 08:40 PM   #2159
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
Rashid let me know if you need help applying the patch..
M Sport Line Estoril Blue
      01-19-2013, 08:46 PM   #2160
kon
Singapore
Drives: F30 316i
Shawn. Please pm info for the new esys and token. Thanks!
      01-19-2013, 08:47 PM   #2161
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
PM sent.
      01-19-2013, 08:52 PM   #2162
kon
Singapore
Drives: F30 316i
PM sent.
Just to clarify, this is just to get an updated esys and token (password) only right? Pszdata is independent of this, which the community will continue to rip from Ista/p?
      01-19-2013, 08:53 PM   #2163
shawnsheridan
Yes, totally separate from the PSdZData.
      01-19-2013, 10:55 PM   #2164
john08135i
john08135i's Avatar
I AM GOING TO PULL MY HAIR OUT..
After buying my token and testing by coding one setting.. i had to go back and watch my kids. Well now it wont connect to eh car..
NO ZGW AVAILABLE... i didnt change anything. I just closed esys.
What causes this?
      01-19-2013, 11:34 PM   #2165
RASHID007
What causes this?
Is the 1 setting you changed with the patched E-sys and new token still coded/working? I imagine it is, just trying to troubleshoot and wondering if I do mine should I do it all in 1 shot first try if it'll stay coded.
      01-19-2013, 11:44 PM   #2166
RASHID007
John08135i scared me a bit with his problems above with new patch/token so I checked my iLevel. Guess it's official, I can't go back beyond 48.3 and I hope that the patch/token work.
      01-19-2013, 11:55 PM   #2167
kon
Singapore
Drives: F30 316i
What causes this?
I don't have the new token file to try, but are testing the new esys on a machine that never had esys installed... did you have the EDIABAS folder copy to the root directory? All I wanted to know, i long is a long shot, is able to read FA & CAF file since this new machine is desktop and cannot be used for coding at all
Extract from installation instruction (from esys 3.18.4)
Run "C:\EDIABAS\Hardware\Ediabas-Konfigurator\Ediabas-Konfigurator.exe" and make sure "Interface:" is set to "INTERFACE=ENET".
Did you also update the esys program properties to point the token & ods to the right file/directory?
Let's just say you had a bad day.... I do sometime fail to get IP from the car, what I did to make sure I ALWAYS get an ip is start the laptop AFTER the cable is connected to the car & computer, and turn on the car (not start engine)...
CHECK to make sure your computer is receiving an IP with "limited connectivity"
I'll be around for the next few hour... will be heading out to a coding party thereafter, hopefully none of the car will have 505!
      01-19-2013, 11:57 PM   #2168
kon
Singapore
Drives: F30 316i
did you try with 48.1 or 48.2 with esys 3.18.4? did you have any error?
      01-20-2013, 12:19 AM   #2169
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
How did you end up with that iLevel? Was it when you took your car in for the FEM module recall back in December?
I'm helping another forum member code his MY2013 this week so I hope it will be ok with 48.1.
      01-20-2013, 12:56 AM   #2170
RASHID007
I will try tomorrow and report back.
      01-20-2013, 12:57 AM   #2171
RASHID007
On January 16th I had the car into the dealer for something and they told me there is a software update type recall that they installed. Not sure what the recall was for.
      01-20-2013, 01:50 AM   #2172
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
What causes this?
As kon says, it looks like you are just not connecting as the connect via VIN is grayed out.
Did you try just running ZGW_SEARCH.exe and see if that will read your VIN?
I don't think that program accesses the ODX or token (can anyone verify?), so if that won't connect, then you have a cable problem, the car ignition wasn't on, or you didn't get into DHCP fallback mode.
      01-20-2013, 02:51 AM   #2173
ykau
Drives: F30 320I
hi guys, at first i have intermitten problems connecting my cable direct with my windows machine. Until when I installed http://www.dhcpserver.de/dhcpsrv.htm into my windows and make it as DHCP server. Ever since, connection is very smooth.
      01-20-2013, 02:56 AM   #2174
kon
Singapore
Drives: F30 316i
I don't think this would help as the computer is getting the IP from the car, not the other way round? Or is it?
      01-20-2013, 04:43 AM   #2175
shawnsheridan
What causes this?
I am not sure what the issue is with the connection problems. I have messaged Andy, and hopefully he can figure it out.
      01-20-2013, 04:44 AM   #2176
ykau
Drives: F30 320I
Yes.. It will assign IP to the car.(-:
      01-20-2013, 04:45 AM   #2177
shawnsheridan
The car does not have a DHCP server; so it does not assign an IP Address to the computer. Both the computer and the car will go into DHCP fallback mode, each assigning themselves a random Class-B IP Address so that they can talk to each other. This can take up to 60 seconds, so you have to wait until the PC has an IP address before you try to connect.
I don't see how a DHCP Server utility will help.
      01-20-2013, 04:47 AM   #2178
shawnsheridan
Ok. Hopefully you are correct.
John can try it and confirm if it works.
