BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19x9.5 38 offset 265/30/19
      11-28-2012, 11:38 PM   #67
cheukmc
Drives: F30 335i
Thanks for your quick response!
What do you think if I get
Front 225/35/19
Rear 255/30/19
tires instead? slightly camber adjustment will fix that?
      11-29-2012, 01:12 AM   #68
ric124
ric124's Avatar
Jamaica
392
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Originally Posted by cheukmc View Post
Wow, those look amazing! Very very nice ride!
Hi everyone, I'm planning to get new wheels for my F30 335, wondering if this will rub:
KW V2 coilover
Front 19 x 8.5 30et 235/35/19
Rear 19 x 9.5 35et 265/30/19
P.S. I'm new to this forum and thank you very much for your help!
Here is what I am running with zero rub.
H&R Sport with Adaptive M
Front 19x8.5 ET40 235/35R19XL
Rear 19x9.5 ET45 265/30R19XL
      11-29-2012, 08:42 AM   #69
mikew2069
mikew2069's Avatar
58
Drives: F30 335i MSport
How close are you to rubbing? I'm going 19x10 on the rear and im on the fence about tires. I really want to run 285/30 in the back. Do you have any wiggle room back there?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      11-29-2012, 11:39 PM   #70
etmathews
WARRIORS come out to play yay!!
etmathews's Avatar
Drives: 2016 F30 340i M Sport
I was hoping to use my forgestar F-14s from my E92 M-Sport.
19x8.5 et32 235/35
19x10 et38 275/30
Will this set up work on my F30 M-Sport?
2016 340i M Sport/Alpine White/Black Dakota Leather/Ash Wood Trim/ M performance carbon fiber spoiler, M performance grills, M performance front splitter, M performance carbon fiber mirror caps, Llumar ATX Axcess 30% tint
      11-30-2012, 04:41 AM   #71
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
omg...drool. so beefy in the back for a f30... would love to see someone photoshop this onto a black f30 or a black f30 with black m5 reps
      11-30-2012, 08:32 AM   #72
mikew2069
mikew2069's Avatar
58
19x8.5 et32 235/35
19x10 et38 275/30
Looks like you have your car and wheels already. Run out and do a test fit for us! That would help me SO much. But my guess is with that offset, the 275 might be a little wide. I'm only basing my assumption on what others of posted.
I have 19x10 Forgestar ordered hopefully in the +42-45 et range.
      11-30-2012, 11:22 AM   #73
jrob
Bimmer God
Drives: 2003 BMW 330i
Car looks amazing, F10 reps are probably my favorite on the F30 so far. Also interested in seeing what size tires/offsets will work with a 10-inch rear.
      11-30-2012, 11:34 AM   #74
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
This is what I've worked out... should work...
http://www.rimsntires.com/specs.jsp?...2=New F30 Rear
Relative to 18" M-Sport wheels, this setup will be
14mm/1.4cm more aggressive
4mm/0.4cm smaller gap
1in = 2.54cm
      11-30-2012, 12:17 PM   #75
mikew2069
mikew2069's Avatar
58
1in = 2.54cm
That calculator is awesome. I'm going to call Forgestar this afternoon and see what my offsets are. Are you sure that's the correct offset on the stock 18x8.5"?
I think youve sold me on the 265!
      11-30-2012, 01:22 PM   #76
jsedlak
jsedlak's Avatar
The only thing is that people are saying it's impossible to fit a 10, regardless of tire. Although we have seen a few cars with 10s - there is even one running 20x10 (though I'm sure he rubs since he has zero gap).
I got the stock info from this thread:
18" Double Spoke Style 400M (M Sport wheels) - 18x8" ET34 225/45-18 front / 18x8.5" ET47 255/40-18 rear
My only explanation as to why it will work is because the stock rims are 8.5 wide, but have an incredibly deep (from the car) offset because the concavity is shallow. It allows us to bring in the offset a lot while increasing the width of the wheel without moving the part that would hit the suspension.
      11-30-2012, 03:58 PM   #77
mikew2069
mikew2069's Avatar
58
Sweet, I'm feeling good about this. I just spoke with Forgestar and my wheels are 19x9 +35 front and 19x10 +45 rear.
My front setup will be 255/35/19. 0.6" closer to suspension and 0.6" more towards the fender. Should be plenty of room to occomodate 0.6" on both sides (I hope).
http://www.rimsntires.com/specs.jsp?...&text1=&text2=
My only issue now is the rear tires. If I go 265/35 in the rear, I'll be 0.1" closer to suspension and only 0.3" more towards the fender - no problem to fit.
But if I go 285/30, I'll be 0.5" closer to suspension and 0.7" closer to fender - could be cutting it close.
Seems like either would work. Also to factor in for me is that if I go 265/35 rear, I'm going with Michilin Super Sports. If I get 285/30, I'm going with Continental ExtremeContact DW.
Sorry, this is apparently my wheel diary.
      11-30-2012, 04:11 PM   #78
jsedlak
jsedlak's Avatar
For the fronts, you may want to shoot for a slightly lower offset or move to a 245. I wonder what the performance difference is between a 245 and a 255 on a 19" rim. I suspect the stretch of the sidewall has the potential to cause issues when cornering. FWIW, your front choice is essentially the same as mine. Link!
For the rears, 285 seems a bit too much. Try with a 275/35. Tire choice is somewhat odd on tirerack, but it would straddle the middle ground of 265/35 and 285/30.
Could also do 275/35/19 on a 19x10+42.
(This is all speculation and guesswork on my part, I have no background experience with aftermarket rims.)
      11-30-2012, 06:18 PM   #79
mikew2069
mikew2069's Avatar
58
I find it interesting that you said that "For the fronts, you may want to shoot for a slightly lower offset or move to a 245" considering we are going to be running the exact same wheel size and tire size. Only your wheel will be 1mm closer to the fender than mine?... I would like to call them and ask them to shave the front to a +38 offset but I'm not sure what the clearance will look like on the suspension.
The problem with the 275/35 tire is that its 26.57" diameter compared to 26" stock. 265/35 is 26.30" and 285/30 is 25.73". I'd like to stay as close to stock diameter as possible for the spedo and mpg calculations.
      11-30-2012, 08:03 PM   #80
etmathews
etmathews's Avatar
19x8.5 et32 235/35
19x10 et38 275/30
I spoke with Forgestar today and they said my current setup would fit. Just incase anyone wanted to know.
      11-30-2012, 08:57 PM   #81
rxander
rxander's Avatar
Drives: F30 Alpine White
Thanks for this info!
Btw what are you dropped on?
      11-30-2012, 09:39 PM   #82
mikew2069
mikew2069's Avatar
58
So when are you going to put em on? Seems like it would stick out too far - can't wait to see it! Are you planning a drop?
      12-01-2012, 01:11 AM   #83
etmathews
etmathews's Avatar
My F30 is on order and won't be here until the first week in January. I'm not planning on dropping it.
      12-01-2012, 09:09 AM   #84
mikew2069
mikew2069's Avatar
58
Cool, that's probably about when I'll get mine. I think I'm going to drive the car 1000 miles before I put any mods on the car. I don't want to get tires mounted on my wheels until I put the springs on b/c Discount Tire said that if we choose a size and it rubs, we can order another size as long as its the same day.
It's going to be tough looking at my wheels and other parts just sitting here for the first 1000 miles!
      12-03-2012, 02:40 PM   #85
jsedlak
jsedlak's Avatar
The reason I mention it is because my front fitment isn't final. I may end up just running 8.5 up front because I don't want to risk having issues in a parking lot.
      12-03-2012, 06:25 PM   #86
mikew2069
mikew2069's Avatar
58
Yea, I'm at the point of no return. After doing tons of research, I wish I would have gone 8.5 up front and 9.5 rear. That way the 265 would be a better fit on the 9.5 wheel. I keep flip flopping b/t the 265 and 285 tire. I'll probably change my mind 7 more times before I get my car.
      12-04-2012, 12:11 AM   #87
nick2013328i
nick2013328i's Avatar
Drives: 2013 328i
Originally Posted by onehungevo View Post
Correct from **********s. I wanted to go with something different. I bought 265/30/19 rear and 235/35/19 front handkook tires.
I have that exact set up and size on my AW f30 if you guys looking for pics
      12-04-2012, 10:05 AM   #88
jsedlak
jsedlak's Avatar
You ordered? What did you get?
