BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Anyone experienced this Problem - Black soot from 328i exhaust?
European Auto Source
      10-18-2012, 01:11 AM   #1
wvoz
Drives: F30 328i 6MT Sportline
Question Anyone experienced this Problem - Black soot from 328i exhaust?
Hi all
I bought from New 328i 6MT built Jan 2012. Driven over 6000Klms. Having black soot coming out of exhaust and onto paint work, extremely visible near exhaust pipes but covering most of rear bumper / boot with finer particles.
I have been using Premium High Octane RON 98 petrol since 1st day and I never run petrol tank under a quarter full. I have also tried to isolate the problem by using 5 different petrol suppliers with always same result.
Power seems OK but not sure actual performance as I have never driven another 328i.
I also had Computer replaced about 3 months ago as car had to returned back to dealership due to computer malfunction.
My BMW dealership have looked into the problem with no solution and are awaiting an inspection from BMW Australia Head Office.
I have attached pictures below and appreciate anyone's feedback and assistance
Thanks
William
      10-18-2012, 04:01 AM   #2
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
Woah, that looks pretty bad!
Check Engine Light on at all?
      10-18-2012, 04:12 AM   #3
JOHN328
Feeling horny
Australia
18
Drives: BMW F30 328
Originally Posted by wvoz
Hi all
Thanks
William
Should be alright. I got the same thing. Where in AUS r u? May be we can come out n do a drag to see any difference. Lol
BMW F30 328i Sport Line
      10-18-2012, 04:32 AM   #4
francis_william
Drives: 2012 328i sport
Which fuel company are you using? change another brand and see will there be any improvement? BP?Shell?
      10-18-2012, 05:53 AM   #5
wvoz
No, No error messages at all. Taken back to BMW but did not mention whether they can see any error messages
      10-18-2012, 06:30 AM   #6
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
2924
Drives: M2
Wow, looks really bad. Never experienced anything like that. That is not normal no matter what BMW tells you.
      10-18-2012, 06:41 AM   #7
wvoz
Tried them all - shell, bp, caltex, etc with same result. I don't think it's problem with petrol.
      10-18-2012, 07:01 AM   #8
wvoz
Hi all
Thanks
William
Hi John in in Sydney where are you? Have you had BMW look at the problem and I'm interested to know if they have advised you on a solution?
      10-18-2012, 08:11 AM   #9
MikeVictor
Australia
97
Drives: anything given a chance
I've had this as well and it's reduced a lot over the past 3000km. I thought it was just the exhaust wearing in and the fact I have Mineral White paint just means it shows up more. Certainly performance isn't an issue.
      10-20-2012, 10:28 AM   #10
Demetrius Joel
Drives: 2014 BSM/CR M235i
2014 BMW M235i  [0.00]
I had the same problem at first too, went away after a while.
      10-22-2012, 11:28 AM   #11
Asterix
Asterix's Avatar
Drives: BMW 328i F30
Same problem, on Alpine White it is quite visible but was never really concerned , may be I should have been !
At 8000kms , I can still see it
      10-22-2012, 04:43 PM   #12
rickk
rickk's Avatar
Netherlands
Drives: E30 325i, E46 320d, F21 125i
Just an heads up that there are similar reports from AW 1-series drivers: http://f20.1addicts.com/forums/showthread.php?t=739305
2013 F21 125i Estoril Blue M Sport
2002 E46 320d Steel Gray M Sport
1986 E30 325i Royal Metallic Blue
      10-22-2012, 05:29 PM   #13
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Some soot is to be expected but it's what looks like globs that would bother me. Even without a catalytic converter I have not seen this before.
The post below seems a pretty good explanation. OP, out of curiosity, do you rev up the motor when first starting? I typically warm mine up before driving, maybe why I don't get the globs?
Originally Posted by AusF20 View Post
REF: The black stains / spots on the duco around the exhaust end
This is a common issue with short curved tail pipe/s and close mounted rear back box.
When the engine shuts down after running hot, the gases still cooling in the system cause an inversion that sucks water vapour back into exhaust system, (usually worse in cold or wet weather), unfortunately as the back box is just behind the short rear pipe/s the vapour turns to liquid and accumulates in the box.
When you run the car the pipes are not long enough for the liquid/slurry to be dried so some of the liquid is caught in the vortexs around the exhaust tip lip and is then splattered onto the duco. Not a lot you can do about it.
You can get exhaust tips that have a closing flap on them to stop this, however they look crap and usually make the exhaust note sound wierd as the flap acts like a reed in a wood instrument. They work great on boats.
      10-23-2012, 05:34 AM   #14
wvoz
My problem started after I completed the run in stage. I usually start the car and proceed to drive off slowly without revving over 3500 until engine has reached correct driving temperature. Car is always garaged and or undercover at work. If I'm racing the engine I deactivate the auto start stop to allow the engine to naturally cool the turbos. Problem does not seem to be getting any better over the last 4000 klms. I am interested to see if anyone who has had the same problem has had it solved.
      10-23-2012, 06:22 AM   #15
wvoz
Thanks very interesting. I wonder if its a turbo issue with BMW? given they only recently replaced their naturally aspirated engines with turbo versions?
      10-23-2012, 06:28 AM   #16
MikeVictor
Australia
97
For petrol engines BMW first used turbo chargers in the early 70's on the 2002 I believe, and the N54 twin-turbo has been around for five years now.
I accept "recently" is a relative term too.
Checked with a mate of mine at the office who has a Melbourne Red 328i Sport line and he noticed it also.
After I clean the car this weekend I was going to try and run it for a week with the ASS function turned off, as I wonder if it's being caused by gases cooling and the carbon building up before being suddenly ejected out, giving the "explosive carbon diarrhoea" we're seeing. It's a wild guess based on no fact whatsoever, but I'm up for some speculation
It's certainly unusual.
      10-23-2012, 01:53 PM   #17
wvoz
Very interesting. I will also try the same. Seems logical as when I was running in, and didn't seem to have the problem, I usually did engaged the ASS. Thanks for the suggestion.
      10-25-2012, 09:35 AM   #18
Vitoco
Infidel
Vitoco's Avatar
Sweden
53
Drives: F31 328i M Sport
I would think that the exhaust flap thing is the biggest problem here; when closed, on the lower revs, the exhausts get trapped behind it and if the engine doesnt get heated or revved enough these extra trapped fumes eventually cool off there, condensating. Meaning u get a lot of water build up there. Next time u rev enough for the flap to open u get that nice sludge spray painted on the bumper.
Golf Tee mod it is
Glacier Ag. F31 328iA RWD M Sport oct. 2012
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      10-25-2012, 04:30 PM   #19
MikeVictor
Australia
97
Golf Tee mod it is
That's a good point, mate.
Looking at the OP's photos, it seems to be spraying more from the right/inside exhaust port.
Is that the one with the flap?
      10-26-2012, 04:52 AM   #20
Vitoco
Infidel
Vitoco's Avatar
Sweden
53
I have no idea, got my car one week ago (freakinībeauty ) but Iīve only had time to drive it to and from work. This was just a theory I had, I havenīt seen any soot whatsoever on my ride and my pipes are staying clean. But I can imagine that this can be the factor behind your soot. Even if its not, that exhaust flap can cause problems with anyway. I always (almost everytime) make sure that when I start the engine I wonīt shut it down til it reached working temp so that any water build-up in the exhaust vaporizes or gets blown out when Iīm revving it. Often feel the exhaust pipes when I park to let the turbo cool off before shutting it down, if the pipes are warm then I know the whole system has got heated up.
Some might say overkill, but mine isnīt a lease like most of u guys have. Plan to keep it at least this generation out, and I drive around 50k miles a year so... yeah, I care
      11-05-2012, 08:53 PM   #21
wvoz
UPDATE:
Tried 1 week of driving (approx 300 klms) with Auto Start Stop function disengaged. I have noticed the problem of black soot coming out of the exhaust onto the body work reduce but not completely eliminated. I am interested to see if other 328i owners are experiencing this problem or is it only isolated to mine. Any feedback from other owners will be very helpful as dealership claims that this is normal especially on WHITE cars.
Thanks
      11-05-2012, 09:21 PM   #22
lukster
Drives: like a granny
same issue with mine. was told it was normal. took it out with goof off and waxed it back up. i clean it up every time i wash the car. the build up is not that much if you take it out every few hundred miles or so. i'm having an issue polishing up my tailpipes though.
