Login
09-25-2012, 09:45 AM | #1 |
![]() 9
Rep 55
328i Warning coolant level
Hey,
I just got a warning pop on the dash about low coolant level. Is this supposed to run out at this stage? My scheduled service according to the system check is another 5000Km or some time in 2013. I thought we weren't supposed to touch the fluids etc. in the car really. Should I just put bottled water into the coolant tank?? |
09-25-2012, 09:48 AM | #2 |
![]() ![]() ![]() 31
Rep 465
This is not unusual. You should check fluids regularly. Please add distilled water to your expansion tank until it is full. Best practice is to fill it when the car is cold.
Note that if the system was very low on coolant, there may be an air bubble. Don't be surprised if the car asks you to again add coolant in a couple of days. That is not a problem. On the e9x series cars (I haven't tried it with the f30) you follow this procedure to bleed the system: Turn heat all the way up Put fan on low speed Turn ignition on, but do not start engine Hold throttle pedal all the way down, past the kick down switch, for 15-30 seconds When you open the coolant filler cap (again, cold engine) you should see the water circulating. This will get all the air out of the system. You should give this procedure a try. It couldn't hurt... |
09-25-2012, 12:02 PM | #4 |
Rep 465
Not all bottled water is also distilled. Check the label. If you can't find distilled, don't sweat it. But this is a good time to add some Redline Water Wetter to help keep your engine cooler!!!
09-25-2012, 12:18 PM | #5 |
![]() 401
Rep 2,077
Water Wetter mixed with coolant turns into goop. If I remember correctly, the WW bottle states: not to mix with coolant. I could be wrong, it was about 8 years ago when I last used that stuff...
09-25-2012, 12:41 PM | #6 |
![]() ![]() ![]() ![]() 62
Rep 650
Ummm no .. bottled water still as minerals in it. It just removes hard minerals (as part of the reverse osmosis process). There is still "nutritional" value in the water
Distilled water is essentially "dead water" meaning all minterals have been removed and drinking it isn't actually recommended. You won't die from it, but not good over the long term as it provides zero nutritional value. Distilled water is needed so that no desposits are left within the cooling system.
![]() 2013 335i ///M-Sport | + 2015 X3 28i xLine |
09-25-2012, 12:47 PM | #7 |
![]() ![]() ![]() ![]() 47
Rep 875
Assuming you are just going to add a few ounces bottled water or distilled would suffice. This little amount should not have an impact to the coolant plumbing if bottled water is used.
They say 'distilled' water because distilled water is a constant anywhere in the world, has no deposits and is always the same thing and is always safe. If it just said clean water then it would be open for interpretation. Some would add river water, salt water, you name it. Now if you were doing a complete flush and replace then, by all means, definitely use distilled for your 50/50 mix. |
09-25-2012, 04:27 PM | #8 |
![]() ![]() 18
Rep 205
I have the same problem in my F30. I've had the warning low coolant 2 times.
It seems to be a coolant sensor problem. Its a known fault at BMW, they are going to replace it on warranty |
11-24-2012, 04:04 AM | #10 |
![]() 0
Rep 12
i've been getting low coolant warnings for the last couple of days.. theres no signs of leakage.. i topped up the coolant a few times (first time it was very low).. went to bmw today, they put my VIN number in their system and then told me its a common fault with the most 3 series models.. i personally believe its the iDrive problem.. they have asked me to leave my car at the workshop overnight.. i'l update you guys as i hear from them!
11-25-2012, 04:25 PM | #11 |
Rep 5
It could be a sensor problem. Check the coolant level before adding anything...
It happened to me twice, and had it checked by the dealer and they said it was a problem with the sensor. The replacement part arrived a week or so later and they changed it free of charge. Both times the warning came up, I had the car parked outside for several hours on a hot day with no roof over which I don't usually do. Don't know for sure but that was the only thing in common both times it happened. Last edited by karaeloko; 11-25-2012 at 04:30 PM. |
11-30-2012, 05:31 PM | #12 | |
![]() ![]() 217
Rep 1,275
Drives: YMB M3
Garage List 2018 BMW M3 [0.00]
2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
12-03-2012, 06:00 PM | #13 | |
Computer Janitor
Rep 272
![]() You don't happen to know what the SIB number is for this, by chance? Just in case they try to give me grief over it since I probably won't be able to reproduce it for them.
2012 328i Sport Line 6MT (Turned In)
2015 Ford Mustang GT Premium (Current) |
12-05-2012, 10:31 PM | #14 | |
![]() ![]() 217
Rep 1,275
Drives: YMB M3
12-12-2012, 07:25 PM | #15 |
![]() 2
Rep 8
I just took mine in for the low coolant warning coming on even though there was plenty of coolant in there. They fixed it per the SIB. My service advisor told me that the sensor wire was getting corroded, so they replaced the sensor and put some type of cover over it. Also, there were two other SIBs that they performed on the car. One was a software update (possibly the wiper issue in other threads), and the other was putting some rubber stops in the front headrests.
As far as using only distilled water over a 50/50 mix, that should be fine, as long as you don't live somewhere with freezing temperature, because when I took my car in initially for them to look at it, they just put distilled water in it. |
03-17-2013, 04:46 PM | #16 |
![]() 75
Rep 1,185
i just started getting this
![]() had no issues prior to this. i went in once already and they just topped it off. it did go away but came on again. level is the same. |
05-10-2013, 10:34 PM | #17 |
![]() ![]() 0
Rep 76
When i got my car, (60 miles on the odo), the car was showing low coolant. Service topped it off, and i havent seen it since then. Car has 300 miles now. Any ideas on why it was low?
2013 335i M Sport Estoril Blue on Red (Lemon)
2014 i3 BEV - Solar Orange on 21's (Lease ended) 2017 X5 sdrive35i M-Sport Alpine White (Current Daily) 2015 GT-R Black Edition - Midnight Blue (Current Wknd) 1990 300zx Built Twin Turbo - Black (Current race car) |
06-04-2013, 10:51 PM | #19 |
![]() 36
Rep 145
My wife's 2012 started with this about 3 weeks ago. About 6-7 false low coolant messages. Dealer fixed today under warranty.
Invoice states: Expansion tank: 171022 Repair cable: 611011 |
06-13-2013, 03:32 AM | #20 |
![]() ![]() 37
Rep 135
I have been getting the same error, so went to get it checked and they did the programming (as they say) and resolved the issue but again the next day the light came up & goes off the next time i start my car & comes up in a few kms again. This time i have have demanded the coolant sensor replacement.
But how do i know the new sensor wont cause the problem again ? If its a official recall, then the part will be rectified by BMW but im not sure BMW knows about this yet. Any success stories ? Plz help Thanks
HORSEPOWER SELLS CARS, TORQUE WINS RACES
08-26-2013, 03:30 PM | #21 |
B0$$
![]() 21
Rep 126
Last Thursday the low coolant warning light went off and I took it to the dealership to top it off. Then yesterday while stuck in traffic it went back on.
The next day, I turned the car on and the light was off. Went to the dealership anyways to see to tell them about the situation. They checked everything, pressure tested everything and check to see if it was leaking twice. NOTHING. So at the end of the day, they took some coolant out because it was overfilled back to the max line. Then said that if it happens again take it in and they will investigate it. As of right now it's off. But I have a feeling it's going to turn back on because I believe is the faulty sensor..... ![]()
2013 Alpine White/Coral Red 328i Sportline- Mperf. Black Grills, Mperf. exhaust, Prem. pkg, Tech pkg, Lighting pkg, Heated seats, Sports 8spd w/paddles
12-09-2013, 05:30 AM | #22 | |
![]() ![]() 37
Rep 135
The solution which was replacing the coolant tank + sensor. I suggested the same to my SA @ BMW Infinity (Chembur, Mumbai), he agreed & got permission to replace both the parts (coolant tank + Sensor) under warranty. And VOILA, Problem solved Its been over 3 month now and no coolant level error till date.
