Login
12-13-2012, 12:58 PM | #133 |
![]() ![]() 143
Rep 3,782
My Forgestar order was delayed because the 8.5" front barrels are on back order.
![]() '98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
12-13-2012, 01:30 PM | #134 |
![]() 58
Rep 1,319
Man that sucks. Interesting b/c they recommended 8.5 on the front but I wanted 9". Guess I got lucky kind of sort of?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance |
12-13-2012, 03:24 PM | #135 |
![]() ![]() 143
Rep 3,782
I am running them when temps are back up in April. So the delay means nothing to me. I didn't see a point in running a wider wheel and tire to add weight. 8.5 should be fine for the fronts.
12-13-2012, 07:29 PM | #136 |
WARRIORS come out to play yay!!
![]() 18
Rep 347
Drives: 2016 F30 340i M Sport
That's good to know, I might have to check into that.
12-15-2012, 12:44 AM | #137 |
![]() 263
Rep 1,589
just got car today and installed wheels right away. took rear shot at night but wheel is 19x9.5 et32 in rear with Michelin PSS 265/30/19. better pictures to come in daytime. wheels look great but seems i am really pushing it in. Drove 50 miles home today on setup and no rubbing issues. I had all my stock wheel loaded in rear so there was rear weight
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
12-15-2012, 09:10 AM | #138 |
![]() 58
Rep 1,319
Very nice! Can't wait so see some more detailed pics. That is definitely an aggressive offset. It sticks out 3mm further than my setup with a 285/30 tire. Do you plan on dropping it? If it was dropped do you think you would rub?
12-15-2012, 02:56 PM | #139 |
![]() 263
Rep 1,589
Not sure but according to Long Tran, I won't rub. I will eventually drop it but will be very conservative
12-15-2012, 04:58 PM | #140 | |
![]() ![]() ![]() 21
Rep 528
According to your last photo shoted from rear, if you lower your car, seem will rub your fender unless you got a lot camber to avoid it. |
12-15-2012, 06:53 PM | #141 |
![]() 58
Rep 1,319
Yea, I definitey want to see more pics on how the rear wheels sit in the fender.
12-24-2012, 03:48 PM | #142 | |
![]() ![]() ![]() 11
Rep 410
johnsedlak.com - web developer, designer
12-25-2012, 11:11 AM | #143 |
![]() 58
Rep 1,319
No, they are in 'quality inspection' stage so it should be another two weeks. They have a rather SLOW turnaround time. It'll end up being 8-9 weeks total by the time I receive them.
I'm in no hurry since my car isn't even here but I just want them here so I can stare at them!
12-25-2012, 12:32 PM | #144 |
![]() 263
Rep 1,589
I talked to a friend who did an f30 with a 10 inch rear and a similar offset to my rear. Based on what they saw after the drop they think I will be fine. It actually seems like the suspension with most conservative drop is KW with 1.2" front and 1" rear. H&R and eibach seem to be having a more aggressive drop.
12-26-2012, 05:03 AM | #146 | |
![]() ![]() ![]() 14
Rep 478
12-26-2012, 11:44 AM | #147 |
![]() 58
Rep 1,319
Cool, can't wait to hear your results. If yours fits with no rubbing, so will my 19x10 +45 with 285 tires.
12-30-2012, 01:24 PM | #148 |
Rep 4
I am about to put on 19x9.5 33et with 255/35r19 with H&R springs with non-m adaptive sport suspension. I shouldn't have any problems with rubbing should I? I looked up the changes and it said I would lose 18 mm on the inside and push out 20 mm on outside. but I couldn't find how much space i will start with.
12-31-2012, 02:53 AM | #149 |
![]() 263
Rep 1,589
The one think about stance I am still trying to learn is about the differences the tires can make. For example I got PSS tires for their overall quality but I have been told they are very thick tires and should have gone with a different one to increase my chances of no rubbing. Anybody know of a tire rater that measures tire thickness for those of us on the edge of aggressive setups?
12-31-2012, 11:26 AM | #150 |
![]() 58
Rep 1,319
Not sure about tire thickness but I'm going to try the Continental ExtremeContact DW tires b/c they are the lightest tire I could find. The second lightest are the Michelin SuperSports but they also don't come in a 285/30. I prefer Michelin so IF the 285/30 Conti rubs in the rear, I'll change to Michelin 275/30.
01-04-2013, 12:49 AM | #151 | |
![]() 325
Rep 3,366
Dave
2013 M3 Coupe-MR/BLK ZCP, ACM test pipes, BPM Stg2 dev. tune and Megan catback, AFE Stg2. with C/F elbow VMRV810 19x10&19X11 275/295 Mich PSS.
Previous rides: 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
01-05-2013, 04:03 PM | #153 |
![]() 58
Rep 1,319
Hmmmmm.. Discount Tire said they can order them
