BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Rim/Tire Setup Questions
Extreme Power House
      07-03-2012, 10:00 AM   #1
martinf79
martinf79's Avatar
62
Drives: F30 335i M Sport
Hi All – I have a couple of questions on a rim/tire setup. I have a MY2013 M Sport on order coming w/ the following setup:
  • 19.0x8, 225/40 R19 Front
  • 19.0x8.5, 255/35 R19 Rear
This gives me a stock diameter of 26.1” for the Front and 26.0” for the Rear.
I was originally thinking of going w the following setup for winter: 18.0x8, 225/45 R18 all the way around (total diameter of 25.9”) as I’ve been told a thinner tire is better for winter driving and non-staggered is also better.
That said, I really want to maintain some level of aesthetic appeal in my winter setup.
So here is what I’m thinking, and please chime in if you can:
I want to go w/ a 18x8.0, 245/40 R18 all the way around (non staggered setup). This would give me a total diameter of 25.7”. I realize this is slightly wider than stock up front, and slightly narrower in the back, but at least it will be non-staggered and I can rotate the tires around.
Here are my questions:
1 – Should I be going w/ an 8.0” or 8.5” sized rim (any issue going w/ a wider rim up front vs. stock)? Added weight? 245 wide tire can fit a 8" rim (8-9.5), so what rim size is best?
2 – Is there any risk of rubbing w/ a 245 tire up front (I’ve seen others do it, so just need to know for sure?)
3 – Any major issues w/ a 245 vs. 225 width setup for winter driving? Any “red flags” (as I can’t see 2 cm added width making that much of a difference).
Would love to hear everyone’s thoughts.
2013 335i ///M-Sport | + 2015 X3 28i xLine
      07-08-2012, 01:42 PM   #2
martinf79
martinf79's Avatar
62
anyone???
      07-09-2012, 09:55 AM   #3
martinf79
martinf79's Avatar
62
ANyone????? Looking to folks that know their rims/tire setups?
      07-09-2012, 11:10 AM   #4
remmib
remmib's Avatar
Norway
1154
Drives: 2013 F10 520d M-Sport
For 18" winters, I'd go with 225/45/18, don't see what would be better with 245/40/18.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      07-09-2012, 11:21 AM   #5
Road Cone1
Road Cone1's Avatar
17
Drives: 135i & 325i
Thinner is better for winter.
8.5" won't be an issue.
Google tire calculator to see you're overall circumference.
Won't be an issue as long as its close.
2012 White 328i Sportline
2009 135i Silver w/Black (Sold)
2006 325i, AW & BLack, ZSP (Sold)
Lots of Miatas
      07-09-2012, 11:39 AM   #6
martinf79
martinf79's Avatar
62
I've seen a few F30 Sports on the road w/ 18s (non staggered) w/ 225 setup all the way around, and the tires are WAAAYYYY too thin from the back. Car doesn't look right. I figured if I go w/ 245, I'd get a much better look that I can stilol rototate. Thoughts?
