BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Towing with a 328i
      06-13-2012, 11:30 AM   #1
glitched79
Drives: 2012 328i
Towing with a 328i
Maybe this is a silly question...
I know it's frowned upon, but is it possible to tow a SeaDoo-type jet boat with a 2012 328i?
I'm sure the engine is powerful enough to pull it. I guess the bigger question is can the car's frame support a class 2 trailer. And are there even any class 2 trailer hitches available for the 328i?
The gross trailer weight would be just under 3,000lbs for the smallest SeaDoo jet boat, which is all I'm interested in towing.
Let's have an honest discussion about the capabilities of our 328s.
      06-13-2012, 01:45 PM   #2
SomeRandomer123
SomeRandomer123's Avatar
England
232
Drives: F30 328i Luxury - Sport Auto
The maximum towing weight should be listed in the spec.
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      06-13-2012, 02:36 PM   #3
chrisny
Drives: '15 550xi M Sport
Not just about towing capacity, think about the drag on the car and don't forget it's a 4 banger now.. I'm sure a jet ski is fine but I would guess a jet boat is pushing it.. But i would talk to your service department about it.
      06-13-2012, 04:30 PM   #4
svache
svache's Avatar
Drives: 2012 F30 328i
I doubt 3000 lbs is going to be a problem for the 328i, I towed more with lesser cars.. What's more important is if the hitch is capable of doing this.
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      06-13-2012, 04:41 PM   #5
SomeRandomer123
England
232
There is ABSOLUTELY no worries about the engine's capability. The number of cylinders is irrelevant, especially when it has more power and most importantly, more torque than the old 6 cylinder 328i.
The Auto Box though, will it need to be driven in manual mode perhaps? How much stick can it take?
      06-13-2012, 07:08 PM   #6
CirrusSR22
I'd first contact a UK member of the board and have them give you the max towing limits in their owner's manual. I haven't seen towing limits listed in the US versions for decades.
The two limiting factors will be:
#1 The tounge weight. Most BMW cars are limited to 75kg (165 lbs). Weight the tounge of your trailer to make sure you will be under that. If it's over by much at all I'd just forget it.
#2 The max UNBRAKED towing limits of the F30 will not be close to 3,000 lbs. It will probably be in the high 1,000 lbs range (maybe 1,600 -1,800 lbs.). But, the BRAKED trailer limits will probably be in the 3,500 lb range. Even my 138 HP/ 138 FT-LBS E36 318ti has an BRAKED towing limit of 3,306 lbs. You will need to add trailer brakes if you want to meet this limit.
And for the hitch itself, the US made ones (u-haul, Curt, etc..) are mostly class I, as you've probably seen. You might need to order a real Euro hitch (Westfalia, Witter, Bosal, Thule, etc.) to get the max towing capability. Check their websites for limitations on their hitches. For example, Westfalia has F30 hitches in their online catalog but they don't list max weights, yet. But, their E90 hitches in both fixed and detachable versions have max limits of 165 lbs tounge (75 kg) and 4,000 lbs trailer (1,800 kg). That will do the trick.
You can buy euro hitches at http://www.pfjones.co.uk. They will ship to the US for about $220.
I've towed with my 318ti for many years and find it very useful Here's my 5x8 Aluma that puts any SUV to shame. When things are too big for the family Suburban, we use this (and get better fuel mileage than the Subruban could get) Good Luck!
