BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Did engine oil change (328i) myself today
European Auto Source
      10-04-2012, 06:36 PM   #23
JPC Moose
Drives: 2012 F30/N20Sport /Silver
Originally Posted by rado View Post
Yes, the plastic drain plug takes an o-ring. The BMW replacement oil filter included a plastic bag with replacement o-rings *and* a metal crush washer, but there was no need for the metal washer. I assume some other model takes the same oil filter and has a conventional metal oil plug (and pan) that takes the washer.
BTW, a low range torque wrench and 3/8" hex driver (socket) is good to have for reseating the oil drain plug, as the tightening spec (marked on the plug) is only 7 N-m (62 in-lb). You could do it by feel, but the tendency would probably be to over-torque it.
HTH,
I guess I'll be going back to get the correct o-rings and oil filter. I bought six quarts of oil and an oil filter and he gave me a metal flat washer lose with the filter.
Thanks for the info
      10-05-2012, 08:32 PM   #24
RyanCT
Drives: 2015 F30 335i
Originally Posted by JPC Moose View Post
What type of drain plug? The parts dept gave me a metal flat washer for the plug. This baffles me for I saw on another sight that the plug took an o-ring. It amazes me that there is disparity from one BMW parts dept to another.
HTH,
You're kidding. 5 ft-lbs??? If its on the plug I suppose...
Ryan
2015 F30 335i
      10-07-2012, 07:24 PM   #25
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by Mrcarcrazy View Post
BMW only cares that the car functions flawlessly til the end of warranty....after that it's not their problem. Think about it for a second.
Absolutely everything passes through a cost/benefit calculator. If cost> benefit, then x doesn't happen. If Benefit to BMW > Cost then x does happen.
Oil changes are a perfect example. Oil has improved, filters have improved, engines have improved....the years of 3k oil changes are gone. However how much you are willing to go over that is your choice. BMW says your car will be fine til the end of its warranty with 15k oil changes....So if not owning past warranty who cares? If you plan on keeping it past warranty then you should care and possibly think on your own vs. trusting other people.
Was watching the N20 build video and came across this thread. Of course everyone is entitled to their opinions but one should at least become familiar with the ACEA and their specifications. Specifically A3/B4 and C3*
*Euro owners who have low sulphur high quality petrol.
      10-19-2012, 02:03 PM   #26
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
Originally Posted by h42492 View Post
Hi, i'm planning to change engine oil by myself too for every 5000km since 20000km is too much for me. and i hear some people say that if i change engine oil myself the computer system will some how have some problems, like always showing engine oil has problem or whatever, so do you mind to tell me how did you avoid those problems with the computers? thank you very much
you just wont be able to reset the oil change interval programed into the car.
for example if your car says at 20 000kms you need an oil change and you change it at 15 000kms, when you hit 20 000kms the computer will still put out a warning light saying you need an oil change.
you need to get someone to code the light away or i think the secret menu can reset oil change intervals (not eben sure if f30s have them, im still waiting for mine to come in).
      11-13-2012, 12:38 PM   #27
granny
Drives: 2013 328i x drive
Different undercarriage on 2013?
[My 2013 328i has a different undercarriage-extended steel piece to shield oil pan. Also, now uses regular oil plug and crush washer. Oil drain in same location?
      11-13-2012, 01:24 PM   #28
jwilly
Drives: They're all white now.
Pics, build date?
My 2013 September build date does not have these.
Thanks,
Joel
That's a lot of white
      11-15-2012, 01:55 AM   #29
CKau
Drives: F30 328i
As i am waiting for delivery of my f30 i want to know if the oil filter is easy to replace? Anyone know where it is located?
Is it a widely available design or a newer / proprietary one?
328i aus spec |M adaptive suspension|sunroof|sport seats|self parking|extended display | aftermarket sound insulation
      11-19-2012, 11:37 PM   #30
SamE30
BMW Certified Technician
Drives: 84 325e 2.8L PTE6262
F30's need to be connected to an ISID (BMW diagnostics) to reset the CBS.
It is right on top of the engine on the driver side. The dealer sells them, not too expensive.
      11-20-2012, 02:59 AM   #31
CKau
Drives: F30 328i
Thanks. I'm a bit confused as what to replace. I refer to this thread... mine putting your thoughts over there?
Thanks again!
http://www.f30post.com/forums/showthread.php?t=759977
      11-20-2012, 02:34 PM   #32
SamE30
Thanks again!
Replace #3 and #13 then re-use #2 and torque.
#3 is the filter
#13 is the thick O-ring
      11-20-2012, 04:24 PM   #33
rado
Drives: F30 328i M Sport
No, not kidding, and yes, it's written on the plug. It's a plastic plug, threaded into a plastic oil pan, so it doesn't take a whole lotta torque.
-Ed
2013 F30 328i M Sport
2008 Lotus Exige S240
      11-20-2012, 04:38 PM   #34
rado
I'd love to see pics of that, because your description doesn't match my late-July build 2013 328i.
-Ed
      11-20-2012, 04:50 PM   #35
slmdgee
Usofstance
Drives: 328I 6SPD
How high is our oil pan? Is it strong enough to take a hit? I am looking to slam my car.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      11-20-2012, 09:29 PM   #36
SamE30
N20's still have aluminum pans and a steel plug. You may be referring to the transmission pan that's plastic.
      11-21-2012, 02:40 AM   #37
's Avatar
73
Drives: ✚
The oil pan on my 335 is reasonably high. I imagine the 328 should have the pan in a similar position. I think it's high enough that you'll catastrophically damage other things before you damage the oil pan. Basically, when you're riding slammed, the oil pan will only be a fractional part of many worries. Good luck.
      11-21-2012, 06:47 AM   #38
rado
I've changed my oil, and the oil pan (and plug) are most definitely black plastic. I have a US 2013 328i with 6MT (model 133N according to the build sheet), and the label on the hood says "ULEV", *not* "SULEV". So either you are wrong, the BMW docs are wrong and I have an N26, or they have changed the oil pan on the N20. Which do you suppose it is (seriously)?
      11-21-2012, 11:12 AM   #39
rado
I did a bit more research, and I think I've found the explanation. From browsing the RealOEM parts database it appears that all F30 328i N20's and N26's have a plastic oil pan (and plastic plug), the F30 328iX N20 and N26 have metal oil pans (and metal plug). I was assuming it was an N20 vs N26 issue, when in reality it's a 328i vs 328iX issue.
-Ed
      12-07-2012, 06:38 PM   #40
slmdgee
Usofstance
Drives: 328I 6SPD
so ur saying the 328i rwd 6mt has a aluminum oil pan?
      12-11-2012, 11:49 AM   #41
S-Dot
Drives: 2013 328i xDrive Luxury
I don't read it that way. I read it as:
XDrive 328i - metal
RWD 328i - plastic
      12-11-2012, 06:49 PM   #42
slmdgee
Usofstance
Drives: 328I 6SPD
thats odd.
      12-31-2012, 04:03 PM   #43
diesel86
Drives: 2012 BMW 328i Sportline
Did my first oil change yesterday at 6200 miles and other than having to jack up the car on to my ramps, it was pretty uneventful. One thing I noticed is that this car is low!! It doesn't seem any lower than my previous car (lowered VW GLI), but even after the car was on the ramps, I had very little room to move around. Maybe it's the full-length underbody tray, but I felt a little claustrophobic down there.
Filled mine up with Mobil 1 0W-40 Euro formula. Found it at Wal-Mart for $6.99 qt. Was a little hesitant to use the 40, but since I live in PHX and my car is inside mostly, I figured I'd be fine. One thing I wonder is that since these are out of "Scheduled Maintenance" changes, couldn't I just use an SM rated oil not specified by BMW. I mean, the BMW LL is supposed to be used because they figure that most owners only change oil based on when their car tells them to, so maybe it has to last longer, but since I'll change mine somewhere between 5-7.5k miles, do we really need to hunt around for the pricey Euro-formula stuff?
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      12-31-2012, 04:36 PM   #44
rado
XDrive 328i - metal
RWD 328i - plastic
That's correct.
-Ed
