BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Bump stops
Vorsteiner
      10-11-2012, 02:50 AM   #1
BMoutlaW
Team Blop
BMoutlaW's Avatar
Drives: F30 328i M-sport
Bump stops
Has anyone used these for their f30?
http://www.autohausaz.com/search/pro...%20Bump%20Stop
      10-11-2012, 10:36 AM   #2
JUSKIDN
JUSKIDN's Avatar
Drives: 2013 EBII 328i M Sport
would that be after its lowered?
It's not illegal. It's frowned upon, like masturbating on an airplane.
      10-11-2012, 11:08 AM   #3
F555
F555's Avatar
Indonesia
25
Drives: F30 - 335i
looks exactly the same as the OEM, then what's these for?
      10-11-2012, 10:06 PM   #4
RollingLower42
RollingLower42's Avatar
43
Drives: 2012 BMW 335I
Is that so you prevent your tires from hitting your wheel wells?
      10-11-2012, 10:50 PM   #5
jbass524
Drives: 1995 E36 M3
This was a fix for lowered E9X. They have very little travel and if lowering springs were used, even less. Some coilovers would benefit from it also. I know mine did.
There could be drawbacks but I am not sure. The OEM suspension was designed to have a certain amount of travel with some of that into the bump stop. The bump stops are progressive so it the suspension reaches it bottoming out point more softly.
You would have to compare these to our OEM bump stops to see if travel would be increased.
