BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Wheel compatibility between E90 and F30?
Extreme Power House
      09-28-2012, 05:39 AM   #23
getman3d
Drives: bmw f30 320d
I'm going to buy E90 bolt (36 13 6 781 150 M12x1.5) to compare it with mine F30 (36 13 6 781 151 M14x1.25)
      10-02-2012, 12:58 PM   #24
getman3d
Bolts are really different: F30 - Left, E90 - Right. IMHO the rims are incompatible...
      10-02-2012, 02:15 PM   #25
remmib
remmib's Avatar
Norway
1145
Drives: 2013 F10 520d M-Sport
Originally Posted by getman3d View Post
And what about the angle of the "cone" of the bolt? There can be free play of the rim...
Attachment 758732
Nice pic to show the differnet size of the M14x1.25 and M12x1.5 bolts.
At least the angle of the cone seems to be the same and the holes of the e90 wheels are large enough for the f30 bolts so I still think it should work.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      10-02-2012, 04:29 PM   #26
E46M54325Ci
E46M54325Ci's Avatar
286
Drives: The Root Beer Float
I tend to agree- the angles look the same
The Root Beer Float - 2017 230i, Sparkling Brown on Oyster, ZTR, ZLP, ZCW, 2TB...Completed October 2016 ED...http://www.2addicts.com/forums/showthread.php?t=1315020 Redelivered December 2016!
Nurburgring Training! http://f87.bimmerpost.com/forums/sho....php?t=1417300
      10-03-2012, 06:08 AM   #27
getman3d
I've measured it in Photoshop = 60 degrees. The same.
      01-09-2013, 02:45 PM   #28
carlosalbertogui
Drives: bmw E91 facelifted by me
397 whells will work on E90 / E91
hi all
iam pretty sure that 397 whells will work on E90 / E91
they are Et 34
My concern is about 400M the rear ones are ET 47 !!!!!
what do you think ??
Wheels: Wheel 1 Wheel 2
Wheel size 18x8.5 ET 37 18x8 ET 47
BackSpace 157 mm (6.2'') 161 mm (6.3'')
3 mm (0.1'') deeper.
Rim Lip 17 mm (0.7'') wider
Typical Weight ~ 28 lbs / 13 kg ~ 26 lbs / 12 kg
Tires: Tire 1 Tire 2
Tire size 255/40-18 225/45-18
Section width 255 mm (10'') 225 mm (8.9'')
Sidewall 102 mm (4'') 101 mm (4'')
Tire diameter 661 mm (26'') 659 mm (25.9'')
2 mm (0.3%) shorter.
Rim sizes 18x7.5 to 18x9.5 18x6.5 to 18x8.5
Circumference 2076 mm (81.7'') 2069 mm (81.5'')
Revs per mile 775.4 777.7
Speedometer Assuming that this is OEM tire and speedometer readings are correct >>> When speedometer reads 60mph (96.6km/h) actual speed will be 59.8mph (96.3km/h): 0.3% slower.
Typical Weight ~ 25 lbs / 11 kg ~ 23 lbs / 10 kg
Wheel+Tire Weight ~ 53 lbs / 24 kg ~ 49 lbs / 22 kg
Clearance: Package 1 Package 2
Suspension Assuming that this is OEM wheel/tire and there is no any problems with clearance on both sides >>> 100% clear (leaves even more room than OEM)
Fenders 100% clear (leaves even more room than OEM)
Wheelwells The same.
      01-09-2013, 02:55 PM   #29
remmib
remmib's Avatar
Norway
1145
Those ET47 wheels will fit on e90, but will look really tucked, so spacers are kinda needed.
      01-09-2013, 04:18 PM   #30
HighlandPete
Drives: BMW F11 535i Touring
Originally Posted by E46M54325Ci View Post
I wonder about that too.
Yes, cone angle (taper) is the same on both 12 & 14mm studs. Have physically measured the angle and placed 14mm studs in each rim type.
HighlandPete
      01-17-2013, 01:40 PM   #31
R12ax7
R12ax7's Avatar
63
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
Glad to see some traffic starting to pick up on F30 post. This thread seems the most comprehensive on what I expect to be an ongoing conversation (maybe worth making it a Sticky?).
I am currently running 189s as my winter set-up for my e90. I will be ordering an F30 soon (likely Msport/RWD, possibly Adaptive M suspension). From what I have read on this thread it sounds like:
1. I will have no problem mounting the 189s on an F30, but I will have to use the F30 bolts.
2. The front will fit perfectly fine but the rears will be a bit pushed out.
(Please correct me if I am wrong on those!)
3. My question is, with the lower profile tires on the 189s, I suppose there will be more of a wheel well gap, but is there any other negative consequence of having the "incorrect" profile ratio? Incorrect speedometer reading? I guess logically you have less rubber so could there be increased risk of damaging the rims on a pothole or bottoming out in general? Not that I had planned on it but I assume dropping it would increase any of these possible issues. Does anyone know if the M adaptive suspension is any lower than the standard Msport?
Appreciate any input!!
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      01-18-2013, 03:01 AM   #32
vigalent
Drives: F30 318D
For all those interested, I've replaced my 397's with my old 156 style alloys for winter on my F30.
They fitted with no issues, albeit there's not alot of room round the calliper.
      01-28-2014, 09:04 AM   #33
DavidV
Drives: BMW F31 320d
hi, any pic of a E90's 17" on a F30?
I'm considering move from the stock 16" to a 17", the E90's ones are considerably cheaper than the f30's, also the profile in 45 instead of 50 allows a better price for the tires
      01-28-2014, 11:01 PM   #34
BMW Lawman
Supreme Commander of Allied Forces
BMW Lawman's Avatar
Drives: 2012 335i Sport
Originally Posted by adamsclubs View Post
The above posts both seem to say it is fine to put F30 wheels on E90 cars, but what about the other way around?
I have a set of Forgestar F14 wheels custom made for my 11' 328i, if they can go on an F30, that will make me more inclined to get an F30 in the future.
The F14 wheels do need hubcentric rings, but I don't think this is an issue, I am more concerned about the bolts fitting through the wheels. The F14s require thin wall socket to install the lugs.
And of course the offsets. My front is 18X8.5 E32, rear 18X8.5 ET26. What do you guys think?
Taller tires should not be an issue.
And one more thing, is it true that the F30 with M-Sport will have larger disc brakes even for the 328i? Is this true for the E90 also or it is new for F30?
I put my E90 VMR VB3(V703), 19x8.5 235/35R19 and 19x9.5 275/30R19 wheels and tires onto my F30 and they looked ridiculously small. The offset was really bad in the front and better in the back, but the tires looked tiny and the extra room in the wheel well was cavern-like. Admittedly, the tread was pretty well worn on the old E90 set, but still
      12-14-2016, 12:39 AM   #35
nlphe
Drives: 2006 330i sport/winter package
Originally Posted by Feanor View Post
Thanks.
I'm a bit puzzled about the offsets being different though - I thought they had to be the same?
Or do the offsets differ depending on the wheels that the car comes with? To be honest though I don't really understand what the offset measurement really means.
Regarding the mounting specs, it sounds like you're saying that the info on the website is wrong?
As for the tyres being taller, do you mean the profile is bigger? IE the /xxR figure? (eg /45R or /50R)
The offset is the distance of the vertical centerline to the mounting flange. ET comes from the German term "einpresstiefe" or freely translated "impressed depth". A smaller measurement (in mm) results in a wider track. So on a staggered setup, the wider rear rim typically has a greater ET to keep the outside of the rim more a less in line with the front.
      01-06-2017, 11:29 AM   #36
R12ax7
R12ax7's Avatar
63
2011 328i  [0.00]
A little update from my post back in 2013. I actually ended up swapping the summer/winter tires between the 189s and 193s and turned in my e90 with the 189s switching the 193s to winter use - which ended up being a bad idea, since the tire place ruined a couple of the tires in the process.
Anyway, I ran the 193s with the incorrect aspect ratio for three winters with no real issues. Of course the speedo was about 5 mph off and technically the odometer has some phantom miles on it, but it worked for a couple months of the year. The only issue i ever had was that the traction control calibration was a bit off and i did have some ground clearance issues, but i was on Dinan springs and i think i would have been fine if i didnt drop it.
Now I am in a 2016 340 with the Track Handling Package, which has brought a new problem. It turns out the front Msport calipers just barely scrape the inside of the 193s. I mean we are talking 1, maybe 2 millimeters. I may just file down the edge of the calipers a bit or i have a friend with a lathe who said he could probably make a small channel in the wheel, but just a PSA for those with the Msport brakes. Sorry for the terrible cell phone pics.
      01-06-2017, 04:29 PM   #37
ouengineer
Drives: 2015 335xi, 97 Silvia
Ah, bummer. The 193 is a good looking wheel for winter use.
      09-25-2017, 11:35 AM   #38
850CSi
VALVETRONIC I6
850CSi's Avatar
Drives: '06 325i 6MT
Send a message via AIM to 850CSi
I'm thinking of putting style 393's on our E61 wagon. wheels would fit really well (just stick out 6mm more) -- but I'm dumb -- can someone tell me what the deal is with the bolts. Would I just use the 5er bolts (which are same as my E90's) on the F30 wheels? Looks like from the picture above that'd probably work just fine?
E90 325i 6MT + E61 530xiT 6AT = N52B30*2
      11-27-2017, 03:52 PM   #39
613328i
Drives: 07 328i
Sorry if this is in the wrong thread. New member here:
2007 328i (225 45 17 tires)
If anyone can help me, I'm looking at a set of used winter tires on rims. They are 205 55 16 Nexen Winspike.
The person says they are off a 328xi 2009 or 2011. I asked if it was a 2011, was is the e90 or f30 and they weren't sure as the car was totaled and there are no records.
I have 3 questions:
1 - Will rims off an xi fit an i
2 - Will f30 rims fit e90
3 - Will 16" rims mount up without issue. (I know some of the 3 series come stock with 16" just want to be %100 sure)
Any help would be greatly appreciated guys, and sorry again if this is in the wrong thread, still trying to figure this forum out.
      11-27-2017, 06:01 PM   #40
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
Originally Posted by 613328i View Post
I have 3 questions:
Yes
Yes (but not tires!)
Probably (no if F3x has MSport brakes)
      11-28-2017, 04:15 PM   #41
613328i
Drives: 07 328i
Would a pair of 235 45 17 Blizzaks fit on my stock 17"s
I know it's best to go thinner but there for a good price.
Would 10mm wider cause issues?
      11-28-2017, 04:24 PM   #42
floydarogers
Check the specs tab on tirerack.com on the tires - wheel width is one of the specs.
      12-22-2017, 11:04 AM   #43
Littlebear
Littlebear's Avatar
Drives: 2017 330i
Hello BMW Experts!
I just tried to put my old E46 SSR wheels on my '17 330i. All looked good until I tried to put the F30 M14 lug bolt through the wheel hole:
F30 Bolt diameter is too big for this wheel!
Murf
      04-06-2018, 05:26 PM   #44
850CSi
VALVETRONIC I6
850CSi's Avatar
Just bumping for this question if anyone has any insight -- I shouldn't have a problem putting the 5er's M12x1.5 bolts through the F30 wheels, right?
