BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 335xi 0-60?
VIBE Motorsports
      10-09-2012, 02:22 AM   #1
dbpe
Drives: 2013 335xi M Sport
335xi 0-60?
I've got 1800mi but still have been too lazy to find a nice road or strip somewhere. Has anyone timed their 335xi, or seen anyone else that has? Just curious because the speculation has been that it's in the low 4's. Remember, Xi. Method for 335xi still to sport+, brake, and let go at 2k? Also, has anyone tried the BMW phone app that does the timing?
2013 335xi MSport Alpine White/Coral Red, ZMM/337/Walnut, ZPP, 2PE, ZDH, 2TB, ZTP, ZDA, ZDB, ZCW, HK, Shades
2013 X3 35i MSport Black Saphire Metallic/Chestnut, black grill, everything but lane departure, BMW trailer hitch
      10-09-2012, 12:36 PM   #2
Mako
2000 M Roadster (sold), 2006 M Coupe (sold)
Drives: '16 M3 SO '16 X6 35i MW
low 4s I doubt, I would guess 4.7 with the right launch. The M3 with 414 horsepower and less weight is 4.2...
Also the X3 35i has been tested at 5.5 which is exactly what BMW claims. Same engine, same all wheel drive, sure it weighs more (512 pounds more), but I seriously doubt the weight difference will cut off more than 1 second in 0-60 times, especially when we are in the 5 second range already. In fact its a 14% weight difference, and 14% less than 5.5 seconds is 4.7 seconds (I know you can't do the math like that, there are more factors...), normally you don't get a direct weight to performance ratio like that, 10% weight savings might cut 5% off the 0-60 times...
      10-09-2012, 01:29 PM   #3
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
For what it's worth BMW claims 0-60 in 5.1 for manual and 4.8 for automatic (that's not a typo.)
http://www.bmwusa.com/Standard/Conte...fications.aspx
      10-09-2012, 02:22 PM   #4
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [5.00]
i would think its in the vicinity of 4.4 - 4.5, RWD can do 4.8 easily so xi should definitely edge the launch
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      10-09-2012, 02:58 PM   #5
Mako
there is no way the new 335 xdrive is only 0.2 seconds slower 0-60 than the current M3. I am picking up my 335 xdrive soon so I wish it were true, but I would bet BMWs advertised numbers are pretty accurate, maybe 0.1 off 0.2 at the most. unless someone finds a car magazine article to prove me wrong.
      10-11-2012, 10:37 AM   #6
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
i had 07 e92 335 with JB+ and i easly pulled on m3's and i fastest i ever clocked was 4.21 0 - 60.
i wouldnt rely on magazine numbers. i'd like to see what some members post here after their break ins. once you have your number hopefully you are pleasantly surprised
      10-11-2012, 10:46 AM   #7
sean10mm
sean10mm's Avatar
You can't compare a chipped car to stock though. Especially since it's not even the same engine (N54 vs N55 for the F30.)
      10-11-2012, 11:19 AM   #8
rocko911
Bahrain
Drives: 2012 F30 335i Sports line
Well I have a F30 335i and my best 0-60 was 6.2 secs! Thats way too slow compared to what BMW and other magazines are claiming of 5.3 - 5.5 secs. I did it on a complete dead stop and using immediate kickdown on the pedal without using the launch technique rev to 2k etc.. I didnt use the launch method thinking it might be harmful to the engine, brakes & gear according to what my dealer quoted.
I tried all modes sports & sports + and what surprised me most was that I was getting better results when the shifter was on the "D" rather than shifting it to the left "DS" I know it depends on a lot of variables including climate and tyres etc.. I need to try it again but whats the best way to launch and in what mode?
The 335xi will definitely be quicker at least 0.3- 0.5 faster than the 335i. The bottom line is that magazines will state something else but we drivers need to see ourselves what performance we are getting on the clock. 0-100 or 0-60 nowadays is a marketing tactic used by auto companies just to advertise their product. Also USA BMW website claims 0-60 in 5.1 secs for the 335i while the European site claims 5.5 secs. So it doesnt matter what they say , its up to you to find out your self what you get.
      10-11-2012, 02:22 PM   #9
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
true but i was comparing to m3. from what i have read so far f30 is on par with e90/92 in terms of performance
      10-11-2012, 02:23 PM   #10
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
thats a terrible time....when i was getting used to my e92 i ran low 5's and thats with bad starts and slow shifts
DS shifts much faster not sure how ur results r contradictory to every one elses.
how r u measuring the time? maybe thats where the fault is
      10-11-2012, 03:08 PM   #11
dude987
Drives: BMW 335i xDrive M-Sport DHP
Given the combination of optimizing a tight rpm power band on the 8 spd/auto, sport auto shift, early low rpm torque, and a/w drive power delivery to all four wheels, the 335i xDrive may very well give the M3 a run for the money on 0-60. However in a real world track environment, the M3 will probably be in a class of it's own. Unfortunately there are no factual data or creditable articles to back up my "innuendo" / "unsubstantiated claim". Just a gut hunch based on the conglomerate of information/misinformation available as fodder for common consumption. Just a thought. It'd be interesting for a "credible" (yes, I use this term loosely') media source to conduct a performance comparison of the M3 to the 335i xDrive (Summer tires w/Adaptive suspension). Gut instinct says it will be close.
      10-11-2012, 03:56 PM   #12
rocko911
Bahrain
I know the timing sucks , I need to try it out again. I used the normal start/stop watch and also on the phone and all the results were showing above 6 seconds :S
      10-11-2012, 04:07 PM   #13
sean10mm
sean10mm's Avatar
If you don't build the revs before launch you aren't ever going to match the published 0-60 times for any car. That goes double for an AWD car, which is easy to "bog down" if you launch it badly and lose a lot of time.
      10-11-2012, 06:04 PM   #14
motorsport_cat
motorsport_cat's Avatar
Drives: 1995 740iL
1995 BMW 740iL  [0.00]
The 328i xdrive was testes by motor trend mag, and they achieved a time of 5.6 (0-60). I'm not sure if I'm right, but the N55 has a twin-turbo. Even if it is a single turbo, it does have over 300hp. I would think that the fastest time can be around 4.6 seconds.
///Meow
      10-12-2012, 08:04 AM   #15
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
handling wise it can never compare to m3, thats where m3 beats out beasts like c63 amg and cts-v but straight line is not one of m3's stong points. (not that it should be, it is fast enough)
