BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW M Performance Interior Kit Install DIY Guide for F30
      12-29-2012, 01:47 PM   #89
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
No one has tried the CF shifter too?
SOLD: 2012 335i Mineral Gray
      01-01-2013, 12:47 PM   #90
NYmsportF30
Drives: 335i m sport estroil blue
I do, I'm still trying to find out how to do the installation. Anyone know?
2013 335i ///M-Sport, Estoril Blue II, Alum Hex trim with Estoril accent, Black leatherette, Navigation system, Sport automatic with shift paddles, Heated front seats, Bluetooth, rearview camera with park distance control.
      01-01-2013, 05:08 PM   #91
PGT
Drives: 440i X-Drive in Snapper Rocks
I just did it. The shift pattern is actually a sticker. Remove that and there's a T9 screw underneath. Be sure to swap the little white plastic light diffuser over from the old one
| '13 328i M Sport - Estoril Blue | '12 300C SRT8 | '12 Wrangler Rubi Unlimited - COD MW3 Edition|
      01-01-2013, 09:16 PM   #92
NYmsportF30
Thanks a lot PGT.
      01-02-2013, 12:31 AM   #93
PGT
anybody have suggestions on removing the door pieces? At the lower edge, there's a spring clip and a slot to access it. I took one piece off and had such a hard time, I'm not inclined to do the others unless I'm sure I'm doing it right.
      01-02-2013, 10:52 AM   #94
cheukmc
Drives: F30 335i
Originally Posted by NYmsportF30
Hey guys, I just received the carbon fiber trim for the automatic shift knob. Would anyone happen to know how that is replaced? I wanted to ask before I started messing around with it but so far I haven't seen anyone whos changed it yet.
I would like to know how to change my automatic shift knob too, someone please help. Thanks!
      01-02-2013, 11:15 AM   #95
PGT
read post #91
      01-02-2013, 01:55 PM   #96
mfrenkie
Drives: 2013 F30
Dog
Originally Posted by Serenitygal3 View Post
Is the carbon fiber near the idrive easily scratched? I would love put this in my car but my dog walks across the trim and I wonder if it will scratch easily and if the scratches are very noticeable? Thanks.
Can anyone answer this question? Thanks!
      01-02-2013, 03:59 PM   #97
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
The door pieces were the only tough part for me, I wound up breaking two of mine upon removal.
This image I made up as a guide might help you a bit.
Keep in mind, there is an angle to both the removal and install process, look at the tabs, they are angled.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      01-02-2013, 04:18 PM   #98
PGT
so, there's no trick. Basically, working from bottom to top, loosen the perimeter tabs until they're all clear and then you're working against the metal clips. That's basically what I did for the first one I tried.
And....there's L/R x 2 but no LF, LR, RF, RR....correct?
      01-02-2013, 04:57 PM   #99
Jamesons Viggen
Correct.
If that M-Performance press release was out which stated the labor charges, I would have spent $80 to have the dealer do it vs $150 to replace the two door pulls I broke lol.
Now that I installed them all I am much more confident I could remove them without breaking any.
      01-02-2013, 05:13 PM   #100
PGT
Yep....I knew the labor charge and wanted to have my wife take it in but she asked me to try and get it done while I had some free time yesterday. The dash was easy (save the one connector for the hazard/lock button).
      01-02-2013, 06:15 PM   #101
Jamesons Viggen
Yep, I did all the other pieces in 8 minutes. The doors though, I probably rushed, hence breaking two of them lol.
      02-09-2013, 02:34 PM   #102
mikew2069
mikew2069's Avatar
61
Drives: F30 335i MSport
Originally Posted by linhperfume View Post
Sorry, I didn't explain well cause my english is poor
For the idrive, removed like that, softly
Attachment 702874
hope it helps
Is there dead space in the consul under this center panel? I'm thinking about mounting the mute button of my Escort Radar right where the tip of your left thumb is on this picture but I would need 1" or 1.5" of dead space (depth) in the consul to make it work.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      03-01-2013, 10:33 AM   #103
Chris12330
Drives: BMW 320d F30
Where did you get this kit from? was it BMW? Looks great
      03-01-2013, 12:24 PM   #104
finaloption
finaloption's Avatar
Drives: '13 f30 n26
on shopbmwusa.com, it's selling for $1050.. there's gotta be cheaper out there
      03-01-2013, 12:41 PM   #105
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [3.88]
http://www.ebay.com/itm/BMW-F30-M-PE...46568a&vxp=mtr
      03-13-2013, 02:57 AM   #106
SJ00
SJ00's Avatar
Australia
139
Drives: 328i
im doing mine right now
its so frustrating
how do i remove the dash wires?
anyone help?
      03-13-2013, 08:35 AM   #107
Jamesons Viggen
its so frustrating
anyone help?
There are small indentations on the clips, you press in the tab in the indentations and wiggle the clips free.
      03-13-2013, 08:38 AM   #108
SJ00
SJ00's Avatar
Australia
139
Drives: 328i
This is what I did, I couldn't figure out how to unwire the damn thing
      03-17-2013, 02:22 AM   #109
minijet
minijet's Avatar
Australia
26
Drives: Train
its so frustrating
anyone help?
Why are you removing the centre dash wires?
The whole airvent and button etc unclips from the trim.
look at the top and the bottom, there are clips on the top and bottom. I just attacked the top with my pry tool and it clipped off. No wire removal required.
See below pic from first post. see those clips on the top. Just pop it off and the hole vent comes off. Just refit vent into new trim and there is no removal of wires required!
I managed to change all the trims in <15mins. its not as bad as it seems.
      03-18-2013, 12:41 PM   #110
JMSpace144
Drives: '13 335i
Looks great! Anyone got pics of the cf shift knob installed??
3 series f30, 3 series f30 diy, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy 3 series f30, diy f30, diy f30 3 series, diy f30 series 3, f30 3 series, f30 3 series diy, f30 3 series forum, f30 3-series, f30 diy, f30 forum, f30 forum diy, f30 forums, linhperfume
