BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > "Special" Rims needed to run Run FLat Tires???
Extreme Power House
      08-09-2012, 10:18 AM   #1
martinf79
martinf79's Avatar
62
Drives: F30 335i M Sport
Question -
I'm considering using my M Sport stock 19 rims for winter setup (staggered)... and getting a new set of 19s for summer. Is there any concern about switching the summer rubber (run flats on my stock rims) to the new 19s (assuming rubber will fit rim size, which I have checked). Is there anything unique to the factory rims that may cause issues on the new 19s???
2013 335i ///M-Sport | + 2015 X3 28i xLine
      08-09-2012, 09:55 PM   #2
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
Originally Posted by martinf79 View Post
Question -
As long as the shop you are having the work performed at is experienced with low profile tires, you will not have any issues. The primary difference between a runflat is a significantly reinforced sidewall. A thicker sidewall will allow a wheel to run on a flat tire for a longer time without causing significant damage to the wheel itself.
      08-22-2012, 06:15 PM   #3
scott@bmwhn
Drives: Msport X3
The only time I've seen issues running runflat tires is with cheaper lightweight cast wheels. The reinforced sidewall of a runflat will absorb less impact, thus transferring that impact to the wheel itself making it more susceptible to bends.
-Scott
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
