Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > How does the F30 ride compare to the E90?
      07-21-2012, 08:21 PM   #1
allyli
Drives: BMW 330i
I'm thinking of upgrading to a F30 as soon as I can fix my E90 330i and can sell it.
How does the handling compare?
I had runflats onm my E90 and replaced them with nonrunflats.
Have they finally sorted the ride out for the new F30?
      07-21-2012, 08:35 PM   #2
tony20009
tony20009's Avatar
Drives: BMW 335i - Coupe
A lot's been said here an in the automotive press that should answer your question. In short, it handles as well, perhaps better than the E90, but it does so in a less communicative way. It is a very pleasant car to drive, however, especially in typical situations. It is a full on midsize sedan and even a base, or modestly optioned, model 328i, which has quite ample power, will be quite satisfying to anyone who doesn't care about gizmos and gee-gaws.
As you have an E90, I would say you need to spend some time in the F30 to really appreciate it, but having done so, appreciate it you will. I was, as recently as last week, very "down" on the F30, but after spending a day with an F30 service loaner, I strongly recommend it.
I posted some additional observations here: http://www.f30post.com/forums/showthread.php?t=720046.
Cheers,
Tony
'07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed
      07-21-2012, 08:36 PM   #3
cavm335i
Drives: 2012 335i F30
I had the stock 18's on my e93 first with runflats and then without. I hated the runflats on that car, entirely too rough on Houston streets. Changing to Nitto nonrunflats provided better traction around rough corners and a softer ride.
I now have 19s with the pirelli runflats on my F30 and the ride is very good. I do NOT have the VSS or M sport suspension. Driving around the pothole-ridden streets is MUCH improved in the F30. Highly recommend!
