BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LED turnsignals installed
      01-12-2013, 04:08 PM   #111
lokito
lokito's Avatar
Drives: 335i ///M Sport
Originally Posted by svache View Post
lol ok ok..
So I just went outside for a bit and installed the rear turn signal LED's. I haven't seen anything odd yet (haven't been staring at it long either, I have to do some stuff in a bit before another F30post member is coming over to help test fit my old M3 rims).
All I can say for now is that it looks awesome The color is so much redder now, and since these ones have 42 lights (or something like that), it seems as if they are distributing just as much light as the regular bulbs, just more redder (probably since the LED's are red unlike the bulb that's white and therefor displays a more amber-ish light).
Here's two pics:
Might make another picture/video later when it's dark
Edit: just in case anyone is wondering, these are the LED's I used: http://www.ebay.com/itm/ws/eBayISAPI...m=200702835973 ...as you can see, they were less than 15 dollar and nothing was said about being error free.. I'm starting to believe you could actually get away with the cheaper LED's (I'm thinking of getting one of the cheaper amber LED's with more LED's than my current ones so it's more bright during the day), it's at least not a lot of money if it doesn't work out
Just wondering for my break lights.. the bulbs in the break lights are the exact same as the turn signals.. should I get the same LED's or should I get some with more LED's to make the breaklights even more visible? Kind of feel I should since breaklights are most important
Hi svache, I should be receiving my 335i (U.S. Spec) here in Germany sometime next week ...finally! So after learning that the U.S. models have Red turn signal vs Amber on European models in the tail lights, I see you changed the ones on your car with red LEDs. Is the OEM bulb actually red or is the actual rear light housing that gives the red color for the turn signal in the top corner? I actually like how the amber turn signal looks on European models, but haven't been close enough to one to compare how much the tail lights differ to the ones on U.S. models. Can I change that by just changing the bulb to an amber color one or does it requires the whole light panel to be replaced with one for european models? I'm looking into replacing the turn signal bulbs with LEDs, but wanted to verify before I order any. Thanks!
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      01-14-2013, 05:09 AM   #112
sgbk
Drives: F30
yah, i have to change to LED taillamp but in sunlight it is not bright enough for make a signal. My types are same here, anyone know any brand of LED is better ? brighter ?
      01-29-2013, 06:47 PM   #113
echangf30
Drives: 14' F30 MSport 335xi
So has anyone tried the leds in the fog lights? Does it work by itself without resistors?
Im so curious.
thanks
      04-01-2013, 04:13 AM   #114
rustyminded
rustyminded's Avatar
175
Drives: BMW 328i
Hey Svache, I've been looking for these I already got front LED but I need rear turn signals, brake and reverse if you could help me with numbers of each light and if the rear signal same as front turn signal and please post me how to change the back cuz when I open the trunk I hit this metal piece and a spring for the trunk i can't change anything or reach the bulbs... helpp ??
      04-01-2013, 04:30 AM   #115
rustyminded
175
Drives: BMW 328i
lol those are the ones I have on order for my brake lights. The ones I have for my tails have 42 LEDs and are bright enough but figured it wouldn't hurt to add some extra LED's for the brake lights
Can I order this for brake and turn signals ? are they the same size ?
      04-01-2013, 09:41 AM   #116
rustyminded
175
Drives: BMW 328i
ok guys I went down to my car got my 18 smd tried it on front signals, rear signals and brakes and it matches and works perfect !! so I did some search on ebay and found 120 SMD and 68 SMD for who's interested each got (white, amber, red)
120 SMD :http://www.ebay.ca/sch/i.html?_from=...56+120+smd+LED
68 SMD:http://www.ebay.ca/sch/i.html?_nkw=1...at=0&_from=R40
      04-04-2013, 12:21 AM   #117
UndergroundEuros
Drives: 335I Alphina White
Hey guys we have all these LEDs in stock not 68smd and 110smd but we.have 27 smd but the led chips are much bigger so in reto respect it's much brighter than 68 or 100 tiny size smd chips.
We also have plasma which is much brighter. Contact is by pm and we will hook every one up.
      04-05-2013, 03:36 AM   #118
zaidhaque
Qatar
Drives: 328i Mineral Gray Sport Line
Hey rustyminded, just wondering if these were the same as the ones you got? It seems like your ones don't throw errors, but are we sure that these ones don't throw errors as well?
      04-06-2013, 08:19 AM   #119
rustyminded
175
Drives: BMW 328i
I had already the 24smd it works good in front signals ..then I bought 3 pairs of 68 smd 2 red and 1 amber and I live in Egypt so it's kinda risky weather they work or make error but i'm still waiting for shipment so if anyone tried the 68 I'd appreciate to hear feedback...
      04-06-2013, 08:28 AM   #120
rustyminded
175
Drives: BMW 328i
& I bought another from Germany for my F25, I will give you feedback on this too once it arrive
      04-08-2013, 03:19 PM   #121
Indoe
Drives: 2012 328i | Alpine White
Installed front corners. Had to file down one pin to make it fit, but works great! (no flickering or codes yet):
2 x 1156 7506 7528 Canbus error free 27 ed turn signal parking brake light Amber - http://www.ebay.com/itm/170810703945...84.m1497.l2649
Rear turn signals and brake lights still in transit. Will post the results once installed (expecting flickering):
Red 1156 P21W Ba15s 120 3528 SMD LED Brake Tail Fog Head Signal Light Bulb 12V - http://www.ebay.com/itm/390559833956...84.m1497.l2649
2pc Red 1156 Ba15s 42x 3528 SMD LED Stop/Brake Light Bulbs Pair 1619 1651 1680 - http://www.ebay.com/itm/350758179161...84.m1497.l2649
      05-07-2013, 07:04 AM   #122
rustyminded
175
Drives: BMW 328i
ok good news guys, I installed 68 SMD front, back signals and brakes NO flicker doesn't need any resistors work as charm !!! good quality for it's value, it costs just few dollars
      05-07-2013, 07:07 AM   #123
rustyminded
175
Drives: BMW 328i
      05-07-2013, 10:33 AM   #124
R12ax7
R12ax7's Avatar
63
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
Did we ever get an answer on this?
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      05-14-2013, 06:33 PM   #125
npgatech
npgatech's Avatar
Drives: 2012 BMW 335i
Talking
Please post some pictures!
      05-14-2013, 06:34 PM   #126
gerbs
woof
gerbs's Avatar
Drives: M6
Send a message via AIM to gerbs
Link where you got em?
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      05-18-2013, 09:10 PM   #127
JOE YOUNG
SEAL TEAM SIX
JOE YOUNG's Avatar
Drives: F30 330d Msport plus BSM M-PPK
lol ok ok..
Here's two pics:
And here is a video showing the difference between the LED (left) and bulb (right):
Is it just me because i thought the signals are not synchronized.
DON'T MAKE ME ANGRY!
      05-18-2013, 10:00 PM   #128
phx08
phx08's Avatar
Drives: MKV Jetta
Poster above me....it's because they aren't the same. One is a filament the other is a light emitting diode (LED) which has instant on/off characteristics...thus giving you the "not synchronized" conjecture.
To the OP for doing this.
In my MKV I had to solder in a resister to fool cold diagnostic check into thinking there was enough resistence so it wouldn't through a bulb out light....good stuff
      05-23-2013, 08:55 AM   #129
rustyminded
175
Drives: BMW 328i
In ebay search (1157 68 smd led "red,white,amber" ) just write in the end what color you want. and here is a link
http://www.ebay.com/sch/i.html?_odkw...d+led&_sacat=0
      05-23-2013, 09:02 AM   #130
rustyminded
175
Drives: BMW 328i
uploading a video..
      05-23-2013, 10:14 AM   #131
rustyminded
175
Drives: BMW 328i
uploading a video..
If you can't see it tell me
https://www.facebook.com/photo.php?v=10151493648548842
      05-23-2013, 10:18 AM   #132
4.8 E70
Montenegro
-44
Drives: Alpina B7
Has anyone tried these bulbs out ?
http://autolumination.com/1156_1157.htm
50 Watt Cree Eagle EYE SMT Tower
