BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Map Light Removal by VS Motorsports
      07-25-2012, 05:30 PM   #1
VSmotorsports
VSmotorsports's Avatar
103
Drives: e92 M3
Send a message via AIM to VSmotorsports
We went ahead and took out the Map light out of our Project F30 335i. Our plan was to take this out and hardwire our radar, but we want with a different route to power our unit. But for the people who are looking to take this out, we thought we would go ahead and document this process and posting it here.
Many of you recall the steps to remove the map light on the e9x, DO NOT FOLLOW THOSE STEPS, WILL NOT WORK!
Tools Needed:
2x Flat Head screwdrivers
First, you will have to remove the trim piece off
Next locate the following spots and insert your flat head
Insert your screw driver and push the screwdriver towards the inside of the map light (repeat on both sides)
Use your second screwdriver and slowly start to separate the headliner to the map light and start to pull down
At this point you can pull it down and should come out.
This is what the clips look like on the side and the rear
      07-25-2012, 06:18 PM   #2
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
Where do you tap into for power. I need to get my v1 hardwired. Thanks for the info.
2015 M3 Alpine white, shakir orange
carbon roof, black 19's, lighting, executive, HK
side&top view, adaptive susp, mods to come......
      07-25-2012, 08:50 PM   #3
328i4me
Drives: 08 E92 335xi
Send a message via AIM to 328i4me
+1. Im curious as well and would like to hardwire my V1 too. Is there a particular reason to why you guys didn't use the map lights as the power source?
      08-09-2012, 05:48 PM   #4
remydlc
remydlc's Avatar
Drives: F30 N55 MT/blue metal/red int.
Bump! curious too as to what cables to intercept. I need to hardwire my V1 as well.
root@bash-it# shift -g 6 -c 335i | grep "155 MPH"
      08-13-2012, 01:10 PM   #5
ddcha
ddcha's Avatar
Drives: 2013 MG 335i M Sport on order
Bump. me too.
      08-13-2012, 01:35 PM   #6
VSmotorsports
103
Drives: e92 M3
we will update this next week with that information when the car is back, sorry for the delay
      08-20-2012, 09:16 PM   #7
E46M54325Ci
E46M54325Ci's Avatar
184
Drives: The Root Beer Float
yea I want to know the radar detector wire tap- ie which cable
The Root Beer Float - 2017 230i, Sparkling Brown on Oyster, ZTR, ZLP, ZCW, 2TB...Completed October 2016 ED...http://www.2addicts.com/forums/showthread.php?t=1315020 Redelivered December 2016!
Nurburgring Training! http://f87.bimmerpost.com/forums/sho....php?t=1417300
      08-21-2012, 09:05 AM   #8
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
368
Drives: BMW M3 | X5 xdrive 35i MSport
We will have a write up this week, be on the look out
Evolve E600 BMW E92 M3 | BMW E70 X5 xdrive35 M-sport
      08-21-2012, 11:15 AM   #9
E46M54325Ci
184
awesome, thanks!
      08-21-2012, 01:53 PM   #10
remydlc
remydlc's Avatar
thanks a lot. I am so looking forward this DIY. My cable is broken and i have been a ticket magnet lately.
      08-23-2012, 10:56 PM   #11
DNN_F30
Enthusiast
Drives: 2013 335 M-Sport (EB)
Send a message via Skype™ to DNN_F30
Took my V1 to get installed today. Master electrician said he couldn't tab the Map light wires for power. He had to tap in directly to fuse box. Does this make sense? :
2013 335i ///M-Sport
Estoril Blue II, Alum Hex Trim, Estoril Trim, Premium Pkg, Black Leather, Tech Pkg, HK.
      08-23-2012, 10:58 PM   #12
E46M54325Ci
184
if the car is like the e9x, no. but that's yet to be determined.
      08-27-2012, 10:17 PM   #13
auptown
Drives: 2013 F30 328xi
I'm waiting too -- and given that I got a ticket test driving a 335xi I need it!
Andrew
      09-21-2012, 11:27 PM   #14
Boondoggler
Boondoggler's Avatar
Drives: '16 F30 340i xDrive M-Sport
No update, looks like this thread is dying. Bummer, I really would like to know what wire from this area to tap for power.
2016 340i xDrive M-Sport SA8T
My Garage | Estoril Blue | Saddle Brown | Ash Trim | Cold Weather | Track | Technology | Driver Assistance + | Lighting | 19" 442M Orbit Grey
      09-22-2012, 01:46 AM   #15
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
368
I know they were trying to figure out the best solution to tap the wire. I recall when I got into the f30 they had it tapped to a power source which would power on when the door would open, but I am sure they will update this thread
      09-23-2012, 11:49 AM   #16
Messer-schmitt
Messer-schmitt's Avatar
Drives: 2012 BMW 328i
Just BUMPin to keep this thread on top! Need to hardware my V1 too!
      09-26-2012, 07:56 PM   #17
Jadar
Jadar's Avatar
Serbia
1126
Drives: 2013 F30 335i MSport
I took apart the dome light today and looked around. All the wiring was indeed different, and I saw no green wire with a white stripe like in my e90 so I stopped.
Took the center console aprt to get access to the 12v power plug and the wires would work but they are really fat I dont want to splice into them. Im assuming that the 12v under the passanger side dash board will be the same.
So it looks like the fuse box may be the best option. Lets see What VSmotorsports comes up with.
All the f30 wiring is new and they are also thinner then previous E cars. I even checked under the carpet but I dont wanna go this route.
Do you know wich fuse youre technician piggy backed off of? What really sucks about this is the fuse box is in the trunk now and thats just so much routing to go through...Dammit.
FBO-PS1 and stuff
      11-16-2012, 09:28 PM   #18
cesaroctavio_80
cesaroctavio_80's Avatar
Mexico
Drives: BMW X4
Excelent info!!!!
One question VSmotorsports, do you know how to remove this part? i want to fix a rattle that is gettin me crazy
      08-07-2013, 11:21 AM   #19
nurio
Drives: F30 328i xDrive
Thanks to these instructions I got my radar detector hardwired to the dome light and so far it works great. It’s pretty simple to do once you know how to open the dome light and which wires to tap to in the F30.
The wire I tapped to for power was the white with the red stripe, which is on the long single row connector and I believe that it was the third wire from the left. For anyone who is going try and use this wire I take no responsibility so do it at your own risk and I highly advice to test that wire in their car with a voltmeter. In my car (2013 F30 w. Nav) this wire provides a 12v (~13.5v to be more accurate) delayed switched power similar to the cigarette lighter socket. It can be a bit confusing coming from an E90, when I first got the car I thought the power from the cigarette lighter socket never goes off, but in this car the power turns on when unlocking the car with the remote and turns off I believe about 2 minutes after locking the car so it seemed that the power is always on.
As for the rest I followed the same instructions as in the E90 DIY: http://www.e90post.com/forums/showthread.php?t=97545.
I didn’t take pictures when I did my car, but I’m going to do my friend’s car next, so I’ll try to take pictures and post them when I get the chance.
      07-24-2014, 06:12 AM   #20
kobebrain
Italy
Drives: F31 Sport Line
Originally Posted by cesaroctavio_80 View Post
Excelent info!!!!
had you remove it?
      05-13-2016, 09:21 AM   #21
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Is there any way to replace the ambient light led or do you have to replace the entire module?
      02-20-2017, 02:08 PM   #22
Amit
Drives: 320d ED
dome light wiring help
Hi,
Does anyone have the wiring diagram for the LED dome light fitting with map lights?
I have the standard rear center (1bulb) light / without any switches which just turns on when the doors are opened.
Also, my front dome does not have map lights just the one main light with ambiant light leds and 1 button to turn it off an on.
I have sourced 2x LED versions with Map lights that I wanted to switch over both front & rear domes.
Could anyone please help me out with information on either which wires do what or the Pin outs on these new units.
Thanks guys,
Amit
