BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 328i with H&R Super Sport Springs and AP 7040 wheels
      07-05-2012, 06:57 PM   #23
gerbs
woof
gerbs's Avatar
Drives: M6
Send a message via AIM to gerbs
Originally Posted by bosz View Post
Size : 19 x 8.5 (F) & 19 x 9.5 (R)
Offset : 35mm (F) & 38mm (R)
Would also like to know the fitament for this possible config ^
According to the pics here, a 38 rear offset would be a bit more set in in the front and rear, correct?
It's weird, because I was under the impression a 35 rear offset with 19x9.5 would stick out very far, but these don't seem to stick out much at alll? Weird angle? Someone in another thread said "Today I tried on 42offset an about 3mm was sticking out." and he was referring to an F30, so I dunno..
The optimal offsets were 35-38 front, 42-45 rear for a staggered setup.
19x8.5 ET35 squared setup works well.
But for staggered 19x8.5 | 19x9.5, you need 35 front, 45 rear.
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      07-05-2012, 09:17 PM   #24
onehungevo
Drives:
19x9.5 40 offset with 255/35/19 fit. I would think a 19x9.5 38 offset with 265/30/19 will work. It's going to be close but that is the size and rims I just ordered. Wish me luck.
      07-05-2012, 09:20 PM   #25
onehungevo
Drives:
I believe the 38 offset was on a 19x10 rim.
      07-05-2012, 09:49 PM   #26
rayzoe1306
Drives: F30 328i
Can some one tell me if the rims above offset are more or less aggressive than rims with the same tires as above BUT the following widths/offsets:
Front wheel should be more aggressive. If I can choose again, I will choose 9.5j with ET30 or smaller
      07-05-2012, 11:28 PM   #27
onehungevo
Drives:
Just go with some spacers.
Can you post a side shot.
      07-06-2012, 07:26 AM   #28
KSAF
Speed Demon
KSAF's Avatar
Saudi Arabia
Drives: The Ultimate Driving Machine
They are more aggressive than the ones you've listed. The lower offset you go with, the more it will stick out. The higher offset you go with, the more it will sit in.
I agree.
Anyone can drive a fast car, but few can drive a car fast!
      07-06-2012, 10:58 AM   #29
F555
F555's Avatar
Indonesia
26
Drives: F30 - 335i
U should get 9.5 up front & 10 on the rear.
