BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > TPMS sensors required for winter tires/wheel pkgs?
      08-04-2012, 02:51 PM   #1
wolke9
apexlvr
wolke9's Avatar
Drives: 2010 VW GTI;335i m-sprt ordrd
Does anybody know if you are required to purchase the TPMS sensors when buying an aftermarket winter tire/wheel pkg?
If you don't, I guess there is a light that will flash in the instrument cluster the entire time?? I guess the sensors are like an additional $40 per tire or so.
      08-04-2012, 06:38 PM   #2
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Actually more like $90.00. Each
      08-07-2012, 04:06 PM   #3
bavarianx
bavarianx's Avatar
Drives: 2006 X5 4.4i
Yes, without them you will get an error message.
      08-07-2012, 09:04 PM   #4
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
I believe that they are not needed in Canada, as Canadian low tire pressure is not driven by sensors (at least thats what I've been told).
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      08-08-2012, 03:28 AM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
I have heard this about E9x in Canada but have not heard anything regarding F30. Basically, hub rotational speed relative to the other hubs determines if any corner is low on air, rather than physical sensor in wheel/tire. Audi currently uses this sensor for US cars but BMW has stuck with physical sensors.
TPMS is not required, per se, but you will get a TPMS light on if you run wheels without the sensors. This will have no effect on performance or driveability, so long as you can look past the light in the dash
-Matt
| Z4M Build Thread | @violetnites | flickr |
