BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Flat with runflats
Vorsteiner
      06-17-2012, 05:15 AM   #1
Bmwphile
Australia
23
Drives: 2012 F30 328i Auto
Flat with runflats
Have any of you experienced a flat with the runflats?
Does it feel different to a conventional flat?
In fact, did any of you have a flat and not realize it for awhile? LOL
BMWphile
2012 F30 328i Mineral Grey, Auto, Sportline, Sunroof, BiXenon, Headlight washers
      06-17-2012, 05:31 AM   #2
CasZy NL
CasZy NL's Avatar
Netherlands
Drives: M4 | X5 | Z1
2008 BMW X5 35d  [5.00]
2015 BMW M4  [5.00]
1991 BMW Z1  [5.00]
Two years ago a had a flat rear wheel tire. Initially I did not even notice the difference, besides the car showing a warning. I pulled over to see what was wrong. Very hard to see the difference.
You can almost drive like normal with a flat.
      06-17-2012, 06:45 AM   #3
spark58
Drives: BMW 320d
Yes. It's happened twice to me. I seem to have a knack for getting punctures! The good news is car handles exactly the same. The bad news of cause it that you can't repair the tyre even with a minor puncture because the act of driving on it writes it off. You are also only meant drive on a 'flat' for 250 km (155 miles) and at the same time also reduce your speed to 80 km/h (50 mph). It is really easy to forget about reducing your speed because the car doesn't handle any differently.
The only other thing I noticed was the tyre which was 'flat' got incredibly hot after driving only 30 km (19 miles), so hot that you if you had touched it it would burn you!
      06-17-2012, 08:28 AM   #4
Thekop5
I had a flat not too long ago. Only thing to tell you is the run flat warning in the car. Would not know which is one has problem until you pump in the air. So now I carry a pressure gauge in the car to check!
      06-17-2012, 08:37 AM   #5
dmontic71
dmontic71's Avatar
17
Drives: 2012 F30
You will never get stranded, but they are expensive!
2012 F30 328i, Melbourne Red, Premium, Sportline, Steptronic, Xenon, Harmon Kardon.
      06-17-2012, 12:09 PM   #6
aarslan
Turkey
Drives: BMW 3.20i 2012
Can a flat run flat tire be repaired? Or do we have to change the tire altogether?
      06-17-2012, 05:00 PM   #7
's Avatar
61
Drives: ✚
Some say that minor non-sidewall punctures are repairable. BMW says no puncture is repairable.
      06-17-2012, 11:20 PM   #8
kaujong
Drives: BMW 328i 2013
Can we change just the tires with regular tires while keeping the rims?
      06-18-2012, 01:26 AM   #9
huskercubfan
STM TRPR
Drives: 2012 335i MW
This is why you spend the sub-$500 (negotiated) on the 5 year/50,000 mile tire and wheel protection.
      06-20-2012, 06:19 PM   #10
jgrasty
jgrasty's Avatar
Drives: 2012 BMW 328i
2012 BMW 328i  [0.00]
I had a screw in the tire of my F30 328i a few weeks ago. It was a slow leak and I never noticed a difference, even after the TPMS alarm went off. I drove slowly to a gas station, filled up with air (tire was at 25 psi), then drove home. The next day, the air was low again, about 25 psi, and took it to the dealer, where a screw was removed from the tire and, fortunately, repaired and not replaced.
      06-20-2012, 06:22 PM   #11
jgrasty
jgrasty's Avatar
Some run-flats are repairable, some are not. Pirelli P7 Cinturato All-Season run-flats can be repaired.
      06-20-2012, 09:31 PM   #12
RASHID007
Drives: 2014 535d X-Drive
Can the summer version of the same Pirelli be repaired?
      07-05-2012, 06:43 PM   #13
jgrasty
jgrasty's Avatar
Probably, but you'll need to check with either Pirelli or your BMW service dept.
      07-10-2012, 01:04 PM   #14
CESIUM
Drives: 2013 X3 35i Msport
What if you purchase the warranty the day you get the flat? Will it still work? My dealership let me buy it after the fact (25 days) and I now have a ruined tired. THe analytics will show the warning came up prior though I am assuming right?
      08-15-2012, 06:37 AM   #15
tmehanna
Drives: 528i f10
As far as I know, RFTs are as repairable as any tubeless radial. The trouble is if you drive on it while flat you are consuming the "run flat" rated mileage. So I am assuming if you fix it as soon as the flat is detected, it should be ok. Please note however that any fix, even on a tubeless radial, be it a patch or a plug or both nullifies the speed rating of the tire.
      08-24-2012, 12:06 PM   #16
JUSKIDN
JUSKIDN's Avatar
Drives: 2013 EBII 328i M Sport
very interesting.......I think I would rather have regular tires and a spare
It's not illegal. It's frowned upon, like masturbating on an airplane.
      09-01-2012, 07:28 PM   #17
L0UD0G
Drives: 2012 328i Sport
I bought my 328 on August 12th and I just had to have my passenger rear tire replaced this morning... $429 later... And that's with a discount they gave me because they felt bad!
Here's a picture of the bolt that somehow found it's way into my brand new tire...
I'm now looking to buy a set of wheels with normal tires and store the stock ones for when I go to turn the car in!
      09-03-2012, 11:35 AM   #18
Kaitain
Drives: Estoril Blue II F30 M Sport
I hate to tell ou this, but even if you had a set of non run flat tires, you would have had to replace that tire. The bolt was on the inside edge of the tire, and is not able to be properly repaired. The outside edge is also susceptible to this. It is called bad luck. I had this happen to one of my tires, and I had to replace two of them since they were not brand new, and the wear would have been felt in the steering. So, be happy it happened early, if it was going to happen, since it cost you half as much as it could have.
      09-03-2012, 11:42 AM   #19
L0UD0G
I know I would've had to replace it regardless, but I would rather have replaced a normal tire than a run flat. It is bad luck and I am fortunate I was able to just purchase one. I'm still looking to replace the run flats with a set of normal tires and then put the run flats back on before I return the lease.
      09-03-2012, 11:46 AM   #20
fshubert
fshubert's Avatar
84
Drives: 2015 F30 335i
I had 3 tires and 2 wheels replaced by BMW on my 2009 335i. Thank God for wheel/tire insurance. But they said they could not fix the run flats. It was always a replacement.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
