BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i 335i Front Kidney Grill / Grille removal and replacement DIY
      06-06-2012, 01:43 PM   #1
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
BIMMERPOST
     Featured on BIMMERPOST.com
Hey guys,
This is a quick guide to removing and replacing your kidney grills.
Estimated Time: 15-20 minutes
Tools Necessary:
T20 Torx
T30 Torx
small flat head or pick tool
Steps:
1. Locate the rubber hood seal at the front of the engine bay.
2. Remove the seal, starting at a side will make it easier.
3. There are going to be 8 screws (6) T30 torx and (2) T20 torx which need to be removed. A T20 torx screw is located over each headlight
4. Now that all 8 screws are removed, the bumper cover should slide forward. Be careful and make sure to pull straight forward rather than up as there are 4 metal clips which hold the bumper in place which would break.
5. The bumper cover is flexible to a reasonable extent, allowing for a hand or tool too fit behind the grills. Moving away from the center of the bumper allows for more flex, anyone with big hands would probably find it easiest to start on the outside and work inward.
6. Now using the flat head or pick tool press the release tabs on the grill while gently pulling on the grill from the outside, there are 3 clips on both the top and bottom of the grill as well as 1 clip on each side.
Note: the bottom clips are going to require using your hand rather than the screw-driver because they face the ground.
7. Once the first grill is free of the bumper you can easily access the other grill... Don't be impatient and pop a new grill in before having both sides removed, it makes more work for yourself.
8. Now just gently push the new grills into place, run your hand around the gloss black trim piece to ensure all the clips are secured
*use a microfiber cloth if you don't want fingerprints*
9. After the new grills are in place, line the metal clips up with the bumper cover, and then slide it back into place.
10. Once in place replace all 8 screws and prior to tightening them ensure that the bumper cover is even, I did this by comparing two of the outermost points.
I also repeated this procedure on the rubber seal using the outermost T30 screws as reference points, its not necessary but always helps to keep the car looking it's best.
I hope this helps answer any questions and Good-luck!
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
Appreciate 15
      06-06-2012, 01:46 PM   #2
DrivenByE30
DrivenByE30's Avatar
France
310
Drives: '12 F30 Lux 335i 6MT
Wink
PS: your driveway is only missing a Mercedes to complete the big four German Premium Brands
Hows do you like the A3 and Boxster over the F30? how do they compare?
      06-06-2012, 01:57 PM   #3
1.fresh.f30.335
Haha, I know we've looked into the Benz's a few times just never worked out... it's an a4 thats in the background, and we have a Q7 and an A8L too (we like those quattro cars haha) I like different things about different cars, they each have a unique character. Power-wise, the bimmer kills em
      06-12-2012, 05:59 PM   #4
MiloMia
MiloMia's Avatar
Drives: 2012 F30 335i
thank you op, this thread came in handy.
2012 BSM F30 335i:H&R Sport/
      06-12-2012, 10:15 PM   #5
K.Ip
K.Ip's Avatar
Drives: F30
great write up
thanks!
      06-20-2012, 08:43 PM   #6
pkimM3r
pkimM3r's Avatar
136
now its time to do mine tonight
      06-26-2012, 06:48 PM   #7
scott@bmwhn
Drives: Msport X3
Cool, looks about the same routine as the E9x models. Thanks!
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      06-26-2012, 06:50 PM   #8
pkimM3r
pkimM3r's Avatar
136
when i did this, i was sort of worried on how far back i had to bend the bumper. guess everything worked out just fine though.
      06-26-2012, 07:29 PM   #9
positiveions
positiveions's Avatar
Lebanon
264
Drives: 09 MKV JETTA 2.5 & '16 F15 X5
Send a message via MSN to positiveions Send a message via Yahoo to positiveions
car looks so much better. good job
      06-26-2012, 08:44 PM   #10
ORIGIN M.
ORIGIN M.'s Avatar
1453
Drives: ///M
Nicely done - Thanks for sharing sir
      06-26-2012, 09:30 PM   #11
WULFFZA
WULFFZA's Avatar
Drives: 2011 335i MSport / 2012 X5 35d
Mercedes is his wife's name. She doesn't hang in the driveway. That's not how she rolls.
2011 E90 335i M-Sport 6MT Alpine white - saddle brown
2012 E70 X5 35d Sport Activity - Alpine white - black
2005 Toyota 4Runner 4WD Sport Edition Silver
      06-27-2012, 05:42 AM   #12
E91-Norway
E91-Norway's Avatar
Norway
Drives: 15 F36 420D GC MSport MPerf
M Performance kidney
Here is the result on a Melbourne Red F30
      06-27-2012, 06:23 AM   #13
Bluesummer
Bluesummer's Avatar
Taiwan
257
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
looks like major pain in the ass
      06-27-2012, 06:27 AM   #14
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2015 Audi A3  [0.00]
2015 Porsche Macan S  [0.00]
2011 BMW 1M  [0.00]
Thanks--perfect timing, just got the new ones!
      06-27-2012, 07:01 AM   #15
Needsdecaf
Everything's Bigger in Texas!
Drives: Porsche Tractor
It really could not be much easier. I guess if you had your two year old reach between the grille slats and release the tabs it would be but....
Seriously, this is essentially the same as on the F10 and it took me longer to take out my tools and put them away than it did to do this swap.
      06-27-2012, 07:16 AM   #16
R12ax7
R12ax7's Avatar
44
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
Great info! I'd be interested to hear if anyone successfully swaps the grills without removing the bumper cover like you could on the e9x. The tabs look almost the same, granted removing a couple torx screws is no big deal.
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      06-27-2012, 07:47 AM   #17
E91-Norway
E91-Norway's Avatar
Norway
Hi!
If you have small fingers, you my be able to do it.
Still you have to work with silky hands....
      06-27-2012, 09:13 AM   #18
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
I was able to take mine out on the E90 without even popping the hood. Just lift the tabs from the front with my fingers. You really need to take off the top of the bumper cover to do this?
2013 EB/CR 335i xdrive | DHP | Coded | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      06-27-2012, 10:16 AM   #19
Ka razy
Ka razy's Avatar
Drives: 2011 BMW 335I xDrive Coupe 6MT
Thank you for sharing!
2014 Corvette Z51 Stingray 3LT, 7 M/T
2007 BMW R1200GS Adventure
Retired- 11 BMW 335, 04 BMW Z4, 01 K1200RS, 00 R1150GS
Four wheels move the body. Two wheels move the Soul!
      06-27-2012, 10:42 AM   #20
E91-Norway
E91-Norway's Avatar
Norway
Yes me to, but luckely the F30 has a more aggressiv design especial in the front end
      06-28-2012, 12:21 AM   #21
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
First of many mods I hope. Nice ride
      06-28-2012, 12:39 PM   #22
woo1
Drives: 2008 135i : M Sport/PPK
You actually don't need any tools for this. They pop out easily, and without damage if you pull around the edges and pull one clip out at a time. I recently did mine and it worked perfectly. The dealerships just yank them straight out with one forceful pull. The total time to replace both kidneys was about 4 minutes. If they feel stuck, spray the clips with silicone and pull again. Easy!
3 series f30, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy f30, diy guides f30, f30 3 series, f30 3 series diy, f30 3 series diy guide, f30 3 series forum, f30 3 series grille, f30 3 series grilles, f30 3-series, f30 3-series forum, f30 diy, f30 diy guides, f30 forum, f30 forums, f30 grill, f30 grill diy, f30 grille, f30 grilles, f30 grills, f30 kidney grille, f30 kidney grilles
