BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 335i 8at sport+ = fully manual
      06-15-2012, 08:59 PM   #1
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
I found out accidentally that on sport+ and in manual mode the tranny will not shift for you and the car just bounces on the rev limiter until you shift manually.. Also the kickdown button does nothing and it will stay in the gear you choose. Im really impressed and happy because I feel like I have so much more control. The whole forum might already know this but I had no idea. In regular sport the kickdown will take over and Im not sure if it will switch gears itself if you hit redline and dont shift. Just wanted to post this for those of you that didnt know this. have fun.
2015 M3 Alpine white, shakir orange
carbon roof, black 19's, lighting, executive, HK
side&top view, adaptive susp, mods to come......
      06-15-2012, 09:32 PM   #2
bosz
bosz's Avatar
53
Drives: F30 335i Ordered
And what happens if rpms r too low?
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
      06-15-2012, 11:57 PM   #3
RPM90
Drives: 340i M-sport AT
That's cool.
Wonder why that doesn't happen in "sport" mode.
I believe sport+ is sport plus DTC on.
While in sport mode and in manual mode, the trans will up shift at red line? But, only at red line and not before, right?
Auto kick down is also active in sport with manual mode?
      06-16-2012, 12:10 AM   #4
kon
Singapore
Drives: F30 316i
Originally Posted by RPM90 View Post
That's cool.
Depends on much one step on accelerator, normal driving:
Comfort mode: Shift at 2,000rpm
Sports mode: Shift at 3,000 rpm
      06-16-2012, 12:26 AM   #5
FotiosF80M3
It has gone lower than I've seen. I've had it very low and still kick down did not interfere. You have to pay more attention for sure. If you forget it does it you can rev it too high and for too long. Fully manual. The car is getting faster and faster. Coming from Procede n54 I'm still very impressed with the car with this tranny.
      06-16-2012, 12:30 AM   #6
FotiosF80M3
Auto kick down is also active in sport with manual mode?[/quote]
Sport will shift at full redline even in manual. Kick down also takes over. Not in sport + though.
      06-16-2012, 03:12 AM   #7
clarence
Drives: F30 328i M-Sport
It'll only change down 1 gear at a time if the revs are so low that' it'll stall.
      06-16-2012, 03:00 PM   #8
's Avatar
73
Drives: ✚
+1 I can confirm that Sport in Manual mode will automatically up shift at redline. It will not up shift sooner. It's like a failsafe for your transmission. Haven't tried it in Sport+... but now I'm curious.
By kick down, I'm assuming everyone means down shift. It will auto down shift to prevent stalling. The downshifting is really smooth. Again, I'm not sure about Sport+... but I believe it auto downshifts for you in Sport+ as well.
      06-19-2012, 11:39 PM   #9
FotiosF80M3
What I mean by kickdown is that extra pedal travel past the resistance click. If you push the pedal past the resistance it will downshift to the lowest gear for the rpm's as possible. It will not do this in sport+. Beware in sport plus not to blow your engine because it will not shift. I'm still sometimes forgetting and shifting too late.
      06-20-2012, 02:44 AM   #10
's Avatar
73
Drives: ✚
I see what you mean now. Yeah, I forget to shift sometimes too. But slowly I'm getting used to it. It gets confusing for me when I drive my manual car now. I sometimes try to paddle shift, when no paddles exist. I think in about a month, it'll be 2nd nature on both cars.
      06-20-2012, 02:58 PM   #11
jeanchristophele
jeanchristophele's Avatar
Drives: E93
Fun news! Gearing back towards an auto car now =]
      06-28-2012, 04:05 PM   #12
RPM90
You still won't blow the engine though.
There is a rev limiter that electronically prevents the engine from going past it's true built in rev limit. On accel, at red line, it will just bounce as the rev limiter kicks in.
In an AT the ECU won't let you select a gear that's too low, such that will the gear will cause the rpm's to go beyond red line. That's a mechanical type of over rev, and in the MT world that's called a "money shift".
      06-28-2012, 07:58 PM   #13
FotiosF80M3
well, thats a good thing for those extra forgetful days. thanks for the info..I was wondering about that.
      08-09-2012, 01:14 PM   #14
littleE92
Douche in Training
Drives: 2011 335xi e92 6AT m-sport
I traded in my previous car (which was 6MT) for a 6AT e92. One of my biggest complaints since have been with the 6AT shifting at redline for me.
Knowing that the F30 will not shift for me at redline in Sport+ will definitely make me look at the new 4-series in 8AT when it comes out instead of moving back to a 6MT(which I enjoy but do not miss during rush hour)...
2011 335Xi E92 Le Mans Blue 6AT M-sport with Exec and Nav package
      08-15-2012, 09:15 PM   #15
FotiosF80M3
What if your power sliding the car (which the f30 does very well with a tune especially ) and want to stay at the end of redline?. not shifting for you makes you have more control. More like a manual but with added convenience of an auto. If we want a fail safe just put it in sport.
      08-18-2012, 03:50 AM   #16
daxtor
Drives: EBII F30 335i
If you track your car, you'll appreciate the transmission obeying everything you tell it: i.e. not up shift unless I tell it to. Sometimes I find the transmission shifting at the wrong time (say while I am negotiating a turn) and it can upset the car's balance. Or, it would up shift too early while I still want it to stay in lower gear for greater acceleration.
      08-25-2012, 09:06 PM   #17
RPM90
The N55 produces the majority of it's torque well before red line.
If you want to kick the rear end out and power slide, select a gear that will put you around 4k rpm, then depending on you good you are at initiating the slide you'll have plenty of torque and plenty of rpm to keep the rear tires spinning.
By the time the engine is around 6K most of the torque is way down, so trying a power slide near red line isn't the best approach.
You're right, the 335i kicks out the rear nicely in sport+ mode. At a modest 30mph I got the rear to come out very controllably.
      08-26-2012, 02:38 PM   #18
ScheerSpeed
ScheerSpeed's Avatar
Drives: '13 F30 Estoril M-Sport 335i
Send a message via AIM to ScheerSpeed Send a message via MSN to ScheerSpeed
I figured this out when I was driving on the nurburgring!
      08-26-2012, 11:17 PM   #19
FotiosF80M3
I just hate when my foot unintentionally goes down too far (like my e90 did) when I'm sliding and shifts. It puts an end to it usually. I'm just happy we have a choice and this tranny is so performance oriented
I also think when dsc is completely turned off you have to shift yourself in manual FYI.
      08-26-2012, 11:21 PM   #20
FotiosF80M3
Oh boy....lol. Sounds so fun btw.
      09-09-2012, 08:13 AM   #21
Ermagerd
Ermagerd's Avatar
Drives: a huffy
I didn't know that, pretty cool!
      12-25-2012, 02:59 PM   #22
FrankiE90
FrankiE90's Avatar
Drives: Krooked Sk8board
Send a message via Skype™ to FrankiE90
fotios335i just remember not to do the money shift.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) KW clubsports 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
