BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i/335i front bumper REFLECTORS removal / install DIY
      06-17-2013, 05:11 PM   #45
R12ax7
R12ax7's Avatar
44
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
Just did this last night. This is a lot easier on the F30 then it was on the e90.
Also, while it could be due to there being more room in the wheel well on the F30, it seems to me the bumper and wheel well liner were much more pliable possibly due to the fact that my car is brand new. Point is, if you are considering this mod, might be easier to do right away rather than wait (like I did with my last e90).
Very helpful DIY OP.
Side note, I also plastidipped my rear reflectors to match the Msport diffuser color. I will be posting a DIY on the removal/replacement/dipping of those in the next day.
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      09-26-2013, 08:46 AM   #46
schwarzrb
Drives: 2014 328d
Anybody interested in selling their old amber front reflectors?
      12-28-2013, 09:19 PM   #47
Bill-SD
Bill-SD's Avatar
Drives: '07 335i / '14 328i
I just did this today and have a couple additional tips to offer.
If you heat up the old reflector from the inside using a hair dryer, they will come off much easier. I wouldn't use a heat gun because the may melt your bumper cover. A hair dryer is the right amount of hot.
I also have an AW car. After removing the reflectors, the inner edge of the bumper cover is black. After swapping the first reflector, the black from that edge kind of reflected off the new white reflector. Not bad, but I am anal about that stuff. For the other reflector, I painted that inner edge with touchup paint. Much better! For darker color car this may not be an issue. Tip: but the touchup paint online. I ran to the dealer for it at the last minute and it was $45 (after BMWCCA discount)!!! Online I'm sure it's under $30.
Monaco Blue/Saddle E92 335i
Alpine White/Black F30 328i
      01-02-2014, 10:34 PM   #48
Silvershade
Drives: 2013 328i xdrive
Hello Everyone,
Can someone advise where I could find the amber side marker for a 328xi 2013 ?
Thank you !
      04-26-2014, 09:03 PM   #49
BimmerFan79
Drives: 2013 BMW 335xi
I just did this today with smoked reflectors. This guide is great.
I will say that I did not need to screw driver at all, but i absolutely needed a hair dryer. Trying to do it without heating everything first was just a nonstarter.
Thanks!!
2013 BMW 335xi - sport, premium package.
2011 BMW X3 xDrive35i - MSport, premium package, tech package.
2008 BMW 328i coupe - sport package.
      06-03-2014, 06:32 PM   #50
3onDubs
You live by the sword...
3onDubs's Avatar
125
Drives: 2014 F30 328i
2007 328i  [0.00]
Just did this on my msport front bumper...couldn't fit my flathead in there, so had to use my fingertips to pry the reflectors off. Came off eventually, but damn do my fingers hurt today. Hairdryer or heat gun wouldn't have been a bad idea.
      04-21-2016, 12:29 AM   #51
Andrew309us
Drives: BMW 428i
I need help with something if someone would help me? Does a 2015+ model 428i front reflectors work with the 2014 model ones?
      04-21-2016, 01:51 PM   #52
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
I had the same issue and used a hair dryer from the front and got them off in a few minutes. There is not much room for m sport bumpers to get in there with a screwdriver. So glad i did it though. looks a million times better. I also coded my corner lights off when the headlights are on as well. much better.
2013 EB/CR 335i xdrive | DHP | Coded | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      04-25-2016, 09:51 AM   #53
BOOT335
BOOT335's Avatar
44
Drives: '13 F30 335i
Did this over the weekend. I was able to get the OEM markers off pretty easily using some Turtle Wax Adhesive Remover spray and a screwdriver from the back side of the reflector.
But now I'm having a very annoying issue. After cleaning off all the old molding tape and even lightly sanding down the inside of the bumper to get ALL the residue off, my reflectors are not sticking to the bumper all the way. on the m sport, the long edge closer to the wheel has pulled away from the reflector adhesive and won't stay no matter how long i hold it pressed together.
Anyone else have this issue? Thinking about redoing this whole thing and carefully using betalink or something to make the reflector stick all the way around.
      04-25-2016, 10:50 AM   #54
R12ax7
R12ax7's Avatar
44
2011 328i  [0.00]
Never had this issue and have done quite a few of these. What kind of double sided tape did you use? Is it possible the bumper got deformed a bit in prying the original reflector out?
      04-25-2016, 12:36 PM   #55
BOOT335
BOOT335's Avatar
44
I used the tape that came with the reflector. Purchased from ebay seller named "ultimotors" but the manufacturer is HELIX which I've known to be pretty reliable in the past.
The adhesive had 3M logos all over it so I assumed it would be good to go.
I never turned the screwdriver and didn't use heat so I don't think the bumper lost any shape, but it seems like the reflector is completely ridgid and flat where as the bumper obviously has a bit of a natural curve to it.
      04-25-2016, 12:40 PM   #56
BOOT335
BOOT335's Avatar
44
Just found another manufacturer named DEPO, are they supposed to be any better? The 3M tape looks slightly different. Not sure it would make much difference...
      04-25-2016, 02:18 PM   #57
R12ax7
R12ax7's Avatar
44
2011 328i  [0.00]
That's really interesting. Sounds like that is the correct 3M tape I have always used. Actually if its the same Helix I know, they are located near me in Philly and I can tell you first hand they are a reputable shop with a presence on the post. Might consider reaching out to them directly (this is their website, if its the same Helix: http://store.helix13.com/). That being said, I believe their focus is fabricating performance parts, particularly some nice higher capacity inter-coolers for BMW and Mini.
I've heard of DEPO (as i recall they used to make replica "blacklines" for e90s and other lighting products), but I think most people would consider the IND painted reflectors to be the benchmark - they are probably a bit pricier but worth it in my opinion. Also, I think you are right that there is a slight natural curve to the reflectors having just removed my painted ones and reinstalled the OEMs - both had that slight curve.
Maybe you can use some heat to bend these to a better shape? Obviously be careful not to mess up the paint though.
      04-25-2016, 02:49 PM   #58
BOOT335
BOOT335's Avatar
44
Yeah Helix was also a solid brand for aftermarket exterior pieces in the VW community where I'm coming from.
I've reached out to the seller to see if maybe I just got some defective set or one that had been sitting on the shelf too long. I just ordered the DEPO ones now to see if they follow that natural curve. The reflector piece on the DEPO ones also seem to be a little bit smaller and in line with the OEM style.
I thought about heating them but kinda makes me nervous. I think at worst I will end up trying to apply some betalink very carefully.
I'm so OCD about this stuff lol. The IND color matched ones seemed like a good option but I didn't like the way the gap was "too" close as pointed out earlier in the thread.
      04-25-2016, 04:07 PM   #59
R12ax7
R12ax7's Avatar
44
2011 328i  [0.00]
Nice, yeah sounds like its probably a different Helix than the VW one anyway. Good luck with the DEPOs (and/or the beta link)!
      05-03-2016, 08:09 AM   #60
BOOT335
BOOT335's Avatar
44
Just an update for anyone else who finds themselves in the same predicament as I did...
If you don't go with color matched IND reflectors don't buy HELIX reflectors. They are flat and don't follow the curve of the bumper (like the blade of a hockey stick but not as drastic).
I haven't installed the DEPO ones yet, but I just took them out of the package and I could immediately tell it had an OEM like curve to it so I'm much more optimistic about these. Will report back with a fitment update tonight.
EDIT: Installed them during lunch. Depo ones fit great. Very very close to OEM and not a single area where there is a gap with the adhesive due to the shape like the Helix ones.
      11-14-2016, 01:00 AM   #61
SMiGGs
Drives: Msport
If any of you want to save money, just buy a small piece of white vinyl wrap, and wrap the reflector, and reinstall. It looks much better too, no yellow tint. I just reheated the old glue too, and stuck back on there.
If the vinyl comes off, i might just mask it off, and paint it. I bought ebay reflectors, and shipped them back, got a replacement, and sent those back too, for some reason they look yellow
3 series f30, 3 series f30 diy, 3 series f30 forum, 3 series forum, bmw 3 series diy, bmw 3 series forum, bmw 3-series f30, bmw f30, bmw f30 3-series, bmw f30 diy, bmw f30 forum, bmw f30 reflectors, bumper reflectors f30, diy f30, f30 3 series bumper whiskers, f30 3 series diy, f30 3 series reflectors, f30 3 series reflectors diy, f30 3-series, f30 3-series forum, f30 bmw diy, f30 bumper reflectors, f30 bumper reflectors diy, f30 bumper whiskers, f30 diy, f30 forum, f30 forums, f30 reflectors, f30 reflectors diy, f30 whiskers
