BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Steering Wheel Creaking/Squeaking Noise
Extreme Power House
      09-02-2012, 03:48 AM   #1
rocko911
Bahrain
Drives: 2012 F30 335i Sports line
Unhappy Steering Wheel Creaking/Squeaking Noise
Hey guys, I own a 335i sports line and just noticed whenever i turn my steering wheel left or right I hear a creaking noise. The noise is soft but definitely noticeable. I ve researched over here and noticed that some other people had the same issue. Is there any fix to this issue? Thanks
      09-03-2012, 01:13 PM   #2
npgatech
npgatech's Avatar
Drives: 2012 BMW 335i
Yup, I got that a few times. Just adjust the steering wheel column and pull it out/push it back in. It took me a while to figure out where the squeaking is coming from! At particular lengths of the steering wheel column, may be an O-ring or something is causing the problem.
      09-03-2012, 01:26 PM   #3
rocko911
Bahrain
Thanks man for your help, let me check that out. I drove it today and did not hear anything. I guess it starts making a sound when your re turning the wheel completely on the left or right. So for you the sound is gone after you did that?
      12-12-2012, 12:04 PM   #4
BLAZEDV3
Drives: 335i
I experienced this issue on my e92 and after researching I found that the issue is due to the brake sensor in the wheels touching when you turn the wheel. Nothing to worry about.
      12-12-2012, 01:04 PM   #5
nick2013328i
nick2013328i's Avatar
Drives: 2013 328i
This was happening in my last car (2010 Camaro) looked to be rubbing the rubber boot at the bottom (I have steering wheel all the way down). So I sprayed a quick shot of lubricant right there and all problems were solved
      12-12-2012, 02:18 PM   #6
jsbmw87
Gear Head
Drives: 2016 M4
Having my service center take a look at this exact issue on mine today. I'll let you know the results.
2016 M4
      12-12-2012, 03:45 PM   #7
David328M-Sport
Australia
62
I had the same thing in my E90 early on, back in 2005. Was most annoying as it was quite loud. It either went away or I had it fixed. Cant remember.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      12-13-2012, 04:49 PM   #8
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I just noticed this last night...it's really odd.
Any real fix?
I'll push the column in a little...my wife noticed it too, and she has the column in all the way. So I think it's independent of the column.
SOLD: 2012 335i Mineral Gray
      12-17-2012, 11:06 AM   #9
Erik.klenke
Drives: 2012 328i Sportline
So what did the Dealer say about it? I have the same problem and have been thinking about taking it in to the dealer.
      12-17-2012, 11:12 AM   #10
rocko911
Bahrain
Well I havent taken mine to the dealer yet since I havent found it very annoying because its not very loud but after finding spots of rust under my seat Im going to go soon and show both problems now :S
      12-17-2012, 11:58 AM   #11
shivaswrath
Drives: 2012 335i
yeah mine went away once it started raining heavily here...I wonder if it's something in the exterior, not interior?
      12-17-2012, 06:11 PM   #12
jsbmw87
Gear Head
Drives: 2016 M4
Apparently my "thrust arm bushings" weren't prepped correctly from the factory. They're on a 3 week backorder, just playing the waiting game now.
2016 M4
      12-18-2012, 12:32 AM   #13
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Just a side note. Make sure you do not exert all kinds of force on your steering wheel as you exit the car. Over time, this practice can lead to squeaking.
The steering wheel is a sensitive instrument and it is not a door handle.
Once I let a big guy sit in the driver's seat of my 5 series. As he exited it, you could actually see the entire wheel bending and twisting as he put his 350 lb weight on the steering wheel to exit the car.
      01-04-2013, 05:14 PM   #14
godfather87
Drives: 2013 335ix
If u don't mind me asking, did u get it checked by the dealer? i started having the same issue on my car. i usually have music on but its def annoying when theres no music playing.
      01-04-2013, 08:52 PM   #15
rocko911
Bahrain
No I haven not taken it to the dealer yet, been busy lately. Well with music on you cant hear it but its quite noticeable when music is turned off. I tried adjusting the steering wheel but the sound is still there. You better take it to the dealer to check it out and see whats the issue. Lot of people have mentioned this problem here on the threads
      01-08-2013, 11:38 AM   #16
Elastino
Drives: F32 435i ZMM/ZTP/LED
Send a message via Skype™ to Elastino
Same here with 335i 2012 Apr.
I think it is related to VSS.
It sounds like out of oil gear noise.
I went to dealer with this issue and they completely replaced steering wheel core(rod).
The replacement did somewhat improvement for a month but it came back.
Currently I send my car back to the dealer for this issue.
I will post it if I get new treatment on this.
2015 F10-LCI 530D xDrive M Sports Package Black
2014 F32 435i M Sports Line Black
2012 F30 335i Sports Line Alpine White (retired)
2011 F25 X3 28i Silver
2010 E83-LCI X3 3.0 Silver (retired), 2007 E90 328i Gray
      01-08-2013, 12:34 PM   #17
shivaswrath
Drives: 2012 335i
I had the creaking/moaning issue on my 335i.
Dealer took steering wheel out, greased specific parts, and everything is fine.
Parts weren't replaced. It was a simple fix and no issues now.
      01-08-2013, 01:48 PM   #18
godfather87
Drives: 2013 335ix
good to know, i live an hour an a half from where i bought the car, can i take it to any dealer or is it recommended to go back to where i bought the car from?
      01-08-2013, 03:20 PM   #19
shivaswrath
Drives: 2012 335i
any dealer since it's a warrantable issue.
Just make sure as $hit you can duplicate the issue once the SA sits in the car with you (or have a tech drive along with you, which is what I did).
You have to book that ahead of time, and usually, I've noticed you'll get better preference at the dealer you purchased from...
      07-02-2014, 04:52 PM   #20
vip
vip's Avatar
Drives: 2016 Golf GTI SE
I had this repaired a few months back and now the sound is back....
Current: 2016 GTI SE
Past: 2012 335i (f30), 2007 335i (e90)
      07-02-2014, 05:42 PM   #21
OC40
Drives: 335i MSport + MPS/MPPK
2013 MINI S  [0.00]
2013 BMW 335i  [0.00]
Really? Had mine fixed over a year ago and it's been fine. Hopefully, it doesn't come back for me.
      02-19-2015, 03:36 AM   #22
Jera_Jakerz
Jera_Jakerz's Avatar
Drives: 2014 BMW 335i xDrive
I guess I am bringing this thread back alive, but I noticed it only on one side. When I turn to the left its the amazing BMW ultimate driving machine I originally purchased. When I turn to the right its NOT GOOD.
The right turn makes noise at about 1/8th of a turn until 3/4 turned and the entire time to the right its rougher, almost like there is dirt or something rubbing, but it is inconsistant and not at all when turning to the left which boggles my mind and makes me think it has something to do with the 0010100100001100 of the eletric steering.
I live close to a dealer so I am going to go there and ask them to do a couple of your suggestions, but did anyone notice the problem on one side only?
