BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > HID in Halogen (Worked!)
      10-26-2012, 09:34 PM   #23
Accelerometer
Accelerometer's Avatar
Drives: 11 E90 M3 ZCP
I hope you realize you are blinding oncoming drivers with your "retrofitted" HID bulbs. You never drop an HID bulb in a free form halogen reflector housing. The light sources are completely different and not interchangeable.
      10-29-2012, 06:00 PM   #24
NiceNotRiceBMW
Drives: 2012 Mineral Grey Sport 328i
Originally Posted by Ecmiyake
Just installed the HID kit on my 2012 320i, no flickering and no system malfunction code. I bought the kit from this ebay seller for $35 bucks. Make sure you order the H7R kit, the R kit is supposedly designed for halogen headlights to reduce glare. Here is the advice for those of you having trouble removing the H7 bulb. make sure you leave the connector connected to the bulb, then you hold onto that and pull the bulb out by tilting the bulb from the bottom. my left side came out quite easy, then the right side is a little tight. I believe the H7 bulb is pressed fit into the bulb holder.
Also installed the LED Parking lamp. no error either.
http://www.ebay.com/itm/270921200523...84.m1439.l2649
Where did you find the correct daytime running light led bulb?! I can't find it anywhere : can you post a link where you brought it from? Also what kind of bulb is it?
      11-04-2012, 07:37 PM   #25
TK427
TK427's Avatar
Drives: 2105 335i XDrive
Originally Posted by persean View Post
That looks really clean!
Are there HID's in red? Or do I just have to do a regular red bulb?
I am thinking of putting red for my fog lights.
Its illegal to have forward facing red lights, as they could be confused for brake or tail lights.
      11-10-2012, 01:36 PM   #26
Ecmiyake
Drives: 2012 320i
Originally Posted by bmwm311 View Post
where did you mount the ballasts? I can't find instructions anywhere on how people are installing them.
Thanks!
i just tie the wire hardness and ballast together once the bulbs are installed, and tucked it inside the headlight housing before putting the round plastic dust cap back on. I've got the slim ballast HID kit, so it will fit right in there.
      11-10-2012, 01:44 PM   #27
Ecmiyake
Drives: 2012 320i
Actually, since i've installed this kit, i havn't got any high beam flashes from on coming traffic yet. The BMW light housing is designed to aim the light down, if you look inside, there's a metal sleeve surrounding the light bulb, that's to reduce glare.
I've found the only time the light will cause glare is when the light is dirty. that's why headlight washer for cars equipped with HID is mandatory in the earlier days. so, just make sure you wipe your headlight clean even if you can't wash your car.
      11-10-2012, 01:47 PM   #28
Ecmiyake
Drives: 2012 320i
Originally Posted by ohmymayo24 View Post
hey could you link me the parking light bulbs you got?
sorry, after 60 days, don't have the ebay sellers info anymore, just search H6w error free, and find a seller that has the highest rate, you should be fine. the two bulb only cost me like $4 together.
      01-16-2013, 07:50 PM   #29
DXL XLR8
Drives: F30
Ok so I got some HID's and I thought taking out the bulb and installing the HID's would be a piece of cake, but I can't seem to figure out how to lock the lowbeam bulb back in place. I tried everything and went at it for hours, did I bend the clips when i pulled it out?
Any suggestion would help greatly. Thanks.
      01-16-2013, 09:43 PM   #30
SJ00
SJ00's Avatar
Australia
139
Drives: 328i
i would appreciate a step-by-step DIY guide too, im not ready to spend $250 (local quote), but im also not confident in doing it myself..
      04-24-2015, 03:54 PM   #31
djviciousmtl
Drives: 2014 320i
Has anyone tried this on a 320i 2014?
      04-24-2015, 04:01 PM   #32
smithf80
smithf80's Avatar
Drives: '16 F80 M3 6MT
Send a message via AIM to smithf80
this is a bad idea.
Currently F80-less. Incoming 2018 Individual Hera Mica Blue on Cohiba Brown
