BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Alignment Lessons Learned
Extreme Power House
      09-05-2012, 08:42 AM   #1
mocohead's Avatar
Drives: '16 M235i 6MT & 12 128i Msport
I took my car to West End Alignment in So Cal (a renowned race alignment shop) with a couple of goals:
1. Install e90 M3 front lower control arms to get more negative camber, and
2. Take out the pins on the top of the shock tower to get more negative camber in front
Both goals were not achieved. While the e90 M3 control arm was the right length and general shape, the bushing at the rear of the arm was too wide to fit the mount on the chassis. It didn't really look like you could punch out the existing bushing on the M3 piece so we didn't bother. Hopefully some day somebody will develop a replacement bushing that will fit our cars.
As for the shock tower pins these could be knocked out BUT unlike on all previous BMW's the shock tower bolts did not thread into slotted holes. That means that the top of the shock is not adjustable for camber.
In the end I left with .5 degrees negative camber in the front, 1.5 in the back. This was a somewhat disappointing result.
The car also has a lot of caster (6.5 degrees) which might explain, in part, some of the steering vibration issues. BMW puts in that much caster to gain steering feel, but it may be causing some wheel hop as a result. If you are experiencing steering vibration please consider reducing air pressure in the tires to 3-4 psi below the recommendation in the door jamb.
      09-05-2012, 09:14 AM   #2
Drives: slowly
the aftermarket coilovers need shock top hats with slots like every other bmw has available, until that we are stuck. technically you could cut some, 2 degrees is 2 degrees
you are spot on about caster as well but i doubt we can mod that because of the knuckle. i ended my last track day at 28/30 psi cold and it does help street feel for sure
      09-05-2012, 09:20 AM   #3
Drives: Msport X3
Interesting...thanks for the information
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
