BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > My nav sucks. Anyone else?
      09-20-2012, 02:06 PM   #1
DR.Nefario
DR.Nefario's Avatar
65
Drives: 2013 Dakar Yellow M3
I had it say 350+ miles for something >50miles away. Nav was taking me upstate and back lol. Almost everytime it gives me some crazy distance or takes me on the worst possible route. A few times I knew the general area I was going to and would have to drive 90% of the way there and update the nav again before it was correct.
      09-20-2012, 02:30 PM   #2
ric124
ric124's Avatar
Jamaica
284
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Mine works fine but also depends on your nav setting. I think default nav setting is eco mode but I changed mine to fastest plus to work with the RTTM. so directs you around traffic
      09-20-2012, 02:31 PM   #3
sr5959
Drives: 428GC M-Sport
Mine has been very accurate in terms of routing so far.
      09-20-2012, 02:35 PM   #4
batislav
Drives: 2012 335i Sportline
Always accurate and routes are efficient.
      09-20-2012, 02:40 PM   #5
DR.Nefario
DR.Nefario's Avatar
65
I didn't realize it was defaulted to eco mode. I'll try changing it. Thanks
      09-20-2012, 03:31 PM   #6
CurlyFatAngry
CurlyFatAngry's Avatar
Drives: his BMW as much as he can !
It's crap when it comes to routes ... takes my through the worst traffic when I'm close to highways !!
Also bugged by the fact that maps don't show street names properly or at all sometimes. Even major streets, it's like a plate of spaghetti without a single label
'12 BSM w/ Coral red dakota 328i Sport Line, Premium, 40% tint
'11 Deep Sea Blue E92 335i XDrive, M3 spolier, black grille
'08 Jet Black E92 328xi, Premium, Sport, iPod, Black Grille, GP Thunder, Painted Reflectors
      09-20-2012, 03:55 PM   #7
hhuberla
Drives: 2013 335i XDrive (Sport)
A lot of nav systems have this problem. This happens because there is, for example, traffic data saying that there is a little traffic on the highway, so the nav looks for other routes. Problem is that a lot of minor roads don't have any traffic data available, so the nav interprets that as no traffic. I've been directe4d to a slow road that runs parallel to I90 which was gridlocked. Imagine my frustration when the highway comes into view and everyone is cruising along at 50mph.
H
      09-20-2012, 04:58 PM   #8
Rick4345
Rick4345's Avatar
Drives: 2017 M2 6MT LBB
I had used mine on a trip and it bypassed every exit and then route me back to it. My dealer is going to help me out on the update shortly. I would just rather use my Garmin with the lifetime map updates. A lot less costly and it never has steered me wrong.
      09-20-2012, 06:01 PM   #9
dzaborn
Drives: 2013 BMW 328i F30
Can you set the Nav to always route shortest distance (as to not account for traffic data)?
Also, do you get free map/data updates from BMW for the life of your car or lease or do they have to be purchased?
      09-20-2012, 06:51 PM   #10
ric124
ric124's Avatar
Jamaica
284
2017 BMW M2  [0.00]
You have different Nav option from fastest to eco route. you can disable the traffic data too.
dont know about free updates.
      09-20-2012, 07:52 PM   #11
rbe
Drives: BMW F30, Corvette C5
I like having instructions and speed limit info on the HUD. However, my BMW nav does strange things. I take freeways to the airport. I know the way, just like to use it to see how I am doing on time. When I transition from one freeway to the next, the voice and the screen says to go south. The HUD shows north, which is correct. When I go north the directions continue correctly, it doesn't tell me to make a U turn. I don't know why the screen and HUD show different info. It does that consistently. I have also had it tell me to turn left when I know right turn is correct. Same thing, I turn right and then it continues with the correct instructions.
Also my Garman shows exact replicas of freeway signs at junctions, but the BMW nav just shows a sign that is not a copy of what the sign actually looks like. As was mentioned before, the Garman speaks street names. The Garman cost $179 with bluetooth, free lifetime map updates and real time traffic info. BMW could have done better.
      09-20-2012, 10:32 PM   #12
EnerJi
Drives: '13 BMW 335i M-Sport EB-II
Perhaps this is why BMW is in the process of rolling out a new nav!
      09-21-2012, 09:35 AM   #13
weixp386
Drives: 2013 328i & 2011 318i
I agree... The current nav sucks.
      09-28-2012, 11:03 AM   #14
adelphi_sky
Drives: 2009 BMW 328i Jet Black
I had this same issues for a short time but figured it out. Check your route preferences. One time I wanted to find a way to get from one end of D.C. the the other without taking the highway. So, I selected the avoid highways option. Worked fine. BUT, I forgot that I left it on. So, the next time I had to use it and preferred the highway, it kept telling me to get off the highway. You can avoid highways and tolls. There's also fastest and shortest routes. You have to make sure you get the right mix for the trip you are planning or you will probably be taken where you don't want to go. I think the NAV is fine in that eventually, you'll get to your destination. But the nav just gives you 4 different ways to get there.
2013 328i M-Sport PCD / Estoril Blue II / Aluminum Hex Trim / Estoril Blue Matt / Black Leather / Tech Pkg / HK / Alarm / Xenons
Current Status: She's Home!
      09-28-2012, 04:19 PM   #15
Rick4345
Rick4345's Avatar
Updates
The updates are not free. I believe around 300 dollars. You can look on the BMW accessories section to make sure. Spend that on a Garmin and the car almost drives itself. I found out when I talked to my dealer about the price. When I bought the car, I didn't want to deal with the CD updates. I have a Garmin with lifetime updates, so the Nav system wasn't a big thrill to me. My CA was understanding the updates were free. I bought one of the first F30s on the lot, so I don't blame him for sure. The dealership has been great. They make up for a lot of stuff BMW doesn't take care of.
