BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19x9.5 38 offset 265/30/19
      12-04-2012, 11:47 AM   #89
mikew2069
mikew2069's Avatar
64
Drives: F30 335i MSport
Forgestars. 19x9 +35 and 19x10 +45... I ordered them about 4 weeks ago. Should be another two weeks before I get them.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      12-04-2012, 12:44 PM   #90
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
Niiiiiiiiice. F14 or CF10?
It's good that you're in Houston, our cars may end up matching.
      12-04-2012, 02:50 PM   #91
mikew2069
mikew2069's Avatar
64
Trick question - Neither.... CF5V
I have to say that I'm slightly concerned that they've changed the 'color' of their Gunmetal. I saw a pic on Facebook and they looked light grey. We shall see.....
      12-04-2012, 03:45 PM   #92
jsedlak
jsedlak's Avatar
Oh wow... I didn't even realize they sold those! I may have to change over to that now...
I'm so excited for you - they're going to look fantastic!
      12-04-2012, 04:17 PM   #93
mikew2069
mikew2069's Avatar
64
Thanks, I'm pretty excited too. I just called them and they said that they only have one shade of Gunmetal. The picture I was worried about on Facebook is from SEMA and the lighting there made it look light grey but its the same Gunmetal they've always used.
Can't wait! I'll post pics as soon as I get them but it won't be for another week or two.
      12-09-2012, 08:09 AM   #94
Renus
Renus's Avatar
Drives: E92 335i
Originally Posted by ric124 View Post
Here is what I am running with zero rub.
H&R Sport with Adaptive M
Front 19x8.5 ET40 235/35R19XL
Rear 19x9.5 ET45 265/30R19XL
Your ET for front and rear are very far from fender's edges, therefore you won't get rub but fitment looking not so aggresive I think.
      12-09-2012, 12:40 PM   #95
soolman32
soolman32's Avatar
Drives: Current: F30 335i Soon: AMG
I see a lot of discussion here about offsets but all the specs I'm seeing seem very conservative. I'm not new to fitment but I have no experience with BMW fitment. Guess it's a completely different world.
      12-11-2012, 01:47 AM   #96
ric124
ric124's Avatar
Jamaica
284
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Dont really look like I have that much more room to work with. Let me know what offset your were able to figure out that works as close as possible with no rub.
      12-11-2012, 08:45 AM   #97
mikew2069
mikew2069's Avatar
64
Ric with your setup: Front 19x8.5 ET40 235/35R19XL, Rear 19x9.5 ET45 265/30R19XL
Based on your tire size, you could have gone with 19x8.5 et35 or et33 in the front. 19x9.5 et45 seems about right. You could have maybe went et40.
A member on here Scott@bmw is running 19x9.5 et38 I think on 265/35 with no rubbing.
      12-11-2012, 03:52 PM   #98
onehungevo
Drives:
I'm running 265/30/19 with 19x9.5 rims and 38 offset. I'm lowered with H & R Super Sport and no rubbing. There isn't much room and I haven't had my car aligned.
FYI...Tirerack told me that there can be as much as an 1" fender width difference between the same Year, make and model car.
      12-11-2012, 03:55 PM   #99
Renus
Renus's Avatar
Drives: E92 335i
My new shoes : -
ET35 front and ET36 rear
      12-11-2012, 04:08 PM   #100
jsedlak
jsedlak's Avatar
My new shoes : -
Widths?
johnsedlak.com - web developer, designer
      12-11-2012, 04:13 PM   #101
mikew2069
mikew2069's Avatar
64
Widths?
And tire specs?
      12-11-2012, 04:15 PM   #102
mikew2069
mikew2069's Avatar
64
FYI...Tirerack told me that there can be as much as an 1" fender width difference between the same Year, make and model of car.
My setup will stick out 3mm (0.12in) further than yours. I know you said there isn't much room but do you think there's at least 3mm?
That's scary if what Tirerack says is true. 1" is A LOT
      12-11-2012, 04:43 PM   #103
ric124
ric124's Avatar
Jamaica
284
2017 BMW M2  [0.00]
My new shoes : -
Your car looks like it sits higher than mine. What springs are you running.
      12-11-2012, 04:51 PM   #104
Renus
Renus's Avatar
Drives: E92 335i
Widths?
Front : 19" x 8.5J x ET35
Rear : 19" x 9.5J x ET36
      12-11-2012, 04:52 PM   #105
Renus
Renus's Avatar
Drives: E92 335i
And tire specs?
19" x 235 x 35 for front
19" x 265 x 30 for rear
      12-11-2012, 04:53 PM   #106
Renus
Renus's Avatar
Drives: E92 335i
It is stock suspension. By the way, your M adaptive suspension is ordered from after-market or from BMW? What is the main different from Sport package even M Performance suspension? Do you have it's part number for reference? Thanks.
      12-11-2012, 04:54 PM   #107
Renus
Renus's Avatar
Drives: E92 335i
Actually my rear wheel is wider than edge of fender, could be more than 3mm which around 5mm or more.
      12-11-2012, 05:59 PM   #108
mikew2069
mikew2069's Avatar
64
Can you post a couple of pics of your rear wheel in relation to your fender? My setup will stick out just as much as yours and it would help me out a lot.
Thanks!
      12-11-2012, 06:22 PM   #109
ric124
ric124's Avatar
Jamaica
284
2017 BMW M2  [0.00]
Adaptive M was ordered with the car, sport line with adaptive M . It works with driver modes Comfort to sport. Not sure if its as simple as buying and putting them on may need some coding.
I took the sport springs off and replaced it with H&R Sports. This setup gives a much stiffer setup than sport pkg in Sport/Sport+ mode and softer feel in eco/comfort mode.
I wasnt able to find a part number but this what I think this is the order code.
S2VFA ADAPTIVES M FAHRWERK Adaptive M suspension
      12-11-2012, 09:00 PM   #110
jsedlak
jsedlak's Avatar
a 19x10+37 with a 265/30 is said to fit the same as your setup...
