Login
05-29-2012, 05:17 PM | #1 |
![]() 10
Rep 144
Hub centric or lug centric?
I bought a set of oem 17" wheels to replace my 18's in the winter. I'm going to get the winter tires mounted tomorrow and am curious if I need to have a new centering ring installed? can they install the ring without the car present?
06-05-2012, 02:50 AM | #2 |
I plead the 5th.
![]() 339
Rep 1,406
While you probably already got the wheels installed, it doesn't hurt to answer in case someone else searches and comes across this thread
![]() Newer OEM BMW wheels will have a center bore of 72.56 (72.6) - this is the same size as the hub on your vehicle. Thus, no hubcentric rings will be required for installation. If hubcentric rings are required for wheels with a center bore larger than 72.6, the rings can insdeed be installed into the wheels without the car being present. |
07-03-2012, 01:25 AM | #3 | |
![]() ![]() ![]() ![]() ![]() ![]() 1858
Rep 31,234
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
