BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 35 offset on 18X8.5 wheels?
      09-13-2012, 12:24 AM   #1
Mako
2000 M Roadster (sold), 2006 M Coupe (sold)
Drives: '16 M3 SO '16 X6 35i MW
So tire rack states these will work on the F30 but to me something seems off.
BMW stock wheels 18X8.5 (on a staggered setup) use 47 offset, so won't these have some issues with a 35 offset and that same width?
http://www.tirerack.com/wheels/Wheel...e=245HR8LM60XL
      09-13-2012, 12:57 PM   #2
MRRwheels
Drives: E92
actually those 47et are only factory specs, factory specs are very conservative and sink in. on the aftermarket side anything from a 18x8.5 35et -45et will work but i would stay close to the 35et, 38et. now as for a staggered set up like a 18x9.5 do 45et
      09-13-2012, 01:56 PM   #3
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
Correct! Generally stock wheels are very conservative, allowing for a slightly wider wheel and/or lower offset.
8.5" ET35 can work perfect on all four corners. If you wish to go staggered, 8.5" ET35 Front & 9.5" ET45 rear will be a perfect fit.
      09-13-2012, 03:24 PM   #4
GTM_Challenge
GTM_Challenge's Avatar
Drives: E92 M3,X5M,F30 335
Send a message via AIM to GTM_Challenge
These should fit no problem. We have run this sizing on F30s already.
      09-13-2012, 04:06 PM   #5
Mako
Now my plan is to use these on a future M3 as well (in 3 years). Will I have any issues with that? I am guessing I will need spacers for the rear since it will be flared out more.
      09-14-2012, 04:06 PM   #6
tiltmode43
I plead the 5th.
tiltmode43's Avatar
M3's traditionally can take much wider wheels than standard 3-series. In fact, the OEM M wheels will likely be wider than these are which would make using these on an M a bit of a downgrade.
Maybe purchase new wheels later down the line?
      09-14-2012, 11:49 PM   #7
's Avatar
61
Drives: ✚
Please don't do this. M3 deserves the concavity. Not wheels with spacers.
      09-15-2012, 10:46 AM   #8
Mako
These would be for my winter set up on the M3 not my main wheel. And I wouldn't want any thicker wheels than 8.5 for winter.
