BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Ground location for aftermarket amp
      09-05-2012, 11:14 PM   #1
NateDog07V
Drives: '13 335i M-Sport BSM/CoralRed
Anyone located a good spot to run a ground wire for an aftermarket amp?? Towards the front section of the trunk (near the seats) would be preferable. I haven't really looked back there much yet so sorry if there is an obvious location.
BTW, I totally didn't realize the battery is in the trunk! Should make running the battery lead a heck of a lot easier than to under the hood which i've done on all my old cars. I'm installing a Alpine MRP-M500 and 12" Alpine Type R to beef up the stock HiFi system
      09-06-2012, 10:48 AM   #2
JYohay
Drives: 2011 X5
just use the battery negative terminal.
i am running this and have no interference
      09-06-2012, 11:02 AM   #3
NateDog07V
I think the ground wire in my amp wiring kit is only like 3 or 6 ft long though which won't reach unless i mount my amp behind the carpeting near the battery somehow.... where did you mount your amp ?
      09-07-2012, 01:26 PM   #4
Kaitain
Drives: Estoril Blue II F30 M Sport
So go to an audio store and buy a 10 foot grounding cable that is 2 or 4 gauge, for $15 and you no longer have this problem....
      09-11-2012, 05:38 AM   #5
Ermagerd
Ermagerd's Avatar
Drives: a huffy
What size amp are you running? If you're going to make a long run to the battery, I'd use at a minimum 2ga. If it was my own car, I'd run 1/0 to the amp, no matter if it's a 600 or 1800 watt amp. Long story short, long runs on those cables really increase resistance.
