Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > e92 wheels on f30?
      10-04-2012, 10:26 AM   #1
apagan4182
Drives: '07 BMW 328 xi coupe
e92 wheels on f30?
I had the following on my e92:
wheels are 19 x 8.5, 19 x 10
Tires are 235/35/19, 265/30/19
Does anyone know if these will fit my f30 sport line?
Thanks for your help.
      10-04-2012, 01:11 PM   #2
kokopuffs405
Yup
kokopuffs405's Avatar
59
Drives: BMW?
2014 BMW M5  [0.00]
ET?
Oh hello
      10-04-2012, 02:16 PM   #3
apagan4182
Originally Posted by kokopuffs405 View Post
ET?
30mm in the front, 37mm on the rear
      10-08-2012, 12:38 AM   #4
pkancel
pkancel's Avatar
Drives: G30-Msport,435iGC, Audi A3
Not likely with a 30mm for front, 37 should be ok. I am seeing 35 front and 38 rear as the most common upgrade right now. I think thats safe with the tires you have. Now you could add a 5mm hub centric spacer to the front and be just fine.
      10-08-2012, 05:17 PM   #5
remmib
remmib's Avatar
Norway
830
Drives: 2013 F10 520d M-Sport
Don't see ET30 in the front on 19x8.5 as a problem.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      10-09-2012, 12:07 PM   #6
F555
F555's Avatar
Indonesia
26
Drives: F30 - 335i
shouldn't be a problem at front.
use 255 tire at rear, that might minimize the rubbing issue.
      10-09-2012, 02:37 PM   #7
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
200
Drives: Project Estoril
You will be fine
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      10-09-2012, 04:58 PM   #8
nano10
nano10's Avatar
157
Drives: 2018 F80 M3
I have been told by many that AG m355 for example with 19x10 rear and et38 is way too aggressive. Anyone tried a wheel with similar specs as OP setup seems to be 19x8.5 et30, 19x10 et37 rear
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
      10-10-2012, 01:42 PM   #9
1clean335i
1clean335i's Avatar
Vietnam
200
my morr vs8.2's are pretty much the same exact specs plus or minus 1 to 2mm and I am running a 275 in the rear. I've also had 20x10.5 +35 with a 285 tire and it was fine. No he say, she say here. I've done it.
      10-10-2012, 01:49 PM   #10
nano10
nano10's Avatar
157
Drives: 2018 F80 M3
thank you for response! fender roll necessary?
      10-10-2012, 01:54 PM   #11
1clean335i
1clean335i's Avatar
Vietnam
200
Go outside and feel your fenders. Nothing to roll back there
Oh btw, my Morr vs8.2's came off of my E90 so all that talk about the hub being different sizes was just that; talk.
      10-11-2012, 01:11 AM   #12
nano10
nano10's Avatar
157
Drives: 2018 F80 M3
Thanks dude, would love to feel my feel my fenders but they are still sitting at port in South Africa . I got the mods started a little early
      10-11-2012, 08:50 AM   #13
1clean335i
1clean335i's Avatar
Vietnam
200
Aww man. I know that feeling all too well!
      10-11-2012, 09:32 AM   #14
Jackson743
Drives: 335i M-Sport/EBII/ED 12/5
How much camber are you running with the 10.5's in the rear?
I'm considering 19x9 et35's for the fronts. Do you think they will fit?
Really beautiful wheels.
      10-11-2012, 09:38 AM   #15
1clean335i
1clean335i's Avatar
Vietnam
200
Factory specs. Those fronts should work depending on tire size and drop
