proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
      07-18-2012, 01:32 AM   #1
southlight
Moderator / European Editor
southlight's Avatar
1485
Drives: X3M
Exclamation 2015 BMW M4 Coupe (F82) Spied!
BIMMERPOST NEWS
167
COMMENTS
UPDATE: Although not visible in these photos, you can expect the F82 M4 coupe to receive the same (or very similar) hood lip/bulge that we recently spotted for the first time on the F80 M3 sedan.
We've heard rumblings in recent weeks that the F82 M4 coupe had begun its public testing rounds and our spies have now spotted it for the very first time in and around the BMW M Test Center at the Nurburgring!
The prototype wears the typical heavy camouflage of early stage mules, but there's plenty to analyze. There's little doubt that this is the M version of the upcoming F32 4 Series coupe. There are the signature M quad exhausts, the flared fenders, signature blue M brakes, wide tires, and M6 steering wheel.
Body
Both the front and rear fenders on the M4 coupe are significantly flared and stretched compared to the F32 4 Series prototypes we have spotted. The rear flare is easy to spot, while the front is less conspicuous. But, one can easily see in some photos a the gap in the front fender camouflage which clearly shows the front fender as much wider than the rest of the side body. The stretched fenders will accommodate a wider track for the M4 (vs the regular 4 Series).
Underneath the completely covered front fascia will be a sleeker version of the F30 3 Series front end, with sportier lights and grilles (which have now been revealed on the F32 4 Series prototypes). There will of course be M styled front bumper as well. The mirrors are from the F30 3 Series and for testing purposes only. The final production mirrors will be sportier, but may not be revealed until even after the concept debuts (like the F10 M5).
Carbon Fiber Roof / Brakes
This particular mule does not appear to feature a carbon fiber roof, but we're fairly sure that the production M4 Coupe will utilize a carbon fiber roof. Its brakes resemble the new 3 Series' M Sport brakes, paired with steel cross drilled rotors. The wheels are the same as seen on the F80 M3 sedan test mules, as well as the ones peeking out from under the tarp covered BMW Museum mystery car, which we deduced to be the M4 coupe.
Interior
The presence of shift paddles in the interior reveals that this prototype is a DCT model, but the next M3/M4 will also come with a manual transmission option, as it's already been spotted on F80 M3 prototypes. The steering wheel seen here comes from the new M6.
Powertrain
The F80 M3 and F82 M4 will be powered by an inline 6 cylinder engine with multiple turbochargers, pushing the engine's output to approximately 450 horsepowers. The engine is now rumored to be an extensively reworked and reinforced N55 6-cylinder engine with a strengthened aluminium block with a heavily modified cylinder head. The Induction technology is said to be completely new as will be the latest bi-vanos variable valve timing.
The F80 M3 / F82 M4 will not be constructed extensively from carbon fiber (CFRP) as some earlier reports had speculated. Because this next generation M3/M4 began development two years ago, it's said to have been too early to take advantage of BMW's CFRP developments with the later introduction of the BMW i cars/project. The first model (besides the i cars) that will have extensive CFRP incorporated into its construction will be the next generation 7 Series, as reported earlier.
Even without extensive CFRP construction, the next M3/M4 will be lighter than the current M3 sedan and coupe however, owing to its new aluminum chassis, and aluminum and reinforced plastic body panels.
The following is a summary of the facts we can be certain of regarding the F80 M3 / F82 M4:
  • Lighter than current M3
  • Faster than current M3
  • More powerful than current M3
  • More efficient than current M3
  • Powered by an inline 6 cylinder turbo engine
  • Offered with optional or standard manual transmission
  • Electric Power Steering (completely reworked for precision for M3/M4)
  • M3 Introduced late 2013 - early 2014
  • M4 Introduced no earlier than late 2014
*Click on images for hi-resolution version*
UPDATED PHOTOS:
Name:  bmw m4 1a.jpg
Name:  bmw m4 2a.jpg
Name:  bmw m4 3a.jpg
Name:  bmw m4 4a.jpg
Name:  bmw m4 5a.jpg
Name:  bmw m4 6a.jpg
ORIGINAL PHOTOS:
Name:  bmw m coupe 1a.jpg
Name:  bmw m coupe 2a.jpg
Name:  bmw m coupe 3a.jpg
Name:  bmw m coupe 4a.jpg
Name:  bmw m coupe 5a.jpg
Name:  bmw m coupe 6a.jpg
Name:  bmw m coupe 7a.jpg
Visual Comparison of F32 4 Series Prototypes to E92 3 Series Prototypes at Similar Testing Stage
To provide some perspective of how the F32 compares to the E92 at a similar testing/camouflage stage, we revisit the earliest E92 coupe test prototype photos from back at the end of 2005 and we've posted below a comparison of the F32 coupe at this early stage camouflage compared to the E92 coupe during its early stages of testing.
Scrutinizing the photos, it's easy to see how a camouflaged coupe appears overly lengthy and bulky, especially with respect to the front and rear fascias, which still have heavy and cumbersome camouflage.
Keeping in mind how attractive the E92 coupe turned out in production form, we wouldn't bet against BMW with respect to the F32's (or F82 M4's) design. Of course it's always a bit silly to declare final judgment on a car based on preliminary heavy-camo images, so the point here is that it's wise to reserve your judgments until the car is fully revealed (or at least loses most of its camouflage).
* E92 3 Series Coupe Prototype (from 2005) vs. F32 4 Series Coupe Prototype (2012)
      07-18-2012, 02:19 AM   #2
Jblack4083
Drives: E46 ///M3 JB/CB
Some Observations:
Of course it's very early to judge but the general shape looks very unexciting to me. Of course who knows what camo panels are under there...
Was expecting bigger front brakes... maybe six piston brakes.
Fender flares look a bit odd. I'll wait to see how this shapes out. Hopefully it doesn't end up like the C63 lol.
      07-18-2012, 02:27 AM   #3
swamp2
swamp2's Avatar
Drives: E92 M3
Damn, I want a close up of that tachometer. I guess though that would only be really insightful if it was both running and warmed up...
What is with the really odd tail lights?
Nice brakes, well nice calipers at least. Unfortunately the rotors look like the same old BMW Motorsport design. They are good in that they are composite, probably fairly lightweight an aluminum hat but they still have that poor design feature where the hat blocks much of the cooling flow...
Ugly too visible muffler (again), ugh.
Anyone think the mirrors are a finalized design?
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      07-18-2012, 02:31 AM   #4
Jason
Administrator
Jason's Avatar
Drives: F80 M3
The odd tail lights are the typical early camouflage versions, simply there for functional purposes and completely hiding the actual lights underneath.
Per the article that's now been posted above, the mirrors are prototype stage only. The production model will see sportier mirrors.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      07-18-2012, 02:51 AM   #5
crowed
Drives: 2011 E92 M3
For anyone who is worried-- refer to the following post also by Jason: http://www.f30post.com/forums/showthread.php?t=611044
It reminds you that camo is there for just that... hiding the nuances of the true design underneath
      07-18-2012, 02:53 AM   #6
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Thanks for that reference. It's really something helpful to keep in mind when viewing spy photos.
      07-18-2012, 02:58 AM   #7
DDS2015
Drives: 2018 M3CS
2021 BMW X3  [0.00]
2023 BMW M4  [0.00]
So excited for this. I already know its going to be my next car.
      07-18-2012, 03:04 AM   #8
PALMAN
PALMAN's Avatar
Poland
Drives: F11 530d M-Sport
No CF roof ??
- '10 F11 530dA ///M-Sport - Alpine White
- '04 E46 325xi Touring - Saphire Black
      07-18-2012, 03:15 AM   #9
aajami
aajami's Avatar
Drives: Space Gray '09 E92 M3
It's too early to make much of the design at this point, as it's still plastered with camo.
Interesting muffler canisters, though. And I am not a fan of the tapered and rolled exhaust tips. The tapering is a new thing for M cars -- they almost look like x28i tips. Not a fan at all -- I'll wait for the single-walled straight-cut M Performance exhaust.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      07-18-2012, 03:21 AM   #10
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Added more photos to the article.
      07-18-2012, 03:27 AM   #11
csween86
DSC OFF
csween86's Avatar
Drives: 2011 135i, N55, 6MT, MPK
Why must BMW tease... I want to know what it looks like, and I want to know now!
      07-18-2012, 03:40 AM   #12
M Silva
M Silva's Avatar
Drives: an old fast bimmer
And the M4 rumours are back. Once again.
      07-18-2012, 04:17 AM   #13
EdM5
EdM5's Avatar
Netherlands
3826
Drives: G26 i4 M50 & E70 X5 Xdrive35d
Can't wait to welcome her in my stable
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d
      07-18-2012, 04:41 AM   #14
dapopa9
dapopa9's Avatar
68
Drives: F80 M3
Pic #8 down the full side profile pic reminds me of a Mustang
      07-18-2012, 05:01 AM   #15
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
A beefed up N55 with multiple turbos with 450 hp to the crank. Hmm. I just dont like the idea of it having anything to do with a N55.
O'well, we will see soon enough
      07-18-2012, 05:02 AM   #16
JK135i
8:39
JK135i's Avatar
Drives: 2010 135i
2010 135i  [9.50]
I was driving next to the M4 and new M3 on Autobahn 3 headed towards the Ring. They look ok but one thing still remains, the M3 sounds like a Pontiac Grand-Am with a flow master muffler.
"Never attribute to malice that which is adequately explained by stupidity."
      07-18-2012, 05:26 AM   #17
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
but won't sound as mean as E9X M3.
      07-18-2012, 05:39 AM   #18
Romo
Romo's Avatar
Netherlands
1748
Drives: GR Yaris GT4RS
Is it David-Michael Knight-Hasselhoff behind the wheel?
I swear, it must be him, in an all new KITT version..........
      07-18-2012, 06:00 AM   #19
sameh
sameh's Avatar
Drives: 2015 Porsche 911S
Any chance some one could post our E9x when it was at that stage? I have a feeling that comparing E92 in Camo to these pictures may give us better idea!
2011 E92 JB/BL/DCT--->80K Miles
2015 F80 SS/SO/DCT?->28K Miles
2015 Porsche 911S
      07-18-2012, 06:19 AM   #20
M3 Esq
Automobilist
M3 Esq's Avatar
Drives: E70 X5, 911 GT3
I hope the final design utilizes the power dome hood. That is one thing that was so appealing to me about the current generation.
      07-18-2012, 06:22 AM   #21
the /// kid
Drives: 2011 328i
I just can't see M not hitting the mark on this car. The M5 was one upped in my opinion sleeker, more power, more efficient. Sure some might not see efficiency as being the M type do to the racing history but it just shows the smarts the strive to put into there technology. I'm sure this car will be a masterful combination of speed, efficiency, with just the right touch of luxury in that always appealing BMW interior
      07-18-2012, 06:33 AM   #22
richardg
richardg's Avatar
Drives: MacanGTS, 991.2GT3, E63wagon
I wish the brakes were larger. Would have been nice if they took the units from the m5/6. I am sure these brakes will work fine and are probably lighter. The car looks very narrow to me though. I think it will be thinner than the sedan just as the e92 was to the e90. I am happy to see it using that super sexy steering wheel from the m6. So glad to see that. As for the rear bumper the exhaust cutouts are very sloppy and the bumper is very thin. I think this is a f32 bumper that was cut to fit the quad exhausts. I am sure the final bumper will thicker/beefier and have some kind of functional Aero design. Lastly as for the exhaust itself I think the tips are ugly but I am glad to see that the muffler portion looks much smaller than the previous e46 and e9x M. I am willing to bet it will hide nicely behind the final rear bumper design and hopefully it's a good bit lighter.
Oh and the wheels I think will be final. If you look closely you can see the ///M badge on the wheels.
2013 bmw m3, 2013 bmw m4, 2013 m3, 2013 m4, 2014 bmw m3, 2014 m3, 2014 m3 engine, 2014 m3 forum, 2014 m4, 2014 m4 coupe, 2015 m3 engine, 2015 m4, 2015 m4 coupe, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 engine, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 engine, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m3 n55, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 forum, bmw m4 forums, bmw m4 n55, f80, f80 forum, f80 forums, f80 m3, f80 m3 engine, f80 m3 forum, f80 m3 forums, f80 m3 motor, f80 m3 sedan, f82, f82 coupe, f82 forum, f82 forums, f82 m3, f82 m3 coupe, f82 m3 forum, f82 m4, f82 m4 coupe, f82 m4 engine, f82 m4 forum
f80post
