BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19" tire size question?
Extreme Power House
      06-02-2012, 09:43 PM   #1
onehungevo
Drives:
What size 19" tires are necessary to prevent the speedometer from being off? I have been told different sizes by various vendors. Should they be 30 or 35?
      06-03-2012, 10:53 PM   #2
onehungevo
Drives:
Help!
      06-03-2012, 11:38 PM   #3
ric124
ric124's Avatar
Jamaica
392
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I would think to use the same size BMW uses for the optional staggered 19" wheel option
      06-04-2012, 07:09 PM   #4
onehungevo
Drives:
Good idea but I putting on wider rims.
      06-05-2012, 01:59 AM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
The tire profile number, also known as aspect ratio, is not a uniform value for all tire sizes. The profile number is actually the thickness of the sidewall, measured as a percentage of the width in millimeters (Thickness of a Tire = Width * Profile as a Percentage).
Thus, a 225/45/18 will have a sidewall thickness of .45*225mm = 101.25mm, or about 4" thick.
There is no 'set' profile to go with for an 18" Vs. 19" tire, as it is entirely dependent on width. What you really need to be concerned with is the outer diameter of your tires. You will choose your profile size based on what width you would like to run to match the outer diameter of your OEM setup.
What size wheels were you planning to run and what width tires were you hoping to go with?
      06-05-2012, 06:55 AM   #6
onehungevo
Drives:
19x8.5 front and 19x9.5 rear.
      06-05-2012, 02:05 PM   #7
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Do you know the offsets of the wheels you are looking to pick up?
