BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 245 versus 225 f30's
VIBE Motorsports
      06-03-2012, 02:27 AM   #1
hanman
BMW ENTHUSIAST
hanman's Avatar
Drives: 2017 M3 COMPETITION
So why would BMW not choose the 245's as the standard? Any reasons why I should not change to 245?
2012 335i M-Sport Black Saphire
2014 X5 35i M-Sport Alpine White
2017 M3 Competition Mineral White
      06-03-2012, 03:19 AM   #2
CoolDude196
CoolDude196's Avatar
England
24
Drives: f30 20d
I suppose it adds weight, and more surface area would consequently mean more friction which would lower mpg/increase co2.
More friction would mean more grip however, which is obviously a benefit
AW Sport 20d, 2tb, 552, lc, 397 plus others
      06-03-2012, 04:24 AM   #3
HighlandPete
Drives: BMW F11 535i Touring
Why would you want to? What characteristics are you wanting to change about the car? I assume you are talking front and rear on the same rims?
I would suggest the 255 is the section BMW find gives the best feel from the chassis for the average driver. The typical chassis BMW driver's aim for.
I know I wouldn't want wider tires on the same fromt rim, as steering would be less precise, not as sharp on turn in and likey much more corrupted. I can't see the car being as nimble on fitting wider tires on the same rims.
HighlandPete
      06-03-2012, 09:48 PM   #4
hanman
BMW ENTHUSIAST
hanman's Avatar
HighlandPete
Honestly it's really more for the look than anything else and if I can get some added grip then all the better. Great advice though on the rims. I think I will look at 19 or 20 on 255 or keep my 18's on 245.
Thanks
      06-03-2012, 10:56 PM   #5
onehungevo
Drives:
I wasn't very happy when I figured out the sport sedan runs the same size all around. I think the staggard fitment makes a BMW.
      06-05-2012, 11:34 PM   #6
hanman
BMW ENTHUSIAST
hanman's Avatar
yup me too
      06-06-2012, 11:18 PM   #7
onehungevo
Drives:
I would say the reason they ran the same size is to cut cost and for easier inventory management.
      06-07-2012, 09:02 AM   #8
mocohead
mocohead's Avatar
32
Drives: '16 M235i 6MT & 12 128i Msport
It is funny that people comment negatively on the square setup on the f30. Typically you will see track drivers complain about the staggered setup because it causes more understeer. We are always trying to find a tire/wheel combo that will allow us to run same sizes front and rear, adding front grip without taking away too much rear grip.
      06-07-2012, 09:11 AM   #9
Robin_NL
S0THPAW
Robin_NL's Avatar
Netherlands
2556
Drives: LBB M2+MPE
Fair enough, but keep in mind that the //M series always have staggered setups for a reason. Call it safety(more understeer), or call it more traction.
I'm a tad familiar with track and driftdays so to speak.
If you want a playable car , put on 255 up front and 225s at the back, whatever.
IF BMW should have a 245 square setup I might have chosen that one, but 225 square is just way too tiny for a 335i imo.
All my former 3 series had staggerde setups...
Cheers
Robin
      06-07-2012, 03:01 PM   #10
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
Track driver's would also complain about OE 225mm tires on a 3400 Lb car as well though.
Square setups are typically sought after to maximize track performance but I don't think BMW went with the OE size it did for this reason. I'd say the complaints are valid, but only from a subjective aesthetic viewpoint.
The OE non-staggered setup would be cheaper (half the part numbers for wheels and half the part numbers for tires). Not sure if this was the reasoning, but could have been a factor. To me, a 3-Series doesn't need staggered wheels in the most basic form; that's what options & aftermarket are for
