BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Mud Flaps, anyone adding them?
VIBE Motorsports
      08-12-2012, 04:47 PM   #1
JamesMA
JamesMA's Avatar
20
Drives: 2013 F30 335i M Sport
I was talking to me father in law and I mentioned that mud flaps were available as an add on. He said that he had them on his old '84 320i and that they really did make a difference for keeping crap off of the lower part of the car.
They are less than $100 front and rear and seem to be an easy install if I can't get the dealer to throw them in with the car at delivery.
Anyone have any thoughts from personal experience on the mud flaps?
2013 F30 335i 6MT M-Sport - Blk Saph. / Beige Lthr / Wood Tr. - Tech Pk - VSS M-Adp. Susp. M-Perf Stainless Exhaust M-Perf. brakes
      08-13-2012, 08:23 PM   #2
JamesMA
JamesMA's Avatar
20
Well, I am told they will not fit an M-Sport b/c the aero kit gets in the way. So much for that idea.
      08-14-2012, 10:46 AM   #3
NiceNotRiceBMW
Drives: 2012 Mineral Grey Sport 328i
I've recently been looking into these as well.. I'm concerned about how they will make the car look. I don't want to make it look like "my moms car" . I really want to keep the sporty look , but at the same time the mud is the worst.
      08-14-2012, 08:55 PM   #4
E90jp
Drives: Melbourne Red 2012 F30 335i
I've got'em on my car. I think it looks alright and helps protect the paint. I've never owned a BMW before so I thought I'd take an extra step to protect the paint.
      08-18-2012, 08:55 PM   #5
GR8DAY
Drives: BMW 328i 2013
I installed them at the dealership last week. It's quite low profile.
      08-19-2012, 02:06 AM   #6
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
F30jp or GR8DAY, Any photos? Really considering these!
      08-19-2012, 02:48 PM   #7
E90jp
Heres some I just took. Sorry for the quality, its just my phone.
      08-19-2012, 07:48 PM   #8
JamesMA
JamesMA's Avatar
20
Nice! I would do that if it would fit!
      08-20-2012, 02:19 PM   #9
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Thanks for the pic!
      08-25-2012, 10:19 PM   #10
RPM90
Drives: 340i M-sport AT
I'm going to try and install them on my Msport, which should be here any day.
I asked for a set as part of the deal.
Some say they won't fit an Msport, but most of the different body work is in front, and the area where the flaps go looks to be the same.
On my 135i they also said that the front flaps wouldn't fit due to the different front of th 135i vs the 128i, but they fit just fine.
I'll post a pict if they do fit on an Msport.
      08-28-2012, 02:15 AM   #11
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
that's a no go for me. doesn't look too bad tho
the only thing in this world that gives orders is balls. You got that? Balls.
      09-01-2012, 11:42 PM   #12
pohlease
Drives: 2012 F30 Sport
Does installing mudflaps require drill or are the holes already there?
      09-03-2012, 10:17 AM   #13
diesel86
Drives: 2012 BMW 328i Sportline
No drilling required. The splash guards use existing holes/hardware already in the wheelwells.
Here is a quick iPhone pic I took shortly after installation.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      09-03-2012, 09:50 PM   #14
JamesMA
JamesMA's Avatar
20
FYI, when my parts guy went to order, the computer told him they were a no go for the M-Sport, he showed me the screen.
Let us know how the install goes.
      09-08-2012, 04:45 PM   #15
RPM90
I dry fitted the mud guards and they fit just fine on the Msport. Perfect fit actually. I think the computer info is wrong or not up to date.
The problem is that the rears only came with 4 screws, but 2 go in the bottom of one guard, there is one existing that is used, and then there are 2 more holes in the guard and the inner wheel well.
So, you need 4 new screws each 8 total and my set only came with 4 for both.
I can get them mounted without the 2 inner screws. It feels like it will hold especially with the double sided tape. But I'll see if the shop can give me 4 more.
      09-08-2012, 04:47 PM   #16
RPM90
How many screws came with your rear set?
Mine came with 4 total for the rears, and 4 push-in tabs for the fronts.
Seems to be enough for the front using those and existing push-in's, but seems I'll be 4 light for the rears, unless I don't use 4 per guard.
      09-09-2012, 11:08 PM   #17
diesel86
Mine came with 2 new screws for each side. The part of the flap that attaches inside the wheel well used existing hardware. The two self-tapping screws I used for for the "extension" part of the flap toward the rear. Those go into the plastic cover under the car...at least thats where I put them. If they don't, the underbody panel under the trunk now has 4 new drain holes.
      10-22-2012, 12:08 PM   #18
Quackdiesel
Corleone
Drives: 2014 X5 35d M Sport
Could we please get pictures of the mud guards fitted on an m sport? I am curious to see what it looks like. It sounds like fitment isn't an issue.
      10-25-2012, 03:40 PM   #19
bnekic
Drives: 2013 328i xDrive Sport Line
Yes I'll be adding them because if you look at the car from behind the tires stick out from the rear bumper so they will kick up debris onto the car.
      10-26-2012, 07:06 PM   #20
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
ugh, will look ugly...
SOLD: 2012 335i Mineral Gray
      10-29-2012, 09:48 PM   #21
avl515
Drives: F30 328xi
im not going to be adding them cause i don't like the way it looks and as for paint damage to the car, i am getting a clear bra put on right away so i won't have to worry about that
      12-06-2012, 02:39 AM   #22
DeoJor
a///M azing :)
South Africa
Drives: 2012 F30 MotorsportA
2009 BMW e92  [3.00]
Has anyone fitted these on a msport yet? Pics?
2012 F30 320i M Sportpack, Alpine White, Xenon, PDC, black kidney grills, CF Roof, CF Mirrors
