BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Will the e92 19 inch M3 rims fit F30 328i?
      08-24-2012, 03:00 PM   #1
momo3605
Drives: 2016 M4
I believe the tire width would be 235 front and 265 rear.
I don't really understand offsets and stuff, so does anyone know the answer to this?
      08-24-2012, 05:38 PM   #2
momo3605
Drives: 2016 M4
These are the widths of the rims
19" Style 220
Front 8,5J ET:29
Rear 9,5J ET:23
      08-24-2012, 06:38 PM   #3
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
have you tried using the offset calculator-it's somewhere on here (this prob doesnt answer ur question but..) that will be ur best bet to start. good luck, and post some pics if u decide to run this set up!
the only thing in this world that gives orders is balls. You got that? Balls.
      08-24-2012, 07:05 PM   #4
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
19" Style 220
Front 8,5J ET:29
Rear 9,5J ET:23
The quick answer to this is no, they will not fit properly.
Without going into much detail I can say these wheels will stick out too far and cause the tire to rub on the fender.
      08-24-2012, 07:14 PM   #5
momo3605
Drives: 2016 M4
Ohh, dang that sucks, but why would this be the case?
If you look at other threads, some guy just posted about 20 inch rims with 245 in the front and 275 in the rear fitting fine, and another guy has 19 inch M5 replicas with 235 front 265 rear, and they are fitting fine for him as well.
      08-24-2012, 07:58 PM   #6
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
its bc of the offset. the lower the offset the more they stick out in simple terms..try doing some research of your own on this to get a better understanding
