BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Non-staggered winters on staggered factory setup
      10-05-2012, 06:03 PM   #1
TheObviousChild
TheObviousChild's Avatar
Drives: '16 340xi M-Sport MPPSK 6MT
Forgive me for my utter lack of wheel knowledge, but I'm about to order my 335xi and will be finally purchasing a dedicated set of winter wheels and tires.
My CA informed me that the 18" Performance tire setup comes with a staggered config (18x8/18x8.5) whereas the 18' all-seasons come as a square config.
So I plan on getting the 18" performace tires and am now looking on TireRack for winters. I've decided that it makes little sense to go with a staggered winter config, but I'd like to make sure that a square setup of 4 18x8" wheels/tires woudl work on my 335 that comes delivered with a staggered setup.
I'm guesisng it will, but why rely on best guess when you belong to an amazing Bimmer hive-mind community.
      10-05-2012, 09:12 PM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
square setup is better as you can rotate the tires for even wear.
http://www.e90post.com/forums/showthread.php?t=751199
      10-06-2012, 07:33 AM   #3
remmib
remmib's Avatar
Norway
1154
Drives: 2013 F10 520d M-Sport
Yes.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      10-06-2012, 02:42 PM   #4
dude987
Drives: BMW 335i xDrive M-Sport DHP
Ditto. Just swapped out staggered for 18x8 square wheel/tire combo. Got it from Tire Rack with the TPM. Works fine no issues.
      10-06-2012, 03:08 PM   #5
Il Fenomeno 415
In top form...
Drives: '13 335i xDrive coming...
did you do this yourself or did the dealer do it? i'm also planning on switching out the 19" wheel staggered setup for a 18" wheel square setup for the winter and wondering if the setup needs to be recoded or anything or can I just change out the tires myself?
      10-06-2012, 03:42 PM   #6
Il Fenomeno 415
In top form...
what staggered wheels do you have with the 335ix? did you get the sportline w/ style 401 staggered?
      10-06-2012, 05:09 PM   #7
TheObviousChild
Just got back from the dealer and I'm happy to say my order has been submitted!
I ended up questioning until the last minute, but they happened to have a sport line in the showroom with the 19's and I loved them.
So the car will be delivered with the 19" wheels in the staggered config with summer/performance tires. 19x8" front / 19x8.5" rear.
I plan on getting a set of Enkei rims from TireRack that I found in a square 18x8 configuration with a set of Michelin winter-performance tires. I've heard great things about Blizzacks, but I've seen better reviews of the Michelin's....ride quality, sound, grip, etc.
Oddly enough, a service adviser was trying to tell me you could get great deals on a set of BMW rims to use as winters....by great deal I'm guessing he meant a little less than $4,000. The ones I've found are great and run about $260/wheel. I'll post a pic below.
Thanks for all the info guys!
      10-06-2012, 05:12 PM   #8
TheObviousChild
      10-06-2012, 05:53 PM   #9
Il Fenomeno 415
In top form...
So what did the dealer say about you changing out the staggered set for a square set for the winter?
Also, will you be changing the set out yourself or having the dealer do it? Just wondering if they need to reconfigure anything.
Thanks!
      10-06-2012, 06:31 PM   #10
TheObviousChild
Thanks!
They said it shouldn't be a problem. I do plan on doing it myself. TireRack does a great job putting everything together on their side (tires, rims, tpms sensors, stems, etc) and balancing as well so all you should have to do is jack your car up, take the old wheels off and put the new ones on. May have to reset your TPMS through the on-board computer, but you shouldn't need to go into the dealer for that.
      10-07-2012, 05:13 AM   #11
dude987
Ordered the wheel/tire w/TPMS from Tire Rack balanced and delivered. Used the BMW lift kit to swap out the tires myself. Just a good opportunity to test out the kit and gain some familiarity with it. Easy day. The quality of the lift kit is outstanding. Easy day. Very satisfied with results.
      10-07-2012, 12:03 PM   #12
TheObviousChild
Can you post a link to the BMW Lift kit you use?
2016 340xi EBII over Coral Red / ///M sport / Premium / Cold Weather / 6MT / Nav / Dynamic Handling / HK audi
Previous:2013 335xi EBII over Coral Red / ///M sport / Premium / Cold Weather / 6MT / Nav / Dynamic Handling / HK audio
2010 328i / MT - Previous: 2007 328i / AT (boo) - Previous: 2004 325i / MT
