BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Heater failure/not working
      09-09-2012, 12:37 AM   #1
RPM90
Drives: 340i M-sport AT
Only under 500 miles and looks like I'll be heading in for service.
Went for a drive tonight to check out some different settings with driver mode and adaptive suspension. It's in the upper 50's out here.
Set the HVAC temp to 73F, fan about half way. Cool air blowing.
Car was cold, so I kept driving.
A bit later as oil temp is between cold and normal, still no warm air.
Set the temp to 77F. Blowing cold air.
Set to full 84F. Cold air.
I even turned 'auto' mode on, no good.
While driving around with no heat, and testing out driver modes, the sport mode config would grey out the options, and I couldn't make changes.
I switched back to comfort then back to sport, the options were again available. A minute later they would grey out again.
Strange.
I'm sure this is one of those one-off failures, but just curious, anyone else try their heater in their newly delivered 3 series?
So now I've got no heat, sport config acting stupid, added to my steering/steering wheel not locking when I shut the car off.
Gotta get to the dealer.
While there I want them to fix my exhaust tips too.
When I went to pick up my 335i I noticed the tips weren't even, one of them sticks out about 1" farther than the other, and they aren't level. No biggie it's just cosmetic. I figured they could look at it if/when something big comes up. And now it has.
Oh well. It happens. I still love my 335i Msport.
      09-09-2012, 02:20 AM   #2
live4wknds
Drives: 2012 328i
The steering wheel is supposed to lock? I don't believe mine locks when car is off.
      09-09-2012, 02:58 AM   #3
RDowson
RDowson's Avatar
Scotland
64
Drives: F30 320i LCI (B48) M Sport
The manual transmission version does. Apparently.
      09-09-2012, 03:12 AM   #4
ChiefBroady
Drives: 2013 328i M sport
Yes ist does. Mine locks itself quite audible when I climb out of the seat.
2013 328i M-Sport, EB2, DHP, Adaptive Xenon, CA and some other stuff.
      09-13-2012, 05:55 PM   #5
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
My heater does not seem to work either.
M Sport Line Estoril Blue
      09-13-2012, 07:02 PM   #6
jpoet
Drives: 2013 335i M Sport
You are a previous BMW owner, right? So you know that you also need to rotate the dial under the "central locking" button, from blue to red?
I only ask, because you didn't mention that step in your list.
2013 335i ///M Sport, Estoril Blue II, Dynamic Handling, Sport 8AT
      09-13-2012, 08:31 PM   #7
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
I dont want to offend but I think the temperaturre dial might be your issue. I atleast hope Im right. It makes a huge difference.
2015 M3 Alpine white, shakir orange
carbon roof, black 19's, lighting, executive, HK
side&top view, adaptive susp, mods to come......
      09-13-2012, 11:17 PM   #8
dbpe
Drives: 2013 335xi M Sport
Same happened with mine, and it was intermittent - they diagnosed it and will replace the sticky water valve on Monday. No biggie - I'll just turn on the seats and steering wheel till then!
2013 335xi MSport Alpine White/Coral Red, ZMM/337/Walnut, ZPP, 2PE, ZDH, 2TB, ZTP, ZDA, ZDB, ZCW, HK, Shades
2013 X3 35i MSport Black Saphire Metallic/Chestnut, black grill, everything but lane departure, BMW trailer hitch
      10-30-2012, 08:52 AM   #9
john08135i
john08135i's Avatar
Mine works sometimes, but not most of the time when needed.
I set temp to 84+ and the dash dial to red..turn on fan cold air ..try different modes and cold air blows lower also.. tried automatic and see the AC light on all cold still..
sometimes after i power car off and back on it will run hot for a few min then back to cold...i love my car but having to go to the dealer all the time.
      10-30-2012, 09:43 AM   #10
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Mine did the same. They replaced the whole panel/unit.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      11-18-2012, 03:54 AM   #11
shutterlife
Drives: F30 M Sport AW
I'm having trouble as well. Set to auto, ac set to 84, center dial to red. Still cold. Dont really want to take it in, but anyone have an fixes yet?
      11-18-2012, 10:50 AM   #12
Jamesons Viggen
You're going to have to take it in.
It took replaced the whole control unit to fix mine.
      11-18-2012, 12:45 PM   #13
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
jesus HVAC issues on M Sports?
I'm a standard line, no issues yet in the Cold Northeast, 3000 miles. Makes me wonder WHAT they changed from lines to get this to be an issue...
SOLD: 2012 335i Mineral Gray
      11-18-2012, 02:25 PM   #14
Jamesons Viggen
It has nothing to do with M-Sports, the HVAC is the same part number for all '13 lines.
      11-18-2012, 08:33 PM   #15
john08135i
john08135i's Avatar
I finally took mine in. The heat when the car was first started cold but if you turned it off for a bit and turned heat back n it did nit work at all just AC.
they recoded mine car and it works perfectly now..
      01-23-2013, 08:06 PM   #16
Cadi335i
Drives: 2013 BMW 335i M Sport
For those of you who have heater issues, did you notice your engine running cold as well? I'm currently having the heater issue and the dealer has my car...
      01-24-2013, 11:54 PM   #17
Cadi335i
Any thoughts?
      01-25-2013, 12:26 AM   #18
Jamesons Viggen
My issue was independent of engine temp.
      02-15-2013, 03:58 AM   #19
SergioK
Drives: F30 328i
For those that had cold air blowing, was it cold as in ambient (exterior) air or was it as though the A/C compressor just kicked in?
It's been pretty mild here lately so in the morning I'll just run the hvac without the A/C compressor and temps set to about 72, center temp dial leaning towards red. Every once in a while I'd get a blast of very cold air, as if the A/C compressor started running even though the A/C button is not illuminated.
      02-15-2013, 12:35 PM   #20
BimmerBrova
BimmerBrova's Avatar
Drives: F30 335i M Sport
I have had both happening at the same time also. At this point engine temp is just always pegged to cold no matter what. They have replaced several parts to no avail....
      02-24-2013, 11:24 AM   #21
Cadi335i
Are you still having the issue?
      03-01-2013, 06:29 PM   #22
BimmerBrova
I was, but they might have found this particular issue. Its crazy. Will post when I know for sure!
