Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > 335i brakes in 328i retrofit?
European Auto Source
      06-03-2012, 08:48 AM   #1
darmawaa
Drives: 2013 M135i
Can I install 335i brakes (Front and rear) in 328i ?
I plan to buy M performance brake for my 335i and sell the stock 335i brakes to 328i owner
      06-03-2012, 08:56 AM   #2
clarence
Drives: F30 328i M-Sport
Yes u can, cos the US-spec 328i M-sport brake (factory fit) is just the standard 335i brakes with calipers painted in blue with M logos.
      06-03-2012, 09:46 AM   #3
mocohead
mocohead's Avatar
26
Drives: '16 M235i 6MT & 12 128i Msport
Please PM me. My research says you can do this, and I am interested.
Thanks
      06-03-2012, 10:17 AM   #4
clarence
Thanks
OP is located at Indonesia, probably cheaper to get it from someone local.
      06-03-2012, 09:30 PM   #5
darmawaa
Drives: 2013 M135i
But the M performance brake rear disc rotor is different for 335i and 328i.
http://www.turnermotorsport.com/p-14...335i-2012.aspx
      06-04-2012, 04:18 PM   #6
Eddy1971
Netherlands
Drives: Stolen 525d touring
So, can you help me out: the what's then the difference between stock 335i brakes and 335i m sport brakes?
      06-04-2012, 05:07 PM   #7
clarence
For US-spec factory fit M-sport brakes on a 328i, it's just the stock system from a 335i but with painted calipers.
Wht u saw from that link is the retrofit kit from the M-performance range, which is identical to EU/ROW-spec factory fit M-sport brakes for the 328i, save for the slotted & "drilled" discs & the different coloured calipers.
      06-04-2012, 05:21 PM   #8
clarence
Stock: 340mm front discs
M-sport: 375mm front discs.
The rears on the M-sport are 345mm w/dual piston fixed caliper. I think the stock rears are 330 on sliding calipers.
      06-07-2012, 09:04 AM   #9
mocohead
mocohead's Avatar
26
Any 335i owners who want to sell me their OE brakes please send me a PM. Thanks
      08-07-2012, 04:50 PM   #10
evobda2
evobda2's Avatar
Drives: F31 M Sport
Does anyone know if 335i callipers/discs will fit on a 120d m-sport?
Ive seen it done here, but cant seem to find any exact info of the conversion.
http://www.1addicts.com/forums/showt...1#post12459191
      01-02-2013, 05:15 PM   #11
chlemaire
Drives: 2013 335i M-Sport Line
I'm assuming you found a seller by now, but if not, I have a practically brand new (~900 miles) set of OE brakes (complete set, calipers & rotors) from a 2013 335i M-Sport Line available for sale (I upgraded to M performance brakes).
      01-03-2013, 09:57 AM   #12
F30 Pilot
F30 Pilot's Avatar
Drives: F30 328i
PM Sent
2013 AW 328i: Sport Line, Sport Trans, Moon roof, Navigation, HK Stereo with Sat Radio, Xenons and 351m wheels
      02-19-2013, 07:08 PM   #13
pnosker
ti fan
22
Drives: 2008 135i | 2008 535xiT
I also have a set of 335i brakes with 1002 miles on them from a 2013 M Sport 335i if anyone is interested.
      02-19-2013, 07:33 PM   #14
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
PM sent
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
