BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Stock exhaust vs. M performance
      10-29-2012, 05:58 PM   #67
omarliendo
Drives: 2012 335i Sport Line - Red
Originally Posted by Mrcarcrazy View Post
Assuming you mean HP/Tq improvements?
this is very simple to answer. Under Dyno Conditions the flap is open. so wiring it open all the time makes no difference.
There is one reason for this "mod" - to increase the volume of music your engine produces.
There's threads on here w/ sound clips. the M exhaust isn't going to be as loud as aftermarket....but it's noticeably louder than OEM
MrCarCrazy, that is what i meant, will performing this mod by myself will increase the music from the engine? Do you know if think it would a noticeable difference in sound?
      12-01-2012, 03:19 AM   #68
NiceNotRiceBMW
Drives: 2012 Mineral Grey Sport 328i
Originally Posted by justinnum1
Originally Posted by AntBabeee View Post
What do you mean by $400 residualized?
the price is $1335 installed. but only $935 goes into my lease.
How?
      12-01-2012, 11:45 AM   #69
justinnum1
Drives: 2015 328i Msport 6mt
How?
Port installed accessory.
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      05-02-2013, 10:20 PM   #70
The Nerd
The Nerd's Avatar
70
Drives: 2013 BMW 335i Dinan S2 (MPPK)
Originally Posted by fshubert View Post
So you don't throw a code, don't unplug. If you look at my actuator picture, you will see two opposing cylinders in-line with one mounting screw. The spring clip comes out with a pair of needle nose pliers. You'll see on the upper cylinder the wire I wrapped thru it to keep it open. This way the car does what it wants but you've kept the exhaust where you want it. Just did a lousy recording with the Blackberry and will try to upload it. Apologies in advance for the poor quality.
Fshubert....if I have the MPE installed on my 335i at the dealer, will it require them to recode anything? Or is it simply saw off the old, clamp on the new? It seems all of the talk about the actuator wiring (which is attached to the stock exhaust) would throw a code when they unattach from the old exhaust and reattach to the new. I only ask because I don't want BMW messing with any codes on my car for the time being. I just had the PPK installed and don't want the headache of them "accidentally" erasing it.
