BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > inner headlights
      10-13-2012, 12:09 AM   #1
Roki_014
Drives: 2014 335i
inner headlights
How do inner headlights light up, is it only when turning?
      10-13-2012, 02:04 AM   #2
LousyShot
LousyShot's Avatar
Drives: MY13 MGM 335i
It depends on which headlight configuration you have. If you have xenons then they light up when you pull the turn signal stalk towards you to "flash" someone. If you don't have xenons then they act as daytime running lights until you turn the headlights on, then they act as highbeams.
      10-13-2012, 02:43 AM   #3
340driver
Singapore
Drives: F15 Xdrive35i Pure Experience
That's not quite right. If you have xenons, the inners are BLANK.
      10-13-2012, 09:24 AM   #4
Roki_014
Drives: 2014 335i
Ita a 335, i have xenons, high beams are through outter ones as well, so whats there purpose than?
      10-13-2012, 10:03 AM   #5
Naambezet
Netherlands
Drives: BMW X1 sDrive 20i
The angel eyes would look weird if there's nothing in the inner one.
      10-13-2012, 10:10 AM   #6
tores
tores's Avatar
Norway
Drives: F 34 M sport
I have a F31 with xenon, same here. It was the same on my 2009 E 91 aswell. I asked one of the BMW dealers in Olso for the purpose of the inner lights but they could not answer.
      10-13-2012, 06:41 PM   #7
LousyShot
LousyShot's Avatar
You are correct. I had xenons on my E90 and thought the F30s worked the same but they don't. I just went out and checked and the F30 does use the outer xenons to "flash". The E90 had halogen bulbs for the inner lights for the flash function because it wasn't considered to be good for the xenons to go through rapid on/off cycles. Guess they figured out a way to make it work.
I humbly apologize for the misinformation.
      10-13-2012, 06:53 PM   #8
Roki_014
Drives: 2014 335i
thanks guys, i honestly thought something was wrong with mine until I started reading, and just wanted to confirm, it would have been cool if they both worked but still they are the brightest ones on the road
      10-15-2012, 02:45 PM   #9
Elk
Drives: 2012 335i
Four round headlights are a BMW design cue. At some point BMW will probably drop them, to howls of protest from the cognoscenti.
When high beams are invoked, a little shutter in front of the bulb moves out of the way and allows more light to pass. This is why switching between high and low beam is instant and there is no warm-up time when going to high beam.
      10-15-2012, 02:52 PM   #10
AVIMAX
Drives: last BMW was 2014 535xd
On my old 3 and my current 5, and I think the new 3 is the same, the inner headlights are cornering lights. Left lights up when you turn left or turn on the left turn signal, right when you turn right and both light up if you put the car in reverse.
      10-15-2012, 03:07 PM   #11
Elk
Drives: 2012 335i
The inner lights are blanks, merely taking up space. The fogs perform the role of turning lights.
      10-15-2012, 03:28 PM   #12
SamS
SamS's Avatar
Drives: 2018 X3 M40i
What if you have M-sport (no fogs).
      10-15-2012, 10:46 PM   #13
Elk
Drives: 2012 335i
Then no turning lights. The inner pair remain inert.
      10-15-2012, 11:50 PM   #14
Tacoma
Drives: BMW's for 25+ years
Or it was to save cost.
      10-16-2012, 10:42 AM   #15
Elk
Drives: 2012 335i
Bi-Xenon are a great deal cheaper than separate high beam housings.
