BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > What size rims are u going with?
      06-10-2012, 05:44 PM   #1
onehungevo
Drives:
What size rims are you going with? I'm having a hard time deciding between 19's and 20's. I'm thinking 20 might look a little too big but I haven't seen an f30 in person with 20's to help me decide. On the other hand, I'm afraid 19's will look too small. FYI.... I'm lowering my car.
      06-10-2012, 05:57 PM   #2
pcbrew
pcbrew's Avatar
29
Drives: 2012 335i 6MT
Sport Line with standard 18" 397 rims.
      06-10-2012, 05:59 PM   #3
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Aftermarket rims + no track = get 20" rims. You'll need the extra 1/2 radius to fill the gap.
      06-10-2012, 06:07 PM   #4
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I tried responding to your PM but your inbox is full.
Here is what im thinking of going with not 100% sure yet.
Front
Offset: 40
Bolt Pattern: 5-120
Rec. Tire Size: 225/40-19
Rear
Offset: 45
Bolt Pattern: 5-120
Rec. Tire Size: 255/35-19
      06-10-2012, 10:32 PM   #5
onehungevo
Drives:
I'm looking at the same size rims but a little more aggressive offset. Tires I'm thinking if going with is 235/35/19 and 265/30/19.
      06-10-2012, 10:53 PM   #6
groovybits
335i Owner
Drives: F30 335i, Blacked Out Alpine W
I went with the 19" Sports Line. I heard the 20" impact ride comfort somewhat. Can't verify this myself though.
Fully Loaded F30 335i Sports Line
Blacked Out Alpine White
      06-10-2012, 11:24 PM   #7
Blake P
Kinda Like A Big Deal
Drives: F31 on order
20's look great, but where I drive there's no way thin rubberband tires will cut it.
      06-10-2012, 11:28 PM   #8
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
What offset you going with?
      06-11-2012, 02:07 AM   #9
svache
svache's Avatar
Drives: 2012 F30 328i
I know noone is speaking about this but I felt like just throwing it out here anyways lol.. I saw a 3er with 22" the other day (or whatever it was, it was way bigger than 20's).. I don't recommend it, at all... it looks ridiculous!
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      06-11-2012, 07:14 AM   #10
oedipol
Hong Kong
I am thinking about the same thing! however there is only 1 tire model that would fit 20" !
http://www.tirerack.com/tires/TireSe...lar=Base+Model
So I am leaning towards 19"!
      06-11-2012, 07:22 AM   #11
onehungevo
Drives:
35 offset front and 42 offset rear.
      06-11-2012, 07:23 AM   #12
onehungevo
Drives:
What size tires?
      06-11-2012, 10:36 AM   #13
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
BMW should revoke their ownership and issue a refund!!!
      06-11-2012, 01:20 PM   #14
MiloMia
MiloMia's Avatar
18
Drives: 2012 F30 335i
42 will stick out, you need 45 in the rear.
2012 BSM F30 335i:H&R Sport/
      06-13-2012, 05:10 PM   #15
mxdirtmx
Drives: 2012 BMW 335i (F30) Imperial B
Does anyone know the weight of the stock BMW 18" sport rims (397)?
Also, I assume the stock BMW 397s are cast wheels and not forged, but I have found some good wheels that are close to the weight of good forged wheels for my 335i.... But I really hope some one either knows the weight of the stock rims or they weight them for us once they get their new setup....
Thanks lots in advance,
MXdirt
P.S. My response to the OP's question would be to stay conservative for looks and comfort. stay with 19s, but go more aggressive with a wider setup of: 19x8.5/245s front & 19x9.5/285s rear. This is the F10 M5 type setup & it looks killer and handles like nothing you have ever experienced, unless you have driven a few Lambos/Ferraris like I have
( the car will be far more comfortable & look better... I never prefer a rubber band type tires, with next to no sidewall, that have to go on twenty's or larger anyway)
      06-13-2012, 06:00 PM   #16
nickstin
Drives: '08 AW E92
Why are the offsets so high? Can't we go anymore aggressive without rubbing? The e90/92s could run 10 inch rears with +30 offsets.
      06-13-2012, 07:48 PM   #17
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
F30's don't have as much outer clearance as E92/Pre-LCI E90's. F30 fitment is similar to E90 LCI fitment in that the rear requires higher offset. There is room to fit a wide wheel in there, it just requires a high offset.
If one were to run E92 fitment on the F30, the rear wheels will be pushed out more than the front and they would have rubbing issues.
I'm undecided in the 19" Vs. 20" F30 debate as well. Will need to see more of both, as well as varying wheel styles, before making up my mind.
      06-13-2012, 07:52 PM   #18
onehungevo
Drives:
43 not 42. I think they should fit.
      06-13-2012, 10:49 PM   #19
nickstin
Drives: '08 AW E92
Seems like 19x10 +38 for the rear would not fit then.
      06-14-2012, 07:28 AM   #20
onehungevo
Drives:
That is what I'm being told by all the vendors.
      06-14-2012, 08:44 AM   #21
Dawko
Belgium
191
Drives: :
  [0.00]
Why wouldn't this fit? Look at LT's creations with some 10.5 in the rears and offsets 45 if I'm not mistaken?
      06-14-2012, 11:05 AM   #22
onehungevo
Drives:
The lower the offset the more the rims stick out.
