BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Standard features differences for 2013 328i vs 335i?
      09-29-2012, 12:40 PM   #1
pmc123
Drives: Ducati Monster M900ie
So I poured over this bmw features pdf to see what the differences are.
It looks like with the 335i, in addition to the I6 turbo, you get:
-Xenons
-Moonroof
-18" wheels
edit:
-exhaust
-alarm
-wood trim
-premium and lines are cheaper on the 335i
Did I miss anything?
Also, does anyone know if the manufacturer of the transmission is the same for both the 328i and the 335i this time around? If I recall correctly, E90 328i had a GM tranny...
Thanks.
      09-29-2012, 01:12 PM   #2
elistan
Drives: F30 328i, AP1 S2000
AFAIK, they both get the auto 8HP by ZF. I don't know where the MT comes from.
      09-29-2012, 01:18 PM   #3
DerekS
DerekS's Avatar
Drives: 2016 F10-535dx
In addition, the Canadian version also offers as standard for 335i :
sport auto transmission w/paddles
adaptive headlights
high beam assistant
larger brakes
heated steering wheel
sport seats
2016-535dx M Sport, Exec. Pkg, DA Pkg, 20" M Sport alloys Style 434
      09-30-2012, 08:20 PM   #4
zibawal
Drives: 2012 X5D
With all accounted 4k for engine upgrade is a valid charge
      09-30-2012, 09:52 PM   #5
RPM90
Drives: 340i M-sport AT
-Xenons
-Moonroof
-18" wheels
Thanks.
If the 328i is compared to an equal line 335i, then also add larger rotors and different calipers that come standard on the 335i.
Performance wise, the larger rotors and multi piston calipers should allow for more even brake wear over time, and allow more fade resistance.
You likely won't encounter fade problems with the 328i brakes unless you track the car. There may be some fade issues in comparison if you drive on very hilly terrain where you use the brakes for longer duration.
The brakes on either model work very well over all.
Yes, both versions use the same ZF 8spd AT.
      09-30-2012, 10:08 PM   #6
bmmcgraw
Drives: AH-64D
Wood trim, Alarm, and different exhaust are also included in the 335
      09-30-2012, 10:23 PM   #7
ric124
ric124's Avatar
Jamaica
392
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
hey you guys forgot about that oh priceless fun of driving and the sweet sounding exhaust!!!
Oh and I just discovered that my 6mt has launch control...oh sweet fun!!
      09-30-2012, 11:02 PM   #8
pmc123
thanks
how is the exhaust different?
      10-01-2012, 12:03 AM   #9
Koer
Drives: 335i 2012 luxury line white
thanks
328 sounds like a tonka toy truck and the 335 sounds like a mean puma on steroids.. Rawr.. ( not to mention separate tips on both sides of the car instead of just to the left)
      10-07-2012, 11:39 AM   #10
pmc123
I see another difference - premium on the 328i is $3100 and it's $2200 on the 335i. Modern is $2100 on the 328i and $1400 on the 335i...
      10-07-2012, 11:45 AM   #11
johnofcross
johnofcross's Avatar
Drives: Superman 2013 F30 335i M Sport
What launch control? Details??
2013 BMW 335i Sedan Estoril Blue II M Sport 19" 403M|6MT|Dynamic Handling|Tech Package|Coral Red Leather|Park Distance Control|Harmon Kardon
      10-07-2012, 02:14 PM   #12
E36toF30
Drives: 2011 E92 M3 DCT
What? I'm pretty sure it doesn't...
      10-07-2012, 02:29 PM   #13
raleedy
Drives: 2016 228i 6-speed
35i X1 has the old 6-speed AT from the E90. 28i has the newer 8-speed. [sorry folks; wrong forum! My bad.]
      10-07-2012, 02:30 PM   #14
raleedy
This is not right (see above) at least for the US market. There is no MT. [See above. Brain explosion -- thought I was reading in the X1 forum.]
      10-07-2012, 03:06 PM   #15
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Que?
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      10-07-2012, 03:11 PM   #16
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
-Xenons
-Moonroof
-18" wheels
edit:
-exhaust
-alarm
-wood trim
Thanks.
This page helps too - check out the ordering guide....
http://www.f30post.com/forums/showthread.php?t=691810
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      10-07-2012, 03:42 PM   #17
Roki_014
Drives: 2014 335i
Adaptive headlights also standard on 335i in US
      10-07-2012, 03:57 PM   #18
RobUK
RobUK's Avatar
Drives: 340i EBII
Better handling is standard on the 328i
(Lights blue touch paper and takes cover)
340i in Estoril Blue
      10-07-2012, 06:05 PM   #19
Roki_014
Drives: 2014 335i
Every day driver will barelly notice the difference in handling, when i test drove both of them i remember that 328 felt like it was struggling where 335i felt and sounded like a beast
      10-08-2012, 08:00 AM   #20
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
here is no launch control because there is no DCT option.
Last edited by sean10mm; 10-08-2012 at 10:11 AM. Reason: I'm a dope about 6MT/328/xdrive apparently :P
      10-08-2012, 08:12 AM   #21
ric124
ric124's Avatar
Jamaica
392
2017 BMW M2  [0.00]
LOL! Wouldn't it be better for you to ask me how to initiate launch control than to jump out and say that you are pretty sure that it doesn't!!!!! I have used it a few times
      10-08-2012, 08:43 AM   #22
BMWgasm
Hooah!
BMWgasm's Avatar
Drives: 2011 335i M Sport
Originally Posted by sean10mm View Post
Man, they sure do tolerate posting false information around here.
6MT is offered on the 328 and 335, including xdrive models.
There is no launch control because there is no DCT option.
Then why was I unable to get 6MT on a 328i xDrive? Not even the configurator allows you to get the 6MT with xDrive. Let's check the actual facts before posting that someone else's are incorrect.
'11 E90 335i M Sport Black Sapphire
'13 F30 328i M Sport Black Sapphire
