10-03-2012, 03:08 PM | #1 |
Rep 2,650
► APEX | Stud Conversion Kits and Extended Lug Bolts/Free shipping to the U.S. 48!
APEX Wheel Hardware
Apex Stud Conversion kits Try and find a BMW race car that hasn't converted to studs yet. They're stronger, safer, and improve pit stop times significantly. For non race cars, stud conversions make wheel install and removal much easier as you do not have to line up the holes in your wheels, spacers, and hubs before hand threading in a single lug bolt. Simply slide the wheel onto the studs, and let go. Your wheel will no longer spin around the hub, but will instead be lined up correctly. APEX 75mm and 90mm Stud Kits with silver or black lug nuts Extended length studs like these allow for a range of spacers to be used without any additional modification. You can easily use 3, 5, 10, 12mm with a 75mm kit or larger 15, 18, 20mm with the 90mm kit, or no spacer at all. When using lug bolts with spacers you are forced to purchase a different length lug for each width spacer. By remaining installed, the studs put less ware on the threads of your hubs. They guarantee there is enough thread engagement, as you can see how many threads were engaged during install. Wheel studs replace your OEM lug bolts by simply threading into your cars hub. Once installed they do not need to be removed when changing or removing wheels. Only the lug bolts are removed similar to many domestic vehicles. APEX 75mm and 90mm Stud Kits with silver or black lug nuts
Available Sizes and Pricing:
Available Lug Nut Finishes
Installation Kit Now Available! (Includes Red Threadlocker and 5.5mm Wrench) Apex Extended Lug Bolts Available in standard OEM length, and extended length version for use with 5, 12, 15, and 20mm spacers. APEX lug bolts can be purchased with either a silver or black zinc coating. BMW extended lug bolts sold individually Extended lugs are a must when using spacers, as the standard length lugs are not long enough to thread into the hub properly. If you want new lugs to go with your new wheels and spacers are not needed, then simply select "standard" length from the drop down menu above. If you are using spacers, then select the corresponding length extended lug bolts. Lug Bolt Specifications:
Available Lug Bolt Finishes Silver Black - +$0.50 Ordering and Contact
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-05-2012, 02:22 PM | #2 |
Rep 2,650
Apex stud kits are in stock in 75mm and 90mm lengths. The stud kits make life much easier when installing wheels and tires!
10-15-2012, 08:50 PM | #3 |
Rep 1,470
those stick out far too much for my tastes. how long are those, and is there a spacer. i want a set but want a reference picture for 75mm with no spacer.
10-16-2012, 01:28 PM | #4 | |
Rep 2,650
11-06-2012, 03:59 PM | #5 |
Rep 2,650
Apex stud kits are in stock with either Black or Silver lug nuts in 75mm and 90mm lengths!
Please call, pm, or email with any questions you may have.
01-14-2013, 01:40 PM | #7 |
El Jefe
39
Rep 1,345
I have a question, I am looking to get these in 75mm, but with my current set up, I have spacers. Will I have any issues or should I get the 90mm instead?
01-14-2013, 03:05 PM | #8 |
Rep 2,650
The APEX 75mm stud kit will accept up to a 12mm wheel spacer and the 90mm stud kit will accept up to a 20mm wheel spacer. We can also provide you with a split kit that would have 10x 75mm studs and 10x 90mm studs.
01-15-2013, 05:31 AM | #9 |
El Jefe
39
Rep 1,345
Cool I decided to go with the 75mm. I made the order last night. Thanks for your help.
01-15-2013, 06:54 AM | #10 |
11817
Rep 23,187
agreed. a very simple mod that is highly effective, adds strength and peace of mind. that being said is there any rule of thumb for replacement intervals for studs? number of track days, or time?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
04-08-2013, 01:48 PM | #12 |
Rep 2,650
Standard or OEM length lug bolts should have 28mm of thread length.
07-09-2013, 06:10 PM | #13 |
Rep 2,650
Apex stud kits are in stock in 75 and 90mm lengths with either black or silver lug nuts! The kit pictured below is the 75mm kit with silver lug nuts.
Please call, pm, or email us with any questions you may have.
07-17-2013, 06:37 PM | #14 |
Rep 6,702
Need replacement lug bolts? Look no further, we've got them available in Black and Silver, in multiple sizes!
08-03-2013, 10:37 AM | #15 |
Rep 192
Currently running 220 wheels with 15/12 spacers. Probably will be getting a set of ec-7 square later in the year. Which set stud kit should I run?
08-05-2013, 06:38 PM | #16 | |
Rep 2,650
Please let us know if you have any other questions and we'd be happy to answer them for you.
08-07-2013, 07:02 PM | #17 |
Rep 2,650
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out!
08-09-2013, 05:21 PM | #18 |
Rep 2,650
Switch up the look of your wheel setup by changing the color of your lug nuts (for those with a stud conversion kit) or lug bolts. We sell these items individually for your convenience!
Please let us know if you have any questions and we'd be glad to help you out!
08-14-2013, 06:04 PM | #19 |
Rep 6,702
Tired of wasting time aligning the wheel to the hub? We have 75mm and 90mm stud conversion kits to eliminate that problem!
Feel free to contact us by phone, email, or PM and we'd love to help you out!
08-15-2013, 06:34 PM | #20 |
Rep 2,650
Our BMW lug bolts come in standard lengths for cars without spacers as well as extended lengths for cars running up to a 20mm spacer. They're available in all sizes in black or silver:
Give us a call to order your set of lug bolts today!
08-20-2013, 03:56 PM | #21 |
Rep 2,650
Our stud kits are available with a stud install kit. The install kit includes an allen wrench and red loctite to make installation that much quicker and easier for you.
Please call, email, or pm us with any questions you may have.
08-21-2013, 06:48 PM | #22 |
Rep 2,650
Life becomes much easier once a stud kit is installed on your car. No more worrying about lining up your lug bolts with the hub holes while switching from street to track wheels!
Here is how our 90mm studs look without any spacers on: Please call, email, or pm us with any questions you may have.
