BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Adding sub and amp to stock 'hifi' system
      07-05-2012, 07:35 PM   #1
NateDog07V
Drives: '13 335i M-Sport BSM/CoralRed
Has anyone wired up a sub/amp to the stock system? Is there a wiring schematic out there I can use to figure out which wires to tap into to either run a high level input to the amp or an RCA line out converter? It will be another month or so until my M Sport 335i arrives, but i'd like to start planning now if possible I'm thinking of adding a small 10" sub in a sealed enclosure (0.5 cubic feet) in the trunk... this will free up the stock speakers to be able to do their job better since the bass duties will be handled by the aftermarket sub
      07-09-2012, 01:11 PM   #2
VP Electricity
VP Electricity's Avatar
Drives: F34 xDrive
We have not yet validated our package in the F30, but we hope that in 45 days we will be offering a PnP package just like you describe. I would be shocked if they changed the amp harness, it's been the same for HiFi since the E46 at least.
The HiFi amp gets lower-voltage preamp, but for just adding an amp, you're best off using the woofer outputs from the amp, not messing with the preamp signals (too easy to introduce RPM whine that way).
Musicar Certified Sound
Musicar Northwest in Portland, Oregon
musicarcertified.com
musicarnw.com
      07-09-2012, 01:50 PM   #3
NateDog07V
OK, great, that's what i was anticipating. Do you happen to have a diagram of the harness so we can determine which wires go to the subs, and possibly where a switched power line is as well?
      09-10-2012, 12:53 PM   #4
NateDog07V
Any update on this? Anyone know which wires are the sub outputs on the stock amp and also what to tap for a remote turn on ?
subwoofer amp line out converter
