BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Issue with HID"S in fogs
VIBE Motorsports
      07-03-2012, 10:16 AM   #1
DR.Nefario
DR.Nefario's Avatar
64
Drives: 2013 Dakar Yellow M3
I installed some 6k HID's to match the angel eyes and they have been intermittently flickering and even cutting out. I'm not sure if it's an issue with the car or the lights. They seem to do it more when there is an electrical draw on the engine such as using the power steering, but have flickered while just sitting idle. Anyone else run into this issue?
      07-03-2012, 03:12 PM   #2
200Duece
200Duece's Avatar
20
Drives: '73 2002,'12 X5 35d,'03 540iT
I haven't had a problem with mine. running my old DDM 6000k with big ballast from my E90. I only run them at night with the xenons on. Are you running the "error code cancel" resistors ?
1988 E28 535is Euro Conversion --- sold
2009 E90 335 6MT --- sold
      07-03-2012, 03:13 PM   #3
UndergroundEuros
Drives: 335I Alphina White
that is because the ballast you are running is not the right one for that car.
We just did the 1st f30 car in south Florida and It worked great!
We sell the kit for $120.00 and you will have no issues at all!
here is some pics of the fog lights, and we did HID Head Lights and LED City light bulb! Sorry not the best pics yet but it will do!
      07-03-2012, 03:17 PM   #4
200Duece
200Duece's Avatar
20
[quote=****************;12262412]that is because the ballast you are running is not the right one for that car.
QUOTE]
pretty sure it's not the BALLAST.
      07-03-2012, 03:22 PM   #5
UndergroundEuros
[quote=200Duece;12262440]
QUOTE]
It is for sure, if i am understanding right that the bulb is flickering and not staying on.
its takes a bigger ballast with a higher canbus system to make it to work and stay on with no codes.
      07-26-2012, 01:59 AM   #6
DimSum
Drives: SLOW
Get some error cancellers from eBay or locally and it should fix the flickering issue.
      08-30-2012, 03:41 PM   #7
turtle335
Drives: E92 335i
I am pretty sure that your Hid ballast votage does not match your car and your canbus hid ballast does not work great on your car. Replace your ballast or try a relay harness that will be fix flicker problems.
      08-31-2012, 11:16 PM   #8
Ecmiyake
Drives: 2012 320i
the parking lights require canceller too? i've replaced the parking light with LED on my 320i, and it kept telling me that my parking lights are malfunction. I think for this specific reason, when my light switch is turn to automatic, the headlight is on even during the day. any fix? thanks in advance.
      12-04-2012, 03:55 PM   #9
DR.Nefario
DR.Nefario's Avatar
64
Does anyone make just the "error code cancel" resistors for the F30 or do i have to replace my entire set-up ?
      12-07-2012, 01:21 PM   #10
jose_sonictuning
jose_sonictuning's Avatar
Drives: BMW F30
All you need is the error cancellers go inline with your ballast.
Your canbus system is seeing different resistance from the HIDs you installed, thats why you are getting the flickering and shut off error.
      12-11-2012, 08:31 AM   #11
Vitoco
Infidel
Vitoco's Avatar
Sweden
53
Drives: F31 328i M Sport
What kit did you get, where from? Would be easier if you could share this info
Glacier Ag. F31 328iA RWD M Sport oct. 2012
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
