BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Can u retrofit a Combox Media to a base F30?
VIBE Motorsports
      07-08-2012, 03:55 PM   #1
yujyh
Drives: F30 320d Luxury S-Automatic
Can it be done if the car has no sat nav and the smaller screen?
      07-08-2012, 10:05 PM   #2
PrazVT
PrazVT's Avatar
Drives: '15 228i M Sport Track 6mt
I exchanged a few e-mails w/ Patryk from bimmer-tech a month ago or so and he seemed to think it would work. Excerpt:
"If you have the Combox (no matter which one) you will be able to use the Apple white cable.
However I just checked the BMW diagrams and it seems that your car will have the USB port connected directly to the head unit
and this is why the Apple white cable might not work and this will be just basic iPod integration.
If you had taken the 6NL option then they would have installed the Combox Telematics and the USB port would have been connected to the Combox.
Assuming the head units that are installed in cars with 6NH and those installed with options 6NL are the same
we should be able to retrofit the Combox, but most probably we shall not be able to make it a permanent retrofit.
I mean that you would need to disconnect the Combox before your dealer could update the car software in the future.
I am thinking about the Media version that is cheaper than the Telematics."
2015 228i M Sport 6mt + Track Handling Package
2012 328i Sport 6mt (retired)
      07-09-2012, 12:44 AM   #3
clarence
Drives: F30 328i M-Sport
Does ur can have enhanced BT and or BMW Assist?
      07-09-2012, 06:12 AM   #4
yujyh
No my car has the base Bluetooth and iPod connects through Y-Cable. Thats why I thought the Combox Media might work but not the Combox Telematics.
My dealer is also checking with BMW but I have some doubts there as well.
      07-09-2012, 07:58 AM   #5
yujyh
trying now to get 06nk fitted only, hopefully that doesn't need as much HW as 06nl
      07-10-2012, 12:38 PM   #6
yujyh
Dealer just told me it cannot be done, sniff...
      07-10-2012, 12:43 PM   #7
PrazVT
PrazVT's Avatar
It's not that BMW can't do it - they won't do it. Both Patryk (bimmer-tech) and Aleks (Alekshop) have said they can do it.
      07-17-2012, 08:14 AM   #8
yujyh
Thanks, am returning the car now and getting one which has 6NL and a fix for the other problems I had so it's all good and lucky! Cant wait
      09-13-2012, 11:14 AM   #9
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
What is the combox exactly?
M Sport Line Estoril Blue
      10-09-2016, 04:09 PM   #10
tarekelsakka
Drives: BMW F30 316i
I apologize for reviving such an old thread, but did anyone get around to doing this? I have a 2013 F30 with the small screen and standard Bluetooth which only works for phone calls. I do have a USB port in the glovebox which I use for music playback through a USB flash drive.
I also have BMW's Connected Drive on the display but it only has one option, which is to contact the BMW Emergency Services in case anything happens on the road.
Replacing the iDrive with a nav one is extremely expensive and not easy to do, so I thought retrofitting a COMBOX would be cheaper and easier. Does anyone know if it's doable and exactly what it requires? And what exactly would it enable? Premium Bluetooth?
Thanks
      10-09-2016, 10:18 PM   #11
Adamr916
Adamr916's Avatar
Drives: 2014 328d
You won't even have to retrofit the combox, you just need to get enhanced bluetooth turned on by coding.
      10-10-2016, 06:37 AM   #12
tarekelsakka
But I've read and heard that in order to get enhanced Bluetooth to work, I'll need a COMBOX installed in the trunk of the car, regardless of coding.
      10-10-2016, 12:23 PM   #13
Patrys@BimmerTech
Patrys@BimmerTech's Avatar
Poland
453
Drives: 2007 E92 335i
If you send us an email at info@bimmer-tech.net with your VIN we will check if you need just software or the full Combox retrofit kit.
      10-10-2016, 12:56 PM   #14
tarekelsakka
Thanks for your reply, Patrick. I've heard a lot about you here and in other forums.
I sent the VIN number to the email address you provided. Thank you!
