BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 20x9 et35 front + 20x10 et35 rear = fit?
      07-12-2012, 03:04 PM   #1
Helicide
Helicide's Avatar
Drives: E24 M6
How will 20x9 et35 front and 20x10 et35 rear fit? I'm looking to get VMR VB3's in that size. It is the recommended size on European Auto Source's website but it seems odd that the front and rears have the same offset with different widths.
Current:
75' 530i 5MT (E12)
85' 735i 5MT (E23)
00' M Coupe 5MT (E36/8)
03' 540iT M Sport 5AT (E39)
      07-12-2012, 04:21 PM   #2
dcg71
Australia
51
Drives: F15 X5 25d / Ducati Monster
I'd look at the pics in onehungevo's thread. In comparison, your wheels will sit 3mm further out (3mm lower offset), you'll have a 1/2" wider wheel, and the overall wheel/tire diameter will be larger (onehungevo is running tires with a lower aspect ratio than spec). His car is lowered though, but I still don't like your chances.
      07-12-2012, 04:34 PM   #3
Helicide
Helicide's Avatar
Drives: E24 M6
I should go with a square setup 20x9 et35 front and rear.
Current:
75' 530i 5MT (E12)
85' 735i 5MT (E23)
      07-12-2012, 10:35 PM   #4
onehungevo
Drives:
That should work. I almost went that route with V710's.
      07-13-2012, 03:11 AM   #5
F30 Pilot
F30 Pilot's Avatar
Drives: F30 328i
From what I've read, you will need a 40et to a 45et for the rear in that size of wheel. I've used elementwheels.com search function for the F30 and it gives the et and fit required for a 9 and 10 rim.
2013 AW 328i: Sport Line, Sport Trans, Moon roof, Navigation, HK Stereo with Sat Radio, Xenons and 351m wheels
      07-19-2012, 08:02 AM   #6
F555
F555's Avatar
Indonesia
25
Drives: F30 - 335i
the wheel will sit flush with a bit of poke, but if u r into stance & fitment things then the size will be just right.
      10-30-2012, 07:20 PM   #7
s1k0ne
Drives: ..
anybody try this yet? sorry if i'm bringing it back from the dead
I'm thinking that a 245/35/19, 265/30/19 will make this work.
drop it low and make the natural camber settle it in.
I saw a few that went x10.5+45, x10+40, but haven't seen a x10+35 yet.
      10-30-2012, 07:36 PM   #8
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
305
Drives: Project Estoril
That's the same sizes I had on my F30. The rear will poke out a bit. Probably more than most people would like. With a 285 and my drop, it did not rub though. Take a look at my thread in the gallery section with the K3 Projekt wheels.
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      10-31-2012, 12:20 AM   #9
nickstin
Drives: '08 AW E92
Thought I read on that thread that the rears were 20x10.5 +35... No?
      10-31-2012, 08:12 AM   #10
1clean335i
1clean335i's Avatar
Vietnam
305
Oops. I thought it said 10.5. Well if my 10.5's worked, im sure the 10's will work also
      10-31-2012, 12:59 PM   #11
nickstin
Drives: '08 AW E92
There you go op. Looks like it would work. Also, the cars in the European car magazine with the HREs have 20x11+42 and 20x11+44 which are slightly more aggressive.
      10-31-2012, 04:54 PM   #12
s1k0ne
Drives: ..
How in the world did i forget your car? lol
