BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > How often do you check the presure in your Nitrogen filled Run Flats?
Extreme Power House
      08-28-2012, 03:07 PM   #1
islandjm
Drives: 2012 328i Sedan, Luxury, Imper
Send a message via Skype™ to islandjm
Question How often do you check the presure in your Nitrogen filled Run Flats?
I'm new to Nitrogen filled tires. I'm new to driving on Run Flat Tires. How often should I check the presures? Should I use my standard tire gauge?
      08-28-2012, 06:26 PM   #2
brian99997
Drives: slowly
Are your valvecaps green or some other special type? My car was not delivered with nitrogen.
The TPMS sensors are fairly sensitive so I wouldn't bother checking them until you see a light.
      08-29-2012, 02:41 PM   #3
islandjm
They are white with an "N" on them. My last car, a CTS, actually gave you the presures in each tire, which was helpful. Run Flats are so pricey I want to take care of them.
      08-29-2012, 03:30 PM   #4
richb811
richb811's Avatar
312
Drives: 2011 E92 JZB M3, 2000 750iL
Still check mine once a week. Probably less than I should, but I am anal like that.
