Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LED turnsignals installed
      09-18-2012, 03:40 AM   #89
zeezz
Drives: F30 328i Sport Line
Anyone have updates on the occasional blinking that svache mentioned? I am probably going to buy a set of 2 of the 68-LED rear lights to test out.
      09-22-2012, 04:45 PM   #90
Alvine90
Drives: slow
These are on the pricey side, so I'll leave the link here:
http://www.ebay.com/itm/2x-CREE-Q5-L...item8bb620747f
pin will have to be filed down to fit 7507
      10-07-2012, 12:41 AM   #91
rxander
rxander's Avatar
Drives: F30 Alpine White
I tried the chrome ones from ebay they work good enough to get rid of the egg yolk.
Wondering about these white ones hoping someone can give some advice on fitment http://store.ijdmtoy.com/Can-bus-BMW...24w-led-2s.htm
Will it fit the f30s?
      10-20-2012, 12:01 AM   #92
Sales@modmy3.com
Sales@modmy3.com's Avatar
43
Drives: Stock
PY24W bulbs will not work for F30 turn signals. Those are for some of the E9x models. You need the 7507 bulbs.
      10-20-2012, 04:28 AM   #93
zeezz
http://www.ebay.com/itm/270894693455...84.m1497.l2649
Put these into my rear turn signal lamps this evening and they are working well. They don't seem to 'diffuse' as well as the regular bulb, but for turn signals I think that should be fine. Not sure if I want to do that for the brake lamps yet though. No errors so far...
      10-21-2012, 03:41 AM   #94
BonanzaNLD
BonanzaNLD's Avatar
Netherlands
Drives: waiting for...328i (F30)
2pc 1156/Ba15s Super Red 42x 3528 SMD LED Brake/Stop Tail Light Bulb Red DC 12V
Yesterday, when I had my tires replaced, the lease company performed some checks on my car. They told me: "you know your turn signal blinks occasionally?" . So, in contrast to what I've been thinking: I also have this problem.
Anyone been able to find error free ones? If not, can anyone tell how to add/install resistors?
BMW 328i, Innovation Edition, Mineral Grey, Sport Line, 18" double spoke, Anthrazit Roof, Aluminium+Black Gloss, SatNav Business, HiFi, Xenon
      10-22-2012, 01:44 AM   #95
zeezz
I was just about to come back here and state the same-- was able to drive behind my car for about 35 minutes and saw 'random' pseudo-flashes maybe once or twice per side, at least. Would be interested if anyone has made any significant changes for this prob.
      10-22-2012, 03:37 AM   #96
persean
Drives: BMW F30
let us know if anything happens!
      10-23-2012, 12:34 PM   #97
persean
Drives: BMW F30
Anyone in OC has a shop? that would do installs for bulbs, HIDs, etc?
      10-26-2012, 08:56 PM   #98
rxander
rxander's Avatar
Just tried these. They are real bright and look good, but they give the turn signal error. However, they do come with resistors. I haven't gotten around to installing them yet. http://store.ijdmtoy.com/BAU15s-7507...507_sku200.htm
      10-28-2012, 10:30 AM   #99
Alex@ONEighty
Alex@ONEighty's Avatar
Drives: 2011 E90 M3 CZP 6MT
Any LED bulb that is used to replace a halogen bulb on the lighting of the car will need a resistor, unless it's interior bulbs. Which just need to be canbus.
So, if you change your front signals to led you need to wire up a resistor for each side, and same for the rear.
This will avoid errors, hyper blinking and random blinks.
If anyone is just trying to get rid of the yellow bulb look I would recommend a white halogen/chrome bulb that lights amber.
      10-29-2012, 03:54 PM   #100
BonanzaNLD
BonanzaNLD's Avatar
Netherlands
Any tips how to add a resistor?
      10-29-2012, 08:05 PM   #101
rxander
rxander's Avatar
http://store.ijdmtoy.com/Add-Load-Re...ight-a/169.htm
      11-01-2012, 10:18 AM   #102
pacecapt
Drives: 2014 435i & 2013 X3 28i
2014 BMW 435i  [0.00]
2013 BMW X3 28i  [0.00]
Regarding coding fixes for LED Errors, has anyone tried not only changing the Warm/Cold settings to "not active" but also changing the "is LED" setting to active? Background, my new F25 has eleven coding lines for each bulb, in addition to the Warm and Cold checks there is a line just below those two that is labeled: "XX is LED". On my vehicle that line for the incandesent bulbs is set to Not Active.
      11-19-2012, 03:02 PM   #103
slmdgee
Usofstance
Drives: 328I 6SPD
So basically we need switchback bulbs? That are white when your driving but when you turn they are back to amber. Rite or am i wrong>
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      11-23-2012, 02:02 PM   #104
ramonE90-NL
Netherlands
Drives: bmw F30 320iA
I would like to see led brake lights. To me the normal bulbs look kinda pink when lit :S
      12-06-2012, 06:19 PM   #105
bzguy888
Drives: 2013 328i
Checking to see if anyone has found a plug-n-play solution?
      12-07-2012, 09:25 AM   #106
Accelerometer
Accelerometer's Avatar
Drives: 11 E90 M3 ZCP
Guys, I have decent experience in LED retrofits and I can tell you without a doubt there is no plug and play LED solution that matches your stock halogen output. Frankly, most of these solutions are borderline dangerous. If you want something that works well and looks OEM you will need to spend the time and effort to build a custom solution.
      12-22-2012, 05:26 PM   #107
zeezz
Quick update since this is still bothering me. I actually took a video of my rear turn signals and determined that the flicker happens once every 4.5 minutes (an odd timing).. I don't THINK there is anything in between those 4.5 minutes (I checked the 30/60 second intervals). I left a video running for 20 minutes and noted there was a flicker at every 4.5 minute interval.
In reading some older E90 threads, I'm thinking this is the check the system does to see if the bulb is burnt out. Since LEDs light up instantly vs incandescents (which wouldn't even light to a significant amount on that pulse), we get the flicker.
I guess I'll do some more looking in the coding section, and/or figure out what else to do. I guess a flicker every 5 minutes is not that bad, although at night it is somewhat visible.
      12-26-2012, 05:37 AM   #108
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
So...in a few words, what is the best, brightest, non error throwing, white L.E.D that will match the stock xenons, with angle eyes?? For '13 328 MSport??
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      12-26-2012, 10:01 PM   #109
zeezz
I am 99% sure the flicker has been fixed by coding off warm/cold checks. I would get a bunch of quick flashes right on starting the car, and now that is gone. I'll have my friends keep an eye out next time to see if the 5 minute flashes are still there. Refer to the coding thread for more details, this should work for any of our bulbs
      12-28-2012, 01:58 PM   #110
HenryX
Drives: 2013 335i
Nice! Keep us posted!
